On 6/3/2024 at 4:32 PM, Dave and Kimberly said:
 It's not a real big deal but I can't figure out what I'm missing.
I decided to chime in on this because I don’t think you’re missing anything, your discharge rate is perfectly correct!
All the given advice is good, but it’ can be a bit miss-leading to fully understand whats going on.  I hope to provide a better explanation, and show you a simple and very accurate way to check your “parasite” loads, which I’ll refer to as normal “stand-by” loads.
Your 390 amp hour battery with a daily discharge rate of 3% equates to a loss of 11.7 amp hours over a 24 hour period.  This further equates to a stand-by load of 0.48 amps, which is not overly excessive considering all the electronic devices in the Oliver.  Devices with memories, remotes, touch lights, rain sensors, USB ports, electronic boards, etc., can each draw milliamp currents even when turned off, and they do add up quickly.
I took some current readings from my own trailer to show you what I mean.  It’s the same year as yours and it also has a 390 amp hour battery.  Remarkably, the values add up to exactly the same current as your calculated load.  But more importantly, it shows that there is no single extraordinary load:
  • Fuse 2, Various electronics = 0.117 amps
  • Fuse 4, Furnace = 0.012 amps
  • Fuse 5, Main lighting = .003 amps
  • Fuse 6, Fans = 0.016 amps
  • Fuse 7, Water heater = 0.113 amps
  • Fuse 8, Radio = .204 amps
  • Fuse 9, USB outlets = 0.007 amps
  • Fuse 10, USB outlets = 0.009 amps
  • Total = 0.481 amps
These measurements were done with a precision multimeter having a resolution of 3 decimal points.  My Victron shunt has a resolution of 2 decimal points and it showed a lessor current of 0.42 amps.  My Clamp-on Amp Meter has a resolution of 1 decimal point, and it showed a higher current of 0.5 amps.  This demonstrates how subjective and inaccurate some of these measurement methods can be when dealing with such small milliamp values.
Another potential misconception is that the Lithionics BMS App will provide the overall charge and discharge values.  It’s only true to the extent that it provides values for the battery selected, but not for each battery combined.  For example; the 390 amp hour package consists of three 130 amp hour batteries.  If the overall load is 3 amps, then the App will show each battery discharging at 1 amp.  Additionally, it’s only accurate to 0 decimal points so it won’t show anything less than 1 amp.  This is another good justification for installing a Shunt.
There are a number of ways to measure stand-by or parasite current, but the easiest and most accurate way is with an inexpensive Multimeter through the fuse box.  It will show the load of each circuit, but not each component on the circuit.  Thats okay because some of the individual component loads are too small to be accurately measured anyway.
  • Caution:  When using the ammeter function, the meter is in-line with the circuit.  This means that the current is running through the leads and meter.  So don’t use it with loads greater than it’s rated maximum current, which is typically 10 amps.
Before testing, make sure that everything is off including the inverter/charger and solar (Solar switch is in the street side overhead cabinet.)   Make sure shore power is unplugged too.  Pull each fuse one at a time and the red LED “blown fuse” indicator will light-up if there is any load.  Put your ammeter leads on each leg of the fuse socket and read the current.  Add up the values and you will have an accurate overall stand-by load.  FYI, the inverter/charger does not go through the fuse box, but it will add another 0.2 amps load if left on.
I keep my trailer undercover without shore power and the batteries also discharge rather quickly.   In fact the shunt screen shot below shows that it will discharge in 10 days.  I considered adding a battery master switch, but it wasn’t a viable option for a number of reasons which is why I believe that Oliver doesn't install them either.  I ended up getting an auxiliary solar panel, with charge controller, and I mounted it on the roof to keep the batteries at 100%.  It was better than running an extension cord and risking complete discharge mishaps.
Hope this helps
Cheers, Geoff
IMG_3878.thumb.jpeg.125759dbbea37a63053940ee4e7535eb.jpegIMG_3882.thumb.PNG.2bd7aa78c002cdd0cf4a997e57de2035.PNGIMG_3880.thumb.jpeg.705413492ba66a1190e7780fb68dff94.jpeg
  • Like 8
  • Love 2
On 6/9/2024 at 2:32 AM, Dave and Kimberly said:
I'm not familiar with another fuse panel in the attic?  Do you mean the rear storage space (above rear window) where the EMS, TV antennae on/off area?
I'm not familiar with the wiring on your trailer, but for many years YES, there is a fuse panel in the Attic, right side.
