My experience....with our 2022 LE2 Norcold I left my setting on auto while boondocking and my LP ran out. The result was an automatic switch to DC while we were away for 2 days. On a good note, with help from Steve L. and JD I got to throw away my 4 6v agms and switch to 600 ahs worth of Epoch Lithuims. Albeit an expensive lesson I couldn't be happier that it happened :)
Nope, and these tires are on a list of "China Bomb Tires", thinner sidewalls, tread delamination, and blowouts
Please tell me you're kidding.
Wow! Really? Can this be true? Six years ago, I purchased an old 12’ flatbed trailer to haul our dirt bikes and SxS. Dexter tandem axle 7K, same suspension as OEM Oliver. I planned to restore it, new wiring, lights, paint frame, new flooring, add brakes to the rear axle, etc. OMG, It had China tires! I quickly purchased a set of the US made Goodyear Endurance ST tires. Listed the old tires on Craig’s. Sold the set for $100 because I didn’t want to take any more money from anybody. I explained twice to the new owner, these are not safe for highway use! He was OK in using them for a landscape trailer. John, please explain to your friend he needs to buy new tires! Anybody taking possession of a new Oliver, let OTT know you’ll not accept delivery with those cheap tires! 🙃 Glad most of us have 16” rims with LT tires mounted!
Best built camper in the market... riding on Chinese steel springs and Chinese tires? .
Not replace, but repair the connection so it cannot come off again. Is it for the inverter/charger? So a 110V plug like the fridge? If so, it’s not the plug but a cheap outlet receptacle. That could be replaced with a Leviton or a quality outlet not Made in you know where! Cheesy, yes! OTT wired the outputs on our inverter using a residential junction box and wire nuts! 🤣 Hardwire? I’d do that in a heartbeat! 😎
Apparently, Oliver has now switched to the Chinese Tires. This has been confirmed by a reliable source.🙃
It's possible a dealer swapped the tires out. I've heard of dealers doing that sort of thing. Example: The sale of some other brand trailer they have on the lot is held up because the customer doesn't want the Castle Rock tires. There's the unsold Oliver over there with brand new Goodyears in the same size. Problem solved!
Winter heating with a small electric heater
Galileo replied to Carl Hansen's topic in General Discussion
Sounds like a good idea. I typically like to keep my vehicles as “stock” as possible as I’ve found a lot of aftermarket accessories to be pretty poorly made and (IMHO) detract from the value of something rather than enhance it. I’m generally a firm believer in the people who designed, built, and service a specific item being more expert on that item than I am. I also realize that I’m unlikely to live forever and be the only owner of a vehicle, so I like to have it as OEM as possible to retain resale value. That said - when I see obvious poor design, construction, or installation - like HUGE air infiltration issues, or duct routing on a furnace that chokes off airflow or has such long runs that no air flow can be felt at a vent when the blower is running - THEN I’ll carefully consider and select ways to improve upon something that was poorly done from the factory. -
Point well-taken on the replacing the socket and/or plug - and if this one were old or worn I’d agree. However, since this one hasn’t been subjected to multiple plugging/unplugging cycles - which would cause one to be loose or weak - I doubt replacing it would yield any better results. Short of cutting off the plug and hard-wiring it to the source, replacing it would be unlikely to solve the problem or eliminate the need to check on it periodically. Additionally, though the receptacle the fridge plugs into IS a standard duplex outlet, the one the battery charger plugs into is a special one that that snaps into the back of the A/C breaker box, and probably doesn’t have a higher-quality replacement available. Only cutting off the plug and hard wiring it will truly “fix” the issue. Anything less is just a band aid. IMHO - having installed items like the battery charger and fridge plug into a household socket is a pretty cheesy way to handle power on a vehicle subject to vibration and shock as part of its everyday mission. Kind of akin to using household Romex on a boat. (Which I’ve seen done - but not by professionals or knowledgeable laymen.) And correct on the “auto” mode on the Norcold fridge switching to A/C when available. It normally does this. When it stayed in LP mode even with shore power connected is when I went into trouble-shooting mode. The issue was not my failure to understand or select the operating mode I desired.
Brand new trailer picked up last week, but don't know it was a Dealer or Hoenwald.
marsharini started following SeeLevel Tank Monitor Issue
Thanks everyone for the suggestions. Will check further report back.
