Maxx-Fan install
The forum has given me more work to do again! Love the new fan with light. I won't bore everyone with the same information already available from previous posts but great upgrade. The only thing I might have done in retrospect is drill a 1/4 in hole adjacent to the 6 in opening so that the wires had a better home rather than squeezed between the fiberglass and shroud.
IMG_7820.thumb.jpg.ce98d44e843a663dc8ffe1ede0e5d535.jpgIMG_7761.thumb.jpg.db2f268b94a70eabd755f04fe0d0d3a7.jpgIMG_7767.thumb.jpg.7c87b18d02eb8dd31e0f3704e43e89d8.jpgIMG_7819.thumb.jpg.4f0c80dd04e87074162ee3b297828983.jpgIMG_7821.thumb.jpg.ced6bbc7e29b76a6ab9b7031a42af864.jpgIMG_7822.thumb.jpg.033163850cf7b44f8f3fa0b826889465.jpgIMG_7823.thumb.jpg.3a4fd221d614be88176fd9f0e4b2e234.jpg
Edited by rideadeuce
-  Mike  Brentwood, TN  -  2018 Elite II  -  Spirit of Adventure Hull #308 -  2016 Toyota Tundra Limited 5.7L  Class IV hitch with 12k lb coupler, Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar, Custom rear bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires
Does it fit the original hole from the older model fan?
It fit our 2008, with a bit of filing of rough edges.
Yes, it fits exactly. The only thing that would work better is to modify the wiring by drilling a hole next to the opening that leads to area that the LED shroud covers. The original wiring from the Vent-line fan came out the side and just tucked in between fiberglass shells. The wiring from the LED light squeezes between the extension shroud and hole but would be better if it was better protected.
Oh, I forgot to mention I blew the fuse for the fan in the sub panel in the attic. Left side, 5th down 7.5 amp. I recommend taking it out before wiring. IMG_7818.thumb.jpeg.4e9948576f9158889b00d5f382172146.jpeg
  • The title was changed to Maxx-Fan install
@rideadeuce Hey Mike, you are really doing a great mod-job on your Oliver. So many great improvements, and excellent work too. I LOVE your ladder-scaffold setup! Can I borrow it? Oh, and can I borrow a lot of flat land to work on? I would need levelers for that setup, or perhaps ladders with adjustable legs. Hmmm, you have me thinking. It's certainly not easy working on top of the Oliver given its shape. Kidding aside, thanks for sharing so many great posts lately. 😂
Little Giant setup with trestle brackets and plank is a game changer for working on and cleaning the Oliver, especially at my age. They actually sell a ladder with built in levelers. The ladder comes apart to make to A-frames, you connect them with trestle brackets and top them off with plank. Links below:
https://www.littlegiantladders.com/products/epic  Accessory bundle is included with wall mount and trestles.
https://www.littlegiantladders.com/products/ladder-plank?variant=41042434228389
1.thumb.jpg.9ff6f77ee6b85f34c6f787d046190519.jpg1-2.jpg.422fa4db792fd31c90914f2ea16ade97.jpg1-4.jpg.55ee7b3e8df394c79ba5323552411ae0.jpg
@rideadeuce - Great work on your bath fan upgrade, Mike - that LED makes a ton of difference when more light is need in the head...  You'll be loving it!  Should be OEM, IMO...
Awesome post!
Cheers from Lake Guntersville SP!
  • 2022 TUNDRA
The Boss of Me is going to be upset because that ladder is going to impact the toy budget.  Wow, I want/need that beast!
Hull #364 - The Roadrunner
2023 F350 CCLB SRW 6.7L