Geoff:
What a great post.  It certainly sheds a technical light on the amp draw issue.  Knowledge is good.
Speaking of which, would you please elaborate further on not installing a high quality Battery Master Switch?  There are some owners who are on the fence in this regard, and your perspective would be beneficial.
Thanks,
Geoff:
Geromino John, thanks for the kind words.  Sure I can elaborate why I haven’t installed a Master battery switch, and I’ll also provide a better solution if the objective is to switch off all the stand-by loads when the trailer is in storage.
The battery switch will add resistance to the circuit from the additional cable length needed to reach the switch, and through cable lugs and switch contact resistance.  Granted it’s not much, but anyone who has ever dabbled with cable resistance knows that it doesn’t take much to create a voltage drop, particularly in high amperage battery systems like the Oliver.   Voltage drop impacts the systems efficiency and it means your creating heat and burning watts.
I don’t think there’s an optimum place to install a switch given the stiffness and limited bending radius of the size cable that you would need.  It's best to keep the cable as short as possible and that really limits the mounting options.
I haven’t see a compelling reason to install a huge battery switch.  I’m in and out of the trailer enough where it would be an unnecessary burden to turn the battery off.  The only reason I can think of for installing a switch, is to shut off the stand-by loads while in storage.  I personally think stand by loads are not a significant concern.  There are not many scenarios where solar or shore power is unavailable and, if so, there are other solutions.
If there is a desire to shut off the stand by loads while the trailer is in storage, then simply shut off the DC breaker that supplies the DC fuse panel. It’s located next to the inverter.  You can see from my previous post that all the primary loads are fed by the DC fuse box.  However, I’d recommend re-powering the CO2 detector so that it always stays energized.
Hope you find this useful!
Cheers, Geoff
On 6/8/2024 at 10:29 PM, Geronimo John said:
<snip>
Meanwhile, we'll just poke along.  Anybody have some slide rule wax?  After 60 years it's getting a bit sticky.  Numbers seem to be smaller than before too!
<snip>
John, I still have my old Pickett 1010 Power Trig, that I could loan you.  I keep it behind glass with a sign that says “Break glass in case of emergency.” for those times my computer is down
  • Haha 2
Hull #364 - The Roadrunner
2023 F350 CCLB SRW 6.7L
The beauty of the Sun Hemmi  257L “Chemical Rule” made of Bamboo never needed lubricants as Bamboo tends to be self lubricating.
Legacy Elite II   Hull 218  TV  2023 Ford F-150 Lariat   2x4   5.0L Max Tow Pkg   Ham W8CB    South Central Michigan
My Ollie does the same.  About 3% per day with everything off including the battery heaters. I assume there is some draw occurring amongst the electronics just to keep everything in monitor mode. I have two 320 Ah Lithionics batteries.  While I would it rather not degrade this fast, I have not attempted to chase it down at this stage and am not overly inclined to do so - too many other projects.
On 12/23/2024 at 1:22 PM, Snackchaser said:
Geronimo John, thanks for the kind words.  Sure I can elaborate why I haven’t installed a Master battery switch,
Geoff:
 Thank you. From your perspective, use, & trailer options; I can understand and respect your justification for not seeing the need for a master battery switch for your trailer.
 Concerning some of your responses:
Increased Resistance: Yes resistance is bad and should be minimized especially with the high amperages ... as you stated.  The suggested switch install in the battery box, as several of us have done, uses a short copper flat bar, and no additional lugs or extra wire.  The increased resistance induced is inconsequential compared to the terrible efficiency of many of our Inverters.  Especially the older ones!
 No Place to Install:  The suggested Blue Seas Series 9000 E switch has nicely been installed in the battery bays, under the dinette seats, and under the street side bed of our trailers.  Depends on your priorities.  If you wanted access inside, it can be mounted inside.  If you want it outside we have space the battery box for many Litho Battery installs.  (But not all).  Either way, locations are not an issue.
 Huge Size of Switch:  Tilt, see above.
 No Compelling Reason:  How about the Fire/Rescue having the ability to stop the flow of power to an inside fire?  This is especially the case for Lithium installations.  One of the reasons to put the switch where they will first look for it.
 Un-necessary Burden of turning the battery off when In and Out of the Trailer:  For most of us, that is not the purpose of this switch.  Many of us only use it for storage and emergency use.  It takes me less than 15 seconds to turn on/off, and that happens on our first season’s voyage and off  3 - 4 months later in the fall when we winterize.  But some owners likely do so more often.