Steve Morris replied to Carl Hansen's topic in General Discussion
I’d like to hear more about what kind (brand, model) was installed From Hank’s FB post: ”Camping Northern Florida. 31F this morning and a very comfortable 76F inside. A small space heater on the low setting only. 12VDC warming blankets on the beds. Using only 11 amps shore power. Basement temperature is holding at 66F. Two small 12VDC fans, one port and one stbd side keep a gentle air flow circulating thru the basement. With the bathroom vanity port open, cabin air is flowing into the basement and returning thru the return grill below the bed. The basement partitions have been removed and a 700W Xtreme heater is mounted inside (auto on at 43F off at 55F) for very cold conditions. Last week camping at 14F the Xtreme heater did come on to maintain a temperature well above freezing in the basement while we were gone.” If you are a member of the Oliver Owners of America facebook group, look up member Hank White, and scroll through his group posts. This one was from January 2025, with several photo. Hank has done a *lot* of cool modifications, and having seen them in person, I’ve added several to my list to things to do. -
Hmmm.....I wonder if his trailer was bought from a dealer or he possibly bought it from a private owner.
Brand new owner discovered Chinese made tires on his new trailer. Castle Rock Tires. Oliver has stated they are installing Goodyear Endurance 15", 10-ply "E" Rated tires. So how does a Chinese tire end up on a brand new Oliver trailer? Chinese tires have resulted in hundreds of blowouts on stock built trailers where everything is cheap. This is strange. I told him he needed to reach out to Oliver asap.
I'd say, this is not such a good idea. Go back to your post from last year and review Geoff's suggestion @Snackchaser. Time to fix the issue vs. adding a checklist item. Not sure re the Norcold fridge controls, but on our Dometic when in LP mode it will stay there by design. When you select "Auto" it will switch to AC if available, or DC when not plugged in.
RM 2454 Problem Heading into SE Colorado Boondocking
jd1923 replied to Geronimo John's topic in Mechanical & Technical Tips
Good work Bill, and you made GJ's day! I have this as part of our "2016 Elite II Owners Manual" PDF, but every time a fellow forum member posts an electronic PDF file, a manual or schematic, that relates to our hull, I download it and save electronic copy. I prefer using PDF files. Not just for the absence of carrying the big basket of paper, but for ease and speed of search. When GJ wrote his model # in the title of this post, I search my 557-page PDF copy of the Oliver manual for keyword "2454" and in 2 seconds it jumped to page 151 where the Dometic fridge manual starts in this long file. I use the Ctrl-F hotkeys, type a keyword, and there it is. No time taken to review the Table of Contents, search an index in the back pages or thumb through paper. This search capability and other tools we have today are so useful! I show my Project Management Professional (PMP) students this, in every class I teach, as they must navigate through multiple PMI standards, 1000s of pages of content they could see on their PMP Exam. I use the Ctrl-F search function several times a day for anything I'm looking for, searching the content of web pages, doing Oliver research and searching the shop manuals for the many cars, trucks, bikes and appliances we own. It's so handy! 😎 You sure have your files well-organized though, and most people still prefer paper copy. The young professionals in my classes are strongly against printing long files for sustainability concerns, like the 290-page slide deck we use, at 2 slides per page, OMG it's a lot! 🤣 -
Galileo started following Accessories unplug themselves…
In just a routine look under the aft dinette seat, I discovered the battery charger plug to be halfway unplugged yet again. Two thoughts: 1. Add checking this to a periodic maintenance checklist. 2. It’s about time for my fridge to stop working in A/C…
I guess we could do that - we have a set of ten of those levelers and I use my LevelMate Pro + to maneuver into site where I rarely need more than two of them. Just sounds like a bit of a pain. Then again, I’ve been known to chock the wheels and unhitch to raise the nose of the trailer at some dump stations.
That beats stepping on them in bare feet in the middle of the night! 😂
@Geronimo John and of course, you have the tank diverter valve pointing at the full tank. When these crossover valves switch from the empty side to the full side its secondary pressure is lower. -
We also drive our truck onto Legos when we hit a dump station.
Townesw replied to Geronimo John's topic in Mechanical & Technical Tips
@Geronimo JohnI hope that has the answers that you are looking for. When I brought hull 313 home in March 2018 I crawled all over it taking pictures of data plates on equipment with model numbers and serial numbers. I then went online and found manuals (owner’s, installation, service, parts, whatever I could find) for the model and serial numbers that were on our Oliver. Some of the manuals on the Oliver site aren’t the correct manual for the model and serial number range of the equipment used in our Oliver. I then printed out the manuals and put them in 3-ring binders that I carry in a tote that fits under the front dinette seat. I know it’s bulky and isn’t as convenient as a link on a phone but I can open a manual and look at it and make notes while I’m working on something. Bill -
@Geronimo Johnsee if you can find any answers in this service manual https://fourwheelcampers.com/NewDometicRefrigeratorManual.pdf I had trouble getting my RM2454 to cool in Ashland VA last week after working fine for 3 weeks. It was just too hot there at 97F for the absorption cycle to work well. I temporarily added a double bladed window fan from Lowes. Still wouldn’t work even at night. Turns out that too much air movement is as bad as not enough. I turned the temporary fan off and the refrigerator started working again. Bill
