The "Master Light" switch and all the others except "Curb Awning" and "Rear Camera" would not turn. So no lights anywhere. It remained that way for 7 hours. Just now it cured itself and all is working! What the heck just happened? Will happen again? Signed, Confused.
Spare Tire wobbles inside the fiberglass cover
Townesw replied to Dirt Duff's topic in Mechanical & Technical Tips
Mine wasn’t wobbly. It was very secure. Always has been tight. I just didn’t like the stain that the tire was leaving on the gelcoat. @Dirt Duffyou’ve got something else going on. You need to determine what is loose. - Today
The Suburban tank is simple and reliable. There is nothing about it that can’t be serviced by the owner. Parts are available on Amazon and most RV shops. I’m not going to change ours out, I like reliability when out in the middle of nowhere. Mike
Thanks, Rob. I will take a look at the Fogatti. I am open to all options. Also, we have an LE I so that may create different space limitations from the LE II. Bob
@Olive2Roam No experience with the Aqua Go but as John stated about a month or so ago I did install the Fogatti WH. In short it works great, very quiet and has an awesome control system via a wired remote. It is much smaller, and much lighter than the older Suburban WH (empty) and you are not carrying around another 50 lbs of water while traveling albeit chump change in weight compared to everything else. Understand other than using it to make sure everything works I haven't been out on a trip this year at all due to knee replacement surgery 4 months ago yesterday so at this point cannot absolutely speak to its in field use and efficiency. It heats up fairly quick but not instant due to the cold water in the lines so we plan on having a container close by to fill with unheated water that will be pumped back into the fresh water tank later given the somewhat smallish Oliver holding tanks. Not that big of a deal really. We never used the Suburban in AC mode, only propane. FWIW I am not a big fan of Suburban products but especially their furnaces like the one installed on the Oliver. As John pointed out Truma is out of the question for a litany of reasons. It is worth noting we never had issues with our Suburban WH other than cleaning and anode rods but have had multiple issues over the years with the furnace and it is loud. I would install the Fogatti furnace in heart beat if there was room in the basement of the Oliver but the shape and size of the Fogatti furnace just doesn't fit unfortunately. It's also important to note DIY people can work on and repair the Fogatti appliances if the need arrives. The Fogatti WH is NOT an easy install however, or rather replacement with the Suburban. How that differs compared to what you already have I don't know. One thing for sure is the Fogatti is light years ahead of Suburban technologically speaking, Design, fit and finish is on another level as well. Suburban products look like relics out of post WWII era by comparison. Hope this doesn't offend anyone. LMK if you have questions about the Fogatti. Oh and they do go on sale from time to time and would expect a 4th of July sale or at least Memorial Day sale if not Dads day sale.
New axles may not fit all older sub-frames
ScottyGS replied to Wayfinder's topic in Mechanical & Technical Tips
I know this is an old thread but.... I am currently in the market for the Nev-R-Lube Axles and wanted to share that Hull #145, a 2016 model, picked up in June has the 50.5" axles. I also assume that current LE2's are provided the D52 axle with an SC measurement of 50.5"..... If someone would confirm that for me I would appreciate it. TIA, Scotty -
ScottyGS started following New axles may not fit all older sub-frames
*Batteries charged with Bluetti power bank. No problem. Used ground plug and external surge protector. Full charged batteries. *Have DC abd blue lights on. *Jack works. No lights.
John, As always, very helpful. And the LP only model would be an interesting option.
Thank you, Scotty. As far as needing more room under the bunk, so the suburban would not fit into the aquago metal "box", is that correct? So there is some reorganizing of the space under the bunk? I would probably look to have OTT do the work. Bob
These Optifuse breakers are known to fail. There are a few posts here about that. I do not know what the common failed position is, but could be open when it looks closed. I would test for continuity between the two posts on the breaker. Be careful though, these are HOT, or at least the battery side is if the breaker is defective (open when appears to be closed). Hope you get your DC power up soon but put it on your mod list to replace this breaker with a 60A ANL fuse and holder. I do not believe anybody has found a quality 60A breaker. They're all cheap junk made in you know where. Fuses are dependable. Always have an extra fuse.
Dirt Duff replied to Dirt Duff's topic in Mechanical & Technical Tips
Always comforting to know that I am not the only owner with a wobbly spare tire. I go with either the Home Depot and Rockler pads. Thanks 🙂 -
Bob, if you also feel this way, then you do not need to do all the following work (quoted below). They possibly have an LP-only model that could cost less too!