For Standby Power Losses During Storage:  Some lucky owners such as yourself have solar and/or shore power in their storage site 365 days a year.   Some owners don’t need to worry about their batteries freezing.  On the other hand, some owners do not see their trailer for months at a time over winter.  Collectively this means that more than a few owners do need to isolate their batteries.   Additionally some battery manufactures do not recommending keeping their Litho's at full charge when not being used, especially where deep freezes occur occasionally.
Simply shut off the DC breaker that supplies the DC fuse panels:  The purpose of the Master Switch is to shut off ALL DC power to the trailer from their batteries.  The 60-amp DC breaker does not do this.  I believe that it does not terminate the power to the Inverter which is wired into the 300-amp fused via 4/0 wiring.  For our trailers, if we want to kill all DC current flow, without a 300 amp breaker, which I am not aware of any OTT trailer having, we would have to remove the 300-Amp fuse or disconnect a terminal in the battery compartment.  But either are a PITA.  So, we do so in 15 seconds or less by turning off the Master Switch.
To summarize, many of our OTT owners don’t have such a great storage solution as apparently you are blessed with.  Likewise, they and others have chosen the peace of mind that the DIY installation of a Master Switch provides.
 I hope you and the family are enjoying a great Christmas!
Edited by Geronimo John
Geoff:  Again great work on the parasitic losses.  I wonder what your amp meter would show if you physically disconnected the 4/0 wire to the Inverter with your 60-amp breaker off?
On 12/23/2024 at 4:22 PM, Snackchaser said:
The battery switch will add resistance to the circuit from the additional cable length needed to reach the switch, and through cable lugs and switch contact resistance...
I haven’t seen a compelling reason to install a huge battery switch.  I’m in and out of the trailer enough where it would be an unnecessary burden to turn the battery off...
If there is a desire to shut off the standby loads while the trailer is in storage, then simply shut off the DC breaker that supplies the DC fuse panel. It’s located next to the inverter.  You can see from my previous post that all the primary loads are fed by the DC fuse box.  However, I’d recommend re-powering the CO2 detector so that it always stays energized.
I'm with Geoff on most of these points. The Blue Seas switch is the best available but does not come close to running 4/0 cables from the batteries straight to the inverter. Yes, you can connect it by copper bar but resistance internal to the switch is the issue, two more lugs, bolts, etc.
By the time I unlock the battery bay and the padlock securing the battery tray, it only takes a wrench on one bolt at the battery ground to disconnect power when servicing. We do not store our Oliver. As Geoff wrote, "I’m in and out of the trailer enough..."
Not a good idea adding another switch under the streetside bed either. I spent hours rerouting the rear bus, solar and DC breakers to the area under the rear dinette seat. I removed over 10' of #6 wire and a good 20' of #10 to the 3 stabilizer jack fuses, and much other wiring. It's crazy how OTT added length to the wiring just to put this stuff under the bed. Some wiring removed had two inline crimped butt-connectors. All the extra length and connectors adds to resistance/voltage drop. All cable runs are now shorter, just 5 ft or less.
I upgraded the positive bus with one that is made of 5/16" solid copper bar (not hollow brass like the OEM bus). I replaced the neutral/ground bus with a longer heavy-duty bus and doubled the ground AWG. In doing this I also removed four #6 cables that were run directly to the +/- battery terminals. I have mod posts of all this work and less connections are better!
On the last point made above. I would not be concerned if the CO monitor was not powered when truly in storage, with LP tanks off, nobody inside anyway. Turning the DC breaker off is a good idea to eliminate parasitic draw. It seems it's all that is needed. Thanks Geoff.
Geronimo, if the inverter is disconnected like that, then it wouldn't be drawing any "parasite" losses because that's how it gets its power.  However, I can tell you that it’s a negligible value and a non-issue if it's turned off.  It doesn't even register a value on the shunt because it's below the  margin of error.  My guess would be something less than 20 milliamps, which is a general stand-by current value for electronic devices.  Although it’s true that old and new inverters are not efficient at inverting power, that efficiency should not be confused with stand by current when turned off, and they should always be turned off when not in use.
Here are some calculated values for perspective:   A 20 milliamp current would take over two years to completely drain the subject 390 amp battery.  However, the afore mentioned 481 milliamp fuse panel current could drain it in 30 days. . . or less considering other battery losses and drawdown limits.  That's a pretty powerful argument for doing nothing more than switching off the fuse panel breaker.
