Administrators JWalmsley Posted May 7, 2024 Administrators Posted May 7, 2024 Navigating through the forums and I cannot believe how much faster it is since the move to the new host. Anyone else notice? That's all. 🤓 2 3 Full Stack Developer/Marketing @ Oliver Companies Oliver Forums Guidelines & Rules
Moderators topgun2 Posted May 7, 2024 Moderators Posted May 7, 2024 You da man! My fingers can't type that fast! 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted May 8, 2024 Posted May 8, 2024 11 hours ago, JWalmsley said: Navigating through the forums and I cannot believe how much faster it is since the move to the new host. Anyone else notice? That's all. 🤓 Thank you for all you do! Speaking for the majority us, the new and old Oliver owners, we love this forum. Thank you again for your work and all you do! JD 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideandfly Posted May 8, 2024 Posted May 8, 2024 Between getting a new computer about the same time you started using a new host, this forum is lightning fast! Thanks! 2 2015 LE2 #75 / 2024 F-150/5.0L
MAX Burner Posted May 8, 2024 Posted May 8, 2024 1 hour ago, rideandfly said: this forum is lightning fast! We like fast... we do "lightning fast" real well! Kinda like the "speed of heat" or "as fast as a scalded APE!" (which is are both known to be very fast as well), HA! 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
jd1923 Posted May 8, 2024 Posted May 8, 2024 21 hours ago, topgun2 said: You da man! My fingers can't type that fast! Bill, I believe you need to add some carbs and proteins to your diet! 5 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
