NCeagle last won the day on March 30 2021
NCeagle had the most liked content!
688
2020
3,888 profile views
NCeagle's Achievements
Hi Nan, I made this modification (added a relay to the Houghton) over a year ago and have used the unit to both heat and cool multiple times without issue since. I used this relay: https://www.amazon.com/gp/product/B07587NZTC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 If you are sure that a properly sized relay was wired in correctly replacing it with another and testing it in a controlled environment is what I'd do. The fact that it was working correctly for some time is a good sign, but to double check the installation, either google for the instructions (I did) or there was a long forum thread on this subject with discussions and instructions (last summer I believe). I didn't relocate my thermistor as you did. I'd love to hear more about how that's working once you get your unit running again. I currently use a small fan on the nightstand that I point up at the Houghton so the thermistor gets some airflow from below when the compressor and fan are both off. This modification has definitely solved the humidity problems the Houghton created with its design at the expense of having to have that small fan on the nightstand running when the Houghton is running. Good tradeoff for me but I'd certainly prefer having the thermistor in the cabin. Best of luck! John
MAX Burner started following NCeagle
@rich.dev, I went with the AC fans because I couldn't find anything comparable (smart/quiet) that were DC. These fans actually have EC motors, so even though they run on 120V AC, the motors are actually brushless DC so very efficient. I'm very happy with both the designs and results for both of my smart fans, so no, I wouldn't change anything unless they came out with DC only fans - even then, I'd wait for mine to break before replacing them. They run non-stop and haven't had any issues for 2.5 years now.
Relocate the furnace inlet grill and block off that opening?
NCeagle replied to John E Davies's topic in Ollie Modifications
I haven't ever seen anything like that in our 2020 Oliver and I have always had 9 temp sensors located throughout the trailer. I took some "baseline" temps all around the trailer in 2020 before I made some HVAC changes and I was seeing temps under the curbside bed in the low 60's when it was in the 20's outside and the inside temp was set at 70. I still have the data / graphs. It seems to me like something "abnormal" is causing an excessive heat buildup under your curbside bed when your heat is running. Maybe one of your ducts has a hole in it and it's pushing the hot air right at your temp sensor? -
I can't figure out an "easy" way to even get at that thermistor from the underside. I can see it but it's protected in a "cage" that looks like it would require some disassembly to remove. I like the routing path idea for a longer wired thermistor! Maybe the original idea of replacing the current thermistor with another that has a long wire. Would still have to figure out how to get through/under the Styrofoam insulation, but we could leave the original thermistor in place (disconnected at the control box) as a backup.
I made the change to the Houghton with the relay to keep the fan from running when the compressor is off. It has made a world of difference with the humidity and dew point overall. As expected, the temperature difference between the temperature set on the Houghton and the actual cabin temperature increased significantly. A solution I have found is to point a small fan up towards the Houghton so the thermistor gets better temp readings from the cabin when the compressor and internal fan are off. In a nutshell it works fantastic - we keep a fan on our nightstand running anyhow so pointing it up a bit was no problem. I'm interested in moving the thermistor as well as a long term solution, but it does seem risky to completely disassemble the Houghton and install a new thermistor that may or may not work as we expect. I'm waiting for one of you brave souls to try this before I do! 🙂
Yep. I don't know about everyone else, but the grey water rules are confusing because it seems legal to create grey water in any manner as long as you don't collect it. It's certainly ok to pee outside in the wilderness - but don't dare spill any pee out of your bucket on the way to the restroom... and sure - it seems many folks set up an outdoor shower and wash off your body and/or dog and/or dishes - but don't let any of that same type water run out of your grey tank or you will be fined and kicked out of the US if caught. We've been spending extra on biodegradable soap for everything in our Ollie, but it seems a waste of money given the rules. If I'm close enough to home I just bring my grey water home and water my plants with it. They are all very healthy. 🙂
My "ghost" draw is around 1.7 amps (refrigerator, radio, CO detector, Natures Head fan, ...), so about 40 amp hours per day (10% of my Lithium capacity). I also don't want to turn everything off for storage and I don't want to keep my Lithiums at 100% or even 90% while sitting in my storage garage, so in this scenario I set my Xantrex to "float" my Lithiums at 13.2v which is about 50% SoC. What eventually happens is the battery settles to "standby" with net zero current at 13.2v and the Xantrex uses only the power necessary to keep the batteries at 13.2v - thus passing enough power through the battery to satisfy whatever battery draw is present.
@Brian and Brandelyne, you are probably aware of the fact that Lithiums don't like to be kept at 99%-100% all the time like AGMs. You may be talking about your battery charge during camping (I keep mine full during camping trips) - not sure if you are keeping them fully charged even when you are not camping, but just in case I thought I'd mention it. Very cool device to assist your MPPT charger! Thanks for sharing!
