MobileJoy
MobileJoy last won the day on September 20 2023
MobileJoy had the most liked content!
1 Follower
    850
MobileJoy's Achievements
Collaborator
Collaborator (7/14)
293
  1. See Truma Aventa Observations for my review of the Aventa with CP Plus panel. We do use it because we can counter the meat locker effect with the non-Truma (Dometic I think) heating system which can be run simultaneously. I do not know if the Truma heater can do this.
  2. Regarding price.... We just had 5200 lbs Nev-R-Lube axles and 5-leaf springs installed by ALCAN. Total price was $3,928.28, and that included $141.99 in convenience fee for using a credit card (3.75%). They only accept the equivalent of wire transfers to avoid the convenience fee. They do not accept checks (I didn't ask about cash). Regarding the functionality... Larger brakes did not cause me to reduce the brake controller gain on my OEM controller (2020 F250). I had to increase it initially, but as the brakes adjusted I decreased it back to roughly where it was initially (+5). Braking is MUCH better. The first two tows were 50 miles each, and ALCAN re-torqued the U-bolts each time. Both times the TV had come down, but nothing else was disturbed. We then towed about 237 miles and then 170 miles, and the TV has not come down again. I usually use the stabilizer jacks to take out less than 2" of height on the low side for leveling. When I first tried to take out 1.75", the wheels lifted off the ground. I had to use the Andersen leveling wedges, and found that anything more than 1/2" would cause the wheels to lift off the ground. As we relocated, this improved somewhat, and Tanner said it would improve more as the springs break in. I expect it will be even better riding when I get new shocks. Two of them were blown, and one of these was broken as well. ALCAN fixed it up the best they could, and we ordered Monroe shocks to replace all four. I would have ordered the Bulldog shocks, but the stories on availability had me concerned in the timeframe in which I needed them. They will be installed this coming Monday.
  3. I had mine replaced last year when I went to the mothership for regular service. This is what I purchased. I had Oliver do the mounting since I was there anyway because I'm not super comfortable with drilling and screwing into fiberglass. They have a central mechanical button that is part of the cover. They are dimmable, have 3000K/4000K/5000K (selectable at purchase) temperature, and they have a blue mode for night lighting. When installing, the screw holes must be drilled perpendicular to the surface, or the cover mounting will not be perfectly flat, in which case the switch button will not reliably make proper contact with the switch itself. I did have to repair the screw installation since the Oliver tech didn't know this (neither did I), but now all five of them work properly first time every time. They're cheap enough that I bought a spare set, but their life is very long so a replacement will probably not be required during my time with the trailer.
  4. Site: F20 Handle: MobileJoy Names: Mike & Sue State: NC Trailer Name: Mojo Hull #: 850
  5. The age thing is definitely overrated... We had ours done 18 months ago. We used to wax, but after a long trip cleaning the Mojo took considerable elbow grease. We returned from a long trip in 10/24 and the Mojo hadn't been washed in over 2 months. It cleaned up easily. Black drip stains wiped away with almost no effort. Even bugs were easier to remove. It looks better than new. So I'd say it is definitely worth the money given the cleaning and waxing time saved, and the appearance of the cleaned fiberglass. Ours is garaged and we use RockTamers. Ditto!
  6. We took the Sam Houston Tollway which is a toll road around Houston. Very nice road, but the signage was unfriendly unless you have the Harris County Toll Road Authority pass. The signage says they only accept that and if you don't have one you are a "violator". I found that if you go online you can pay the toll without any issue. Sorry, I don't remember the site link, but I do remember that a search for my trailer NC plate on the site showed the violation and let me pay. For our journey the toll was $12.
  7. One of my uses is to condition the Lithionics batteries per instructions. They need to be fully discharged and recharged at least once every six months. Using the Dometic Penguin with soft-start that I used to have, I was able to do this, but not with the Truma. Now I have to use the fridge in DC mode, which is inconvenient when the trailer is winterized and garaged. The Truma has a dehumidify mode which maximally runs the compressor, seemingly regardless of the temperature. Other than that, we run the AC at highway rest stops when we're having lunch, and occasionally for short periods when boondocking as you do. We don't necessarily have a full charge in either case.
  8. I'm not really sure of this... I have one without soft-start and Lithium Pro. I've found that when running AC, the batteries reach Low Battery Cut-Off long before the charge level reaches the NeverDie threshold. When I turn the batteries back on, they show much more charge than 10% (I've seen 50%). I suspect the start-up surge current can fool the batteries BMS into believing the charge has dropped to LBCO. At high charge levels, the batteries will start up the Truma. If I run only the Norcold fridge on DC, the batteries don't cut off early.
  9. I received the following from my storage facility today: Dear Tenants, We hope everyone is doing well and enjoying the holiday season!! We are writing to let you know that we will be adding a line item to the lease regarding Lithium batteries and storage as many insurance companies are starting to NOT cover damage due to fires caused by lithium batteries. Per the previous, the following verbiage is being added to all current leases: "From hence forth, lithium batteries are strictly prohibitid from storage and or charging without express written consent from Landlord. Tenant will be liable for any damages resulting from charging any type of batteries" If you have any questions please do not hesitate to call. I haven't yet called. Has anyone received such a notification or have any info regarding this?
  10. Oliver's winterization video shows hand-pumping (four strokes) antifreeze into the fresh water line (LEII). How does one avoid putting this antifreeze into the fresh water tank? Because of this, I ultimately flush the fresh water tank at least 3 times before filling it. Thanks for this tip. I will do this from now on.
  11. Look at your circuit panel description in the (2024) Elite 1 manual. Note that circuit #1 of the main panel is the air conditioner. This is shown in the diagram (below) that uses the Xantrex 2000w inverter. This means the air conditioner is powered directly from the AC source. If you have the optional front AC input for a generator, connecting it to the input will feed to a transfer switch which will determine the power source (front input in this case) to route to the EMS. The EMS will verify the input power is safe and route the AC to the main circuit panel. So, in the Elite I generator case, the inverter should not be in the circuit path to the air conditioner. I think a 3000w inverter is essential to power an air conditioner.
  12. There is Peach Country RV Park in Stonewall TX. We stayed there for the eclipse. It's $55/night. Full hookups. Good Sam, military discounts. Roughly 6 miles from Fredericksburg.
  13. Very clever @Snackchaser! Nicely done.
  14. If it's only your morning coffee, consider boiling water on your propane stove and using a pour-over. If you also need to grind beans, there are hand-powered grinders available. Check out https://www.hario-usa.com/collections. I have a 3000W Xantrex, solar and lithium, and I use a Hario pour-over for coffee.
  15. The Lithionics 130Ah batteries have a built-in battery management system with Bluetooth capability, plus they provide an app that can be used to monitor the individual batteries. You can see the state of charge as a percentage (Lithionics recommends against using this number alone), or you can look at each battery's voltage. I have found this to be adequate regarding battery monitoring. I have no experience with the SmartShunt, so could someone who has installed one with the Lithionics batteries please chime in here? I am also unfamiliar with Battleborn's management system, so perhaps Geronimo John could describe his reasoning for the shunt. The Lithionics batteries can be individually shut off. Can you say why you chose to leave them on? The solar panels can also be shut off.