For those still on the fence about installing a battery switch, I think it’s important to understand this perspective in order to make an informed decision of what option is best for them.
Hey, thanks again for the kind words and Happy New Years!  Geoff
  • Love 3
With your excellent posts, it appears that we should expect to be losing around 11.7 amp hours each 24 hours.  This then would cause a very nice 390 AH battery to go bingo in 33 days (390/11.7 = 33.3 days.)  Less for my three 100 ah Battleborns if I did not kill the 60 amp breaker..
So, without solar or shore power assured, one could see their Litho's shutting down due their BMS hitting low voltage shut down in about a month if they don't kill the 60 amp breaker.
According to DragonFly for our Battleborns' using unpowered storage in hard freezing conditions a low voltage shut down is not recommended.  For such conditions, DragonFly says we need drain down and then equalize our batteries and then draw them down to the 50 - 60% SOC,  Then either disco them or have a Battery Master Switch.  They specifically do not desire that we hard freeze them with the SOC outside of the stated range.  Following this "protocol" we can safely store our Litho's for a year.  Pretty nice in our case.
I would be very interested if other MFG's feel the same as DragonFly on this.
Of course.  But it is not disconnected during your evaluations.
So, let me try again in a different way.
You have taken the time and effort to meticulously run down all the identified sources of parasitic losses in our trailer.  At least for all those sources powered up by the 60 amp breaker. This is wonderful work.
I also note your above post that you stated:  "Devices with memories, remotes, touch lights, rain sensors, USB ports, electronic boards, etc., can each draw milliamp currents even when turned off, and they do add up quickly."
I again totally agree with you.  So we agree that all those micro loads draw power and many do so when off.
Then why would the largest, most complex, and the greatest power draw item we have not draw power when it too is off?  That item is the Inverter.
Hence my suggestion that it be checked out and added to your list.
PS:  The other micro amp draw is from trailer lights when the plug is wet.  I would totally agree that it is not worth testing as it is a load caused by a problem.  Not a load we would need to worry about for the vast majority of our time.
Inquiring minds want to know!
It’s true that inverters are complex devices because they can invert, convert, charge and switch large currents, and they have notable efficiency losses when doing so.  However, with the inverter turned OFF, the only “parasite” load I can think of might be the Bluetooth or a memory function.  Thats why I conservatively guessed an estimated ballpark value of approximately under 20 milliamps (+/- 20.)  😁
The inverter OFF load was too small to register on my shunt and therefore I consider it inconsequential. . . like years to discharge the battery.  But, if I ever disconnect the battery, I'll let you know exactly what the load is and let's not be surprised if it's zero!
Also consider this:  Even with the inverter “inadvertently” left ON, with no AC devices turned on, the “parasite” load is only 0.2 amps per my shunt as I previously mentioned.  That’s because it’s actually operating to power the microwave clock . . . speaking of inefficiency.  But that's also a small current that would take months to run down the 390 amp battery.
Good discussion! Cheers!  Geoff
Certainly, true when OFF. Those of us who have upgraded to the Victron Multiplus II are in the practice of leaving the inverter ON 24x7. It can be switched from OFF, to ON, to Inverter only, or Charger Only modes via the VictronConnect app. It has to be in one of 3 defined ON positions to allow shore-power pass-through power.
We do not store our Oliver so for us this means 365 days a year as well. The Victron MP2 draws 13W (1A) continuously unless switched off or in other power saving mode.
We have the same ~0.5A parasitic draw and I leave the Outside Courtesy lights on 24/7 so that underneath the Oliver does not become nesting ground! So, we are burning about -1.75A regularly and right now on a sunny afternoon we are reading +7.2A from solar. Ours has been parked and unplugged for 2 months, batteries SOC at 80% +/-.
I understand those of you who store your Olivers indoors over the winter have different concerns. Ours must sit outside in the sun and covers are just a PITA and damage the finish equally when blowing in the strong western winds!
2022 LEII with 390 AH factory lithium
just because I was curious and I have been following this thread
with batteries showing 100%
I went out after dark last night around 6:30 pm and turned on the inverter
this morning at 7am I checked the lithionics APP  and then turned off the inverter
it showed 95% on all three batteries
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
That’s just over 1.5A per hour which sounds good with your inverter on. Likely 1AH for inverter only.
Happy New Year!!!
