Nan
Everything posted by Nan
  1. Hey Mike and Carol,  one more question:  Are the valves under the bed in the same position no matter if you put the solution in the boon dock port or the two side ports?  I know I am a pain, but want to do this right.  Thanks again.
  2. Would love to visit, but am a little afraid to travel that far by myself, well with the dogs, but they are not much help.
  3. I am grateful that I know Jesus and He has lead me to Kairos Prison Ministry. I have been serving in Kairos for about 40 years now.
  4. I am going to look at that one too! My dehumidifier bit the dust and I need to get another..I live near Savannah, Ga. and the dehumidifier is a must!
  5. After having the ceramic coating on the trail done, how do you stick the rain diverters over the windows. My grandson used mineral spirits to the the area, but the things just fell off on the ground. Please tell me what to do. Thank you all.
  6. Thanks so much. Wonder why the fuse didn't blow?? And why would the relay burn up after running the AC this summer??
  7. Oh and I forget to say that the thermistor was re-routed to the inside of the camper..actually it is right beside of TV wires. I ran the AC on the last camping trip and it worked great that that.
  8. Thanks for the e-mail. Yes, Houghton designed their AC without giving a thought to humidity in the South of the US.
  9. Can anyone help me?
  10. I bought a Houghton air conditioner. But the air blower would not cut off when the compressor cut off. So, grandson installed a relay to make that happen. I used the AC one time and all was well, but this camping trip the compressor would not come on (just the fan). I had a local camper repair man come and he said the relay is burned up. I have another relay, but do not want to install it without knowing why the first relay failed. Has anyone had this happen?? Thanks so much!
  11. Is there any way to combine the black tank with the grey tank? I have a composting toilet and could really use the extra storage the black tank could provide. Thank you.
  12. Just read your post! Thank you so much for the information John!!!
  13. Sherry, the water heater works fine..it is the refrigerator that was not working on gas, but working on 30 amp. I am going to try turning on the stove the next time I am over at the camper and then see if the refrigerator will fire off.
  14. Just saw your post, sherry. No error codes. I do not think I have any place for error codes on my fridge. The HW tank worked great while camping. I did notice when I turned on the tank the gauge showed red and green at the same time..this happened on both tanks. I will try the stove and see if it lights. Thanks.
  15. I had both gas valves open (one at a time). Maybe I have a problem with the regulator or the gas lines themselves. Now that I am back, I will pull the big cover and try to check it out. Thank you so much for responding to my question.
  16. OK, I just got back from North Carolina camping where the refrigerator worked just fine because it was plugged into 30 amp. So, the story is that it does not work on Gas..I hear a clicking noise, but that is it...what should I look for? Thanks.
  17. Thanks, I have waited since last night for the refrigerator to cool and until about 2:00 this afternoon..I then switched it over to DC and again the freezer is getting cold and maybe the fridge is a little cooler (however I put 6 frozen bottles of water in fridge..so that may be why it is cooler). I am leaving for Apex, NC in the morning and refuse to cancel because of the problem. The temp in Savannah, Ga. is about 100 degrees (with the heat index) just about everyday and the camper is parked at the end of the drive way in the sun. Thanks. And, I am going to ask Grandson to change out the fan and replace it with two when I get back.
  18. Thanks, I just put in a call for the Oliver service dept.
  19. Just looked at it again and the freezer is working just fine, but the refrigerator is not cooling at all. Thanks, Nan Hull 267
  20. Please help me one more time. I believe the cooling fan for the refrigerator is not working. Can someone please tell me where it is located and maybe a part number to order it? Thanks again, Nan Wallace 2017 Hull 267
  21. Thank you so much for the information!!!
  22. Thanks! Someone looked at the camper today and asked me why I do not have a cover for the wheel bearings that has a grease fitting on it so that you could grease the bearings without taking anything apart. That is why I was asking on this forum. Have you ever heard of such a thing and would it work??
  23. OK, did not have the gas tank turned on...😚 But still do not know if the bearings are sealed or not. Thanks again.
  24. I have two questions please: 1). Are my bearings sealed? 2). Refrigerator: if the Auto and Gas lights and the number 5 are lit and I have plenty of gas, why is the refrigerator not cooling? Thanks so much for the information. Nan Wallace Hull #267
  25. I bought my mattresses from Southern Mattress. Very comfortable. Now about the sheets...yes, you can buy them that have the curved edges, but after killing my self changing them every few days, I decided life was too short. So, I just lay a sheet over the bedspread and call it a day. If you will privately e-mail me your address, I will send you two sets of sheets. My e-mail address is: Walliered@aol.com Blessings.
