johnwen Posted April 24, 2024 Posted April 24, 2024 5 hours ago, StillGame said: Does anyone use a sensor on the spare? Yep... 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Geronimo John Posted April 25, 2024 Posted April 25, 2024 (edited) On 4/24/2024 at 9:44 AM, johnwen said: Does anyone use a sensor on the spare? Nope. Most TP sensor systems are designed so that when the tire is sitting, the sensor shuts off. So you'll never know if it gets flat. Yep they do work on the spares. Researched and then called the MFG and they confirmed my faulty memory. The transmitter sends a milli-second burst of the ID number, pressure and temperature data when ever there is air pressure from the tire to the monitor. So long as the sensor has a good battery AND it is not shielded from the monitor (Such as under the vehicle was for my Toyota Sequoia and possibly my F-150).... it is sending that data. For my Sequoia the tire sensor was shielded well and did not work. I'll be re-installing the sensors on my spares this summer! GJ Edited April 26, 2024 by Geronimo John Senior Moment OOPs Bad Response! TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
dewdev Posted April 25, 2024 Posted April 25, 2024 (edited) I thought that when the Ollie starts moving the controls will sense the movement and run a diagnostic check of all sensors. Since I have not installed my extra sensor on the spare at this point, I am only guessing that the spare will the checked? UPDATE @Geronimo John: I googled if a spare tire with a sensor on it would register the tire pressure in the spare and the answer in a number of google answers was that it would register. Can anyone that has a sensor on their spare confirm this? Sorry to change the path of this post, but I wanted to clarify this. Edited April 25, 2024 by dewdev 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
johnwen Posted April 25, 2024 Posted April 25, 2024 4 hours ago, Geronimo John said: Nope. Most TP sensor systems are designed so that when the tire is sitting, the sensor shuts off. So you'll never know if it gets flat. Thanks...good to know. Mine shows different pressures and temperatures from day to day (for the spare), so I'm hoping it isn't a bogus reading. Next time I have the cover off I'll compare the readout with a gauge. My sensor is external and on the stem. John 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators topgun2 Posted April 25, 2024 Moderators Posted April 25, 2024 I have the EEZTire TPMS and both the spare tire on the Ollie and on my F-150 DO register with this system for both pressure and temperature. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
johnwen Posted April 25, 2024 Posted April 25, 2024 3 minutes ago, topgun2 said: I have the EEZTire TPMS and both the spare tire on the Ollie and on my F-150 DO register with this system for both pressure and temperature. Bill Mine is TST and I trust the readout for the spare...so far :) 2 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Geronimo John Posted April 26, 2024 Posted April 26, 2024 3 hours ago, topgun2 said: I have the EEZTire TPMS and both the spare tire on the Ollie and on my F-150 DO register with this system for both pressure and temperature. That's interesting. I'm running a 2018 EEZTire TPMS as well. I purchased six sensors plus a spare so i could monitor Ollie and 2 spare tires. I'll go find my info and advise why I pulled them off my spare tires. Will be good to know for sure. More to follow.... GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted April 26, 2024 Posted April 26, 2024 On 4/24/2024 at 9:09 AM, Ronbrink said: I take the sensor off the flat and use it on the spare. Rationale: The TST monitor is programmed to show the wheel position of each sensor as it scrolls around the Oliver, as well as the TV if equipped. If a spare also has a sensor and deployed, the monitor was still show that wheel at the TT/TV spare mount position. I would rather remove the sensor from the flat tire and place it on the spare as not to disrupt the scrolling sequence. Also, if I choose to keep the spare on the ground and use the repaired tire as the spare, I don’t have to bother myself with reprogramming the TST monitor. As a side note, I recommend traveling with a set of replacement batteries for the type sensors used. Usually when glitches in monitor readings occur it is due to a weak battery. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Steve and MA Posted April 26, 2024 Posted April 26, 2024 13 hours ago, johnwen said: Mine is TST and I trust the readout for the spare...so far 🙂 The TST monitor has icons for the spare for both the TV and trailer, so it's no surprise that the sensors work even if the tire isn't rolling. We've found the pressure and temperature of the rolling tires usually display on the monitor sooner than for the spare. 1 1 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
Geronimo John Posted April 26, 2024 Posted April 26, 2024 15 hours ago, Geronimo John said: I have the EEZTire TPMS and both the spare tire on the Ollie and on my F-150 DO register with this system for both pressure and temperature. Yep they do work on the spares. Researched and then called the MFG and they confirmed my faulty memory. Have re-written my above post accordingly. The transmitter sends a milli-second burst of the ID number, pressure and temperature data whenever there is air pressure from the tire to the monitor. It will be read on the monitor IF: It is within it's range Has a good battery AND it is not shielded from the monitor (Such as under the vehicle was for my Toyota Sequoia For my Sequoia the tire sensor was shielded well and did not work. I'll be re-installing the sensors on my spares this summer! GJ PS: For winter storage, recommend the Egg Carton storage suggestion with removal of the batteries from the sensors to protect from potential battery generated corrosion. 4 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
