T-Oliver
Everything posted by T-Oliver
  1. In 2017 when we purchased Hull 254 I purchased these tools You have inspired me to figure out which bits I need from the kit Any suggestions for the size of the snap ring pliers
  2. If it’s any assistance these D52 axles were installed on my 2017 OEII hull 254 Yes they are NevRLube axles in
  3. I thought of that method, but I’d have to purchase lugs I’ll price it out The bussbar appealed to me, because I could over think the idea form the bar, tin the bar and then heat shrink The offset cable seems more practical
  4. Any advice on how to bend on offset into a copper bar to connect to the disconnect switch. Also is 10mm x 25mm cu overkill vs 6mm x 25mm cu The ampacity calculations are not clear to me
  5. Cover was removed to read the ANL fuse It’s certainly excellent advice to be aware of the potential hazards of grounding to the insulation
  6. I have a related question What size copper bar would I need to attach a negative disconnect
  7. I found this while poking around my 2017 under the dinette seat It’s on the positive cable
  8. Shore power and water heater shows, no A/C on screen. A/C works with remote. Data cable ? Hard reset ?
  9. This is how then tech’s mounted mine
  10. An example of disc brakes on an Oliver D52 NevRLube axles, 5000lb springs 12 in discs with 4 piston calipers Electric over hydraulic actuation
  11. 2017 Oliver While staring at the wiring around the charge controller (trying to make sense of it). I noticed this, after 7 years… No wonder the hose on the outside shower seemed less than useful.
  12. Prime the boondocking port with garden hose, then try again.
  13. The temperature sensor is scheduled for removal, as the BMS tells temperature. The weather has been unpredictable this year (50s followed by 20 below zero. The BMS does shut down in the cold, the batteries clicked off just as we got home from Florida.
  14. All buttoned up, with the exception of the temperature sensing wire. I got rid of all the split loom in battery compartment. The Blue Sky Solar seems to remember it's settings, making it a good day!
  15. It's a lovely day in Minnesota, so I decided to reintall the Epoch batteries. This is the wire arrangement that I came up with. What could be improved or what is absolultly wrong?
  16. Very clean looking ! what happened to all the 6 ga wires in the original battery picture ? I am trying to figure out how to disappear them on 2017 Hull 254
  17. On my list, closed until January 2nd
  18. Thanks for the assistance and information. The Epoch batteries (2x300AH) are installed with a new PD charging module utilizing 2017 Oliver wiring (20 degrees and snow) The batteries are fully charged, sofar so good. Now if I could only get the Blue Sky programing menus to behave
  19. Thank you for the information and advice. I recieved the charging module today, used like new Not! Used part in a plastic bag no intructions, I will try again. Waiting for the Epoch batteries to ship from Off Grid.
  20. I haved admired everyone's upgrade projects Could the process br as simple as: Swap the PD charging module Swap the AGM for lithium Reprogram Blue Sky charge controller 2017 Elite II Hull 254
  21. High falls at Grand Portage State Park Grand Marais harbor
  22. Have you checked to see if the outlet is wired properly ? Open ground,open neutral will cause a surge protector fits (If so equiped)
  23. Jack the trailer until the wheels are off the ground. The zerks should then take grease. there is a more comprehensive thread in the forums dealing with this.
