RoadKingsofGA
RoadKingsofGA last won the day on July 5 2022
RoadKingsofGA had the most liked content!
    550
    2019
2,346 profile views
RoadKingsofGA's Achievements
Contributor
Contributor (5/14)
46
  1. Ours has done this and we can recreate the issue, which is the door pressed into the black back stop puck. Even when using the door hook, constant wind pressure against that back stop has caused ours to crack on the inside, where the inset is hard and susceptible to cracking when under flex/pressure. Stand and push your door into the puck and you can see it flex. Thus when opening the door, if the wind grabs it causing good whack against the back stop, then the cracking begins. We bought our trailer used, and the door never closed smoothly or easily. There was a dent on the inside of the door, but we didn’t think that affected function. Turns out, that dent was probably something hard enough to bend the door frame and then, even when latched, there was play in the door allowing flex on the back stop, so here we are. We are ordering a new door from Oliver and having it installed. 2019 E2 hull #550
  2. Thanks! I re-read my post and it could use some editorial corrections! We can't take credit for the bike rack mount. It was put on by the previous owner to solve the issue of needing a 2" receiver. It's certainly stable as it's well bolted! I can add pictures of that if you would like. I believe it had it custom fabricated and painted or powder coated. We added O-ring screws at the corners to allow us to tie down gas cans when we carry them.
  3. The links don’t go to anything anymore.
  4. I wanted to see if you are still happy with this box since install? We need one to contain set-up stuff only as we keep our larger generator in the truck bed.
  5. True, we could put a long chain out to the dish stand and put a lock thru the foot of it, should we have to place it far away. But even then, a thief who wants it can cut the chain. Would be a hassle for us to then acquire another, but the bad karma the thief gets is worse. We had heard of others removing the rubber piece, but hadn’t heard of drilling holes in the awning mounts! It’s a real pain keeping that area clean and free of debris. I will have to read on forums about this. Like do we have to remove the awning and what is risk of drilling into the fiberglass if the drill bit slips.
  6. We liked the idea of mounting the Starlink bracket to the roof as we already owned the short mount from when we mounted it to the fascia board of our house. Mounting to the awning where easy and quick access to install the dish at each campground was our priority. But our 2019 Oliver has a Dometic awning whose bolt pattern is diagonal and the Starlink mounts bolt pattern is vertical. Our solution was to select a 2” wide piece of 4’ stock aluminum at Lowe’s, cut 2 pieces for strength, and drill holes on one end to match Starlink mount and the other end to match the Dometic awning. 1. We began by measuring the clearance needed for the dish to clear the awning when the dish is in stow mode, and length for the drilling of holes on both end. For our application, that length was ? We also ensured the trailer was level before starting. 2. Next we used cardboard to make a template to cut and drill the hole patterns. I am sure others may find a better way to do this, but we put dark powder on the bolts and then pressed the cardboard to them using a level on the cardboard to ensure it was straight. (We also visually assessed that it appeared perpendicular to the awning). We then pre drilled the holes in the cardboard and did a test run. NOTE: it took us at least 3 cardboard attempts before we got it right! 3. Now we transferred the template to the metal pieces. We actually drilled the awning pattern on one end of the 4’ aluminum piece before we cut the short lengths. This was in case we messed up, we would only lose a short 2” piece rather than our planned 8” lengths. We mounted the long piece to the awning, but the upper hole was slightly off, so we had to wallow that hole slightly larger, but that did not impact securing it. We cut our length and drilled the Starlink holes. We repeated this process for the second piece. 4. We purchased stainless steel bolts, washers and lock nuts for the Starlink end. So we stacked the 2 aluminum plates and installed. The direction we chose for the Starlink mount was to make it easier to see and plug in the router cable to the dish when we put it up there. NOTE: the awning bolts had been cutoff and threads were damaged so the nuts wouldn’t come off easily on the rear awning bolt set. Thus we had to use the set forward of those. 5. We have traveled at 65mph and it doesn’t seem to move and remains secure. 6. Like others, we bring the 4 legged dish mount/anchor and use it if we are under trees and need to move the dish 50’ away from the camper. We aren’t concerned about theft of the dish as it cannot be used by anyone else. Each dish is specific to the owner’s account. For interest, I am including a picture of our Husky storage box and how we pack it. We use a Cord-Pro to wrangle the 75’ router cord to prevent tangling. I also notched a Tupperware to protect the cord plug end that goes in the dish. It can be delicate and damaged easily. 7. We current put the cord thru the basement door and plug into the router via the trap door at the bottom of the bedside table (we have twins. The basement door has a notch in the rubber seal where the cord fits and allows us to close and lock the door without pinching the cord. Eventually we plan to convert the satellite port. Please ask questions, we would be happy to answer.
  7. Well, I was so inspired by your video, I went right out this morning to clean ours. I gathered my wand sprayer, flathead screw driver, rags, pip cleaners, etc. I first pulled the white rubber gasket, then found the cut place of the black track and began to pry it up...lots of cracking and tearing sounds. I could barely raise it a bit. I pulled out past the furry inset. So we stopped and forced it back down. It seems very brittle and is tearing up rather than pulling out. This is the second time we've tried this. Same results. I'll just keep the dirty window tracks. :)
  8. I follow Escape pages and I like mods done by Johnny Hung. He made a few with solar panels that slide out from back and both sides. Not only do they provide more solar power, but they act as exterior shades over the windows.
  9. Thanks Frank! I am glad to hear this! Our white seals have shrunk (2019 E2 #550) and after reading about them on the forums and FB, I have an order prepared with Pelland and before I hit enter, I wanted to find out if streaking was an issue or not. Soe responses were confusing as contributors indicated Oliver switched to white due to streaking, others said that was not true. I will assume streaking is not to be an issue. Next summer I will tackle gutters (when it's warmer).
  10. Of those who switched from white to black, have you had any issues with streaking?
  11. I was glad to find this post as we want a foam mattress but having trouble finding one we can cut without it containing loose fiberglass which will fly everywhere! I began searching online and found that Sam's Club sells these for $449 Queen. Can't wait to try this! Thank you!
  12. Did you add a battery cut off switch or did it come on it?
  13. Always growing and improving! I think they are about to complete a new STEM building behind the IT area where I worked. It’s a beautiful campus. Now if you are asking how the Dawgs are looking for the upcoming season, we’ll, that’s out of my area of knowledge. 😁
  14. Thank you! Home base is Athens, GA