A quick question on using shore power and air conditioning
NCeagle replied to Steve Morris's topic in General Discussion
Yes the Xantrex should charge the batteries from 15A of shore power as long as there are "extra" amps around for the inverter to use. It looks like you have checked for other loads on the battery and you have none since your EMS is showing 1 or 2 amps and good (125) voltage. There is another setting many of us use to turn off the charger when we don't want or need charging - it's setting #26 (charger ignition control). If #26 is set to OFF the charger will work and charge the batteries. If #26 is set to ON it will not charge the batteries. So, make sure the setting #26 is set to OFF on your inverter. One other quick check comes to mind... make sure the connections to your batteries are tight. If the ground is loose some things may work and others may not. This is a long shot given your symptoms but maybe worth a quick check as well. Good luck and keep us posted! -
Prime deals on Battleborn and Renogy suitcase solar
NCeagle replied to SeaDawg's topic in General Discussion
I mentioned in this thread that I use some of the off-brand cheaper lithiums for things other than the main battery compartment in our Ollie. I have found that most of these "compact" off brand lithiums use pouch cell technology rather than using metal casing for the cells. Pouch cells are great/ok if the battery manufacturer takes special precautions during design / engineering. Long story short, the pouches are prone to expansion from outgassing, and other external factors (temp, humidity, etc.) can affect their longevity more so than the encased cells. All of this must be accounted for during battery design. I don't trust that these Chinese battery manufacturers actually know or care about the risk mitigation required for certain types of lithium cells. -
No - the temp setting is not very accurate for me either - I have the 9500 Houghton with a Sensorpush in the cabin and it definitely shuts off the compressor and starts cycling about 2-3 degrees above the set temp on the Houghton. I pretty much just ignore the temp setting on the Houghton and use the Sensorpush and/or my skin to guide my Houghton adjustments. The Houghton does continue to slowly cool the cabin while cycling until it's pretty close to the set temp, but it takes hours to reach the setting (if it ever does) depending on the outside temp, etc. I often just set the Houghton on 60F and let it blast away until it reaches the temp I want and then I'll back it off and let it cycle and tweak it from there. Overall, no big deal for me - I've learned the nuances and I love the Houghton. I've still got my thermostat in the default place up in the plenum. I've been thinking of extending it into the cabin but it seems it may not be helping with the temperature differential at least. Do you feel it cycles less or about the same with the thermostat extended into the cabin?
I have had a pair of the AmpereTime 100Ah batteries for over a year now and I've used them for "extra" battery capacity. I do not use them inside of my Ollie, but I do put them outside and use them with a DC to DC charger that's installed inside to add time/life to my on-board lithium batteries - especially boon docking at night during quiet times when I want to run my A/C without the generator. I also use one of them in my small bass fishing boat to run my trolling motor. So much better than the heavier AGMs! The BMS seems to be working well as I've drained them to 0% quite often - no problem charging them back up to 100% and using them again so far. It's only been a year - and in lithium battery life that's not much but so far so good. But...in my opinion - not sophisticated or time tested enough to put in my Ollie battery tray. -
Super Secret Safety System for the Girard Awning?
Our Girard awning retracted every time I locked my previous truck with the key fob. It took some time to figure that out and I thought the awning was possessed for a while. 🙂 We have a new truck now and it doesn't do it anymore. It wasn't a feature - it was a nuisance - that I didn't research or fix because we got the new truck soon after I discovered what it was and it went away. Almost certainly had something to do with the frequency of the key fob... -
Battery compartment door lock replacement
NCeagle replied to StillGame's topic in Ollie Modifications
It's http (not https), so that's not great security - wise. I set up an account on uglyfish 3 years ago and it's still there. Seems like a legit site but who knows. I've never actually tried to order anything else though, so will definitely keep a close eye on this - and I'm not going to hold my breath. 🙂 Thanks! -
I tracked down an older post and some notes I had made on this when I was shopping for a more secure replacement latch in 2020. I remember trying to order the latch on Southco and the only option was "request a quote" - which I did and never heard back. Just checked again and it's still the same message: https://southco.com/en_us_int/m1-20-91-78. I also had found this site that offered Southco latches that also led to a dead end in 2020: http://www.uglyfishinc.com/southco-m1-deck-hatch-marine-enclosure-latches-p/m1-2x-xx-x8.htm. I just tried it again and ended up with a locking compression latch with part number M1-20-91-78 (as @rich.devcorrectly identified earlier). I was able to place an order for a pair of them so I'll see what happens and update this thread if I hear back or actually get the latches. The price is $64 for the compression latch and $20 extra or the lock/key ($84 total for each latch). Maybe it will work this time because 2020 was challenging for everyone and all businesses to say the least.