YES! YES! Yes.... This is a good switch. We had the Aquago from new in 2016. Nothing but trouble and large repair bills. Switched to the Suburban and never looked back. Service available just about anywhere. It just works. I never use the electric heat, always propane. Heats up reasonably quick. The only negative is that it will take up quite a bit more room under the bunk, so locating and throwing the cutoff valve takes a bit more work. Did I mention that YES!.... I think you should do this? Good Luck Scotty
Bob, I haven't heard of anybody going this direction, but why not? It's usually moving from the 6-gal Suburban to an on-demand/tankless model. Given your experience and reading many other posts re the Aquago model, I would not want one and I agree that I would certainly replace yours asap with something else. As you know, this model is not reliable, and my understanding is anything Truma is not serviceable! This is based on their policy of "authorized service" only. They work OEM installations only, no aftermarket sales, hence NOT serviceable except in waiting forever for OTT or Truma to service months later. Those who DIY cannot even purchase repair/replacement parts, so certainly Truma products are not for me! Rob @routlaw very recently removed a Suburban for a Fogatti tankless. He could chime in on his reasons. I would also read some blogs on tank vs. tankless to fully understand the pros and cons. Lastly, I and others with 2015-16 models, hull #s up to 150, have run the Suburban 6-gal HWH for 10+ years. This includes @topgun2, @Mike and Carol, @rideandfly, @ScottyGS, @Wayfinder and others. I would say this defines Reliability. Others can chime in on Serviceability but in 3 years of ownership, all I have done is drain it, rinse the tank annually, did the vinegar treatment once (on all plumbing). Purchased 2 anodes, installed a new one and have another for backup. I've read something about blowing the dust out of the burn chamber, but I've not experienced any real service needs which speaks again to reliability! You'll always carry 6 gallons in the tank that can't be used. I really like the option to run on propane or electric. Use electric when plugged in and it runs quieter than hearing the LP burning. I often run it on electric when towing to a campsite, powered by our inverter of course, and the +40A we get from our DC-DC charger makes it a breakeven in power, arriving at the campsite with 6-gal hot water (unless we instead run the A/C, weather depending). LP tanks always OFF when towing. There is an AC switch under the cover that is awkward to get to, so we always leave that switch ON and turn electric ON/OFF using the circuit breaker inside. There is a separate switch to fire it up by LP. For this model feature you'll have to run new 10-12 (?) AWG 120VAC wiring and add a breaker in the 120VAC power panel. You'll also need an LP ON/OFF control switch if your tankless model does not have one. That's my take. Hope it helps! 😎
This just came up in another thread, but in their case it was one of the breakers you already found under the bed, so we can rule that out. Since the last thing you changed was charging the batteries, let's start there. How are you charging the batteries? Did you plug your shore power cord into the Bluetti and now the trailer's built-in converter (Xantrex) is charging the batteries? Or did you connect in some other way? Also, to start from basics, are both of your Lithionics batteries currently (no pun intended) turned on (blue light glowing around the power buttons)? Is EVERY DC item dead? All lights? Bathroom fan? USB outlets? Tongue jack?
Will Fuller joined the community
I checked both of these fuse/ breakers and neither one is tripped. They are located on the street side under the bed.
Gliddenwoods started following No DC power!
My 2021 E2 has an OptiFuse 12V 60A breaker under the street side bunk. The best wiring diagram I have found that’s close to my model is the 2019 manual (page 43) from the Oliver University. See the breaker in the upper left side. Another quick check is the CO monitor under the dinette. That usually is always on, does not go through the circuit breaker. If that has a light on, you have power coming in, so it is likely the breaker.
Hokieman replied to Dirt Duff's topic in Mechanical & Technical Tips
Yes I put those on there. I got a roll of stick-on UHMW from Rockler. People put it on tablesaw fences. I did something similar but less elegant to keep my hull from getting scuffed. I used 4 plastic adhesive door stopper discs from Home Depot. -
Not to rehash any particular issues with the Truma on demand water heater that I have experienced, but I am considering replacing the Truma with the Suburban. My primary reasons would be reliability and serviceability. I don't ever want to be 800 miles from home with no hot water if I can help it. I know that there are no perfect solutions, but I want to reduce the likelihood of an outage. Based on some other threads here I see that some have chosen the suburban route, and been quite happy. The on demand is great when it works, but my experience has been less than satisfactory in the nearly 2 years of using it. Any thoughts on the wisdom of making that switch? Thanks!
I have no DC power. Can not find the problem/solution. Need advice. Battery charging with my Bluetti power bank was success. I used my "PowerWatchDog" at the Bluetti. I also used a "grounding plug" at the Bluetti. Works great and my batteries are charging very nicely. However (there always seems to be a "however") I have no DC power in the Oliver. All DC items are down! Is there a "Master DC Fuse/Breaker" somewhere? Or other advice as to a solution? (FYI. I started a conversation yesterday on how to charge with the Bluetti. Received good advice and it worked fine, however... I started this new thread as this is a related, but new topic.) Thanks much.
rideandfly replied to Dirt Duff's topic in Mechanical & Technical Tips
Yep, That sounds right, it's not likely the elastic locks nuts loosened clamping the plate to the fiberglass hull, but still check when the spare is removed. Good advice! -
Truma AquaGo, what's this tool on inside of door cover?
tallmandan replied to cowgs's topic in General Discussion
Hi Craig, That is the vent plug for use with the antifreeze kit. Here's a video that explains its use... -
Ok now I’m thinking that the second nut is a jam nut to hold the first nut on and both have backed off somehow. I would remove both nuts and see if the aluminum cylinder is threaded on that rod and check for something that might have loosened. Bill
