Tom and Doreen
2 Followers
    1321
    2023
Tom and Doreen's Achievements
Rising Star
Rising Star (9/14)
452
  1. Great episode, Steve!
  2. Additionally you may want to consider replacing your valve stems to the metal variety as opposed to rubber. Rubber ones can fail when sensors are attached.
  3. If you’re referring to the little device that relays the sensor signals I installed mine in the front jack housing, there is power in there and room for the module. I repurposed the switch that controls the jack light so that I can turn the module power on and off.
  4. I believe the temperature sensor is mounted just below the controls.
  5. My ‘23 Tundra is on the recall list but I’m one of the lucky ones ( so far ) with 60k miles, 30k of which pulling our Oliver and no failure as yet. I’ve heard that they’re starting to address the ‘23s in my area soon. I have done frequent oil changes right from the start, hard to know if that made a difference.
  6. The Progressive industries EMS that Oliver supplies does check for an open ground, Error #2 as does the Watchdog; We use both devices.
  7. The museum is awesome. You can boondock there for free, the area is nice. If you want an electric hook-up they charge $40 which includes water but when we were there the hydrants were labeled “non potable”. There is also a dump site there. The Truma service center is close by if you need anything from them.
  8. Like @jd1923 said, take measurements around this circuit breaker, input vs output . These have been known to fail. As John said you should measure 12V on each side with respect to ground.
  9. Someone had recommended this one, High Sierra.
  10. Yes, mine did. It worked pretty well (without the repeater) but there were times when I would loose contact with one tire sensor for a period of time. Once I installed the repeater I’ve had no sensor drop-outs.
  11. If you're looking for a convenient place to hook up your TST repeater there is ample space within the front jack head. +12V power is available and you can utilize the existing power switch currently used for the lamp or add an additional switch if you choose to.
  12. Yes, I have a GearWrench torque wrench, 250 ft//lb that we travel with. We were VERY lucky because we had been on the highway heading out to Yellowstone and had just pulled off to get groceries when the tire stem blew out most likely from the "waggle" affect of the TST sensor. We changed the tire in the parking lot then found a Discount Tire location near where we were and had the stems replaced on all tires including the spare.
  13. 1) Using the stabilizer jack is very helpful 2) Change valve stems to the metal type especially if you have TST sensors 3) Invest in an electric impact wrench 4) A locking bottle type jack comes in handy 5) Tire plugs and a compressor can come in handy in a pinch.
  14. Same here. I haven't found anything better than the Calmark cover for all season protection.
  15. We've had two RVLocks fail, on the first one a circuit board failed, the second one had a mechanical failure which we were advised (by the manufacturer) to loosen the internal screws that held a metal plate in place; I don't have a lot of confidence in the second fix but it seems to be working for now. Lot's of people seem to have this lock and are happy with it though.
