Boilermaker Chemist Posted July 8, 2024 Posted July 8, 2024 I am a new Oliver owner and am surprised to find that there is no main battery disconnect. Since we will be making frequent, short trips in and out of storage I would like to add one. I plan to purchase a Blue Seas 350 amp switch and connect it on the negative side. I have seen posts about using a short cable or small bus bar to connect the switch directly to the battery post. That seems like a simpler solution than others I have seen. I would appreciate hearing your comments about exactly how to do that – parts needed and where to purchase. We have the solar package with AGM batteries connected with 4/0 cables. Thanks in advance for any and all advice on this! Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Moderators mossemi Posted July 8, 2024 Moderators Posted July 8, 2024 49 minutes ago, Boilermaker Chemist said: I have seen posts about using a short cable or small bus bar to connect the switch directly to the battery post. That seems like a simpler solution than others I have seen. Your disconnect needs are different than mine, so I choose a location under the rear dinette seat. I was interested in a disconnect switch in order to allow battery removal for a future battery upgrade and I wanted less obstacles in the battery box. It will work for your needs wherever you place it. I have some small pieces of 4/0 cable and I can make a short jumper if you provide the connectors and cover the shipping cost. Mossey 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
HappyCamper7424 Posted July 8, 2024 Posted July 8, 2024 (edited) Thanks Edited July 8, 2024 by HappyCamper7424 wrong account
Boilermaker Chemist Posted July 8, 2024 Author Posted July 8, 2024 Thank so much for the offer, Mossey. I actually have a local shop nearby that has made cables for me in the past, so it will be quicker and more cost effective should I decide to go the cable route. But thanks again. Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Guest Posted July 9, 2024 Posted July 9, 2024 A Google search of this site will lead you to several posts of how owners have installed these switches. Here is a picture of how I did mine during the lithium battery upgrade (which was shamelessly copied from Geronimo John). Tie down straps added after the picture was taken.
Boilermaker Chemist Posted July 9, 2024 Author Posted July 9, 2024 Thanks for the photo, it is pretty close to what I am looking for. Exactly what is the connector from the battery terminal to the battery switch? Where did you purchase? Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Guest Posted July 9, 2024 Posted July 9, 2024 (edited) 3 hours ago, Boilermaker Chemist said: Thanks for the photo, it is pretty close to what I am looking for. Exactly what is the connector from the battery terminal to the battery switch? Where did you purchase? I used some copper bus bar I had left over from one of my airplane builds. I either got it from Aircraft Spruce, or more likely McMaster-Carr. 1/8" thick by 1" wide. I bent it to shape in a vise, used an annular cutter to make the holes for the battery stud and disconnect. Used heat shrink to cover as much of the exposed copper as possible. Edited July 9, 2024 by katanapilot
Boilermaker Chemist Posted July 9, 2024 Author Posted July 9, 2024 Thanks for the detailed info, I like your approach rather than using a cable. Now I can order my parts . . . Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
rferg800 Posted July 9, 2024 Posted July 9, 2024 Just remember that if you disconnect the batteries from everything including the solar charge controller you need to disconnect the charge controller first from the solar panels. Or risk damaging the solar charge controller. 5 2019 LE II Hull# 466 TV 2021 Chev Silverodo 1500 HC
Boilermaker Chemist Posted July 10, 2024 Author Posted July 10, 2024 Thanks for that warning, I guess that is one reason there is a disconnect from the solar panels! Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Boilermaker Chemist Posted July 10, 2024 Author Posted July 10, 2024 11 hours ago, katanapilot said: I used some copper bus bar I had left over from one of my airplane builds. I either got it from Aircraft Spruce, or more likely McMaster-Carr. 1/8" thick by 1" wide. I bent it to shape in a vise, used an annular cutter to make the holes for the battery stud and disconnect. Used heat shrink to cover as much of the exposed copper as possible. Since this disconnect switch will be handling a lot of amps I wanted to be sure to use the proper size busbar for this application. So I did a little more research and found a very helpful document on the Victron Energy website entitled “Wiring Unlimited” by Margreet Leeftink. Assuming that I did my calculations right, a 1/8” x 1” copper busbar only has a surface area of about 80 mm2. According to the table below, the surface area for my 4/0 cable is 107 mm2. So I am going to do a little more investigating before I order those parts. Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Guest Posted July 10, 2024 Posted July 10, 2024 A copper bus bar of 1/8x1” will conservatively handle 275 amps at 40c ambient with a 30c temp rise. If you don’t think that’s enough, then upsize the bus bar.
jd1923 Posted July 10, 2024 Posted July 10, 2024 (edited) 1 hour ago, katanapilot said: A copper bus bar of 1/8x1” will conservatively handle 275 amps at 40c ambient with a 30c temp rise. If you don’t think that’s enough, then upsize the bus bar. It’s enough! 275A x 12 VDV = 3,300W. So you can run your A/C plus your microwave, at the same time across this beautiful piece of copper! Limiting factors will never be the copper bus, but instead your inverter or the cabling to it. Go with the proven design that @katanapilot has illustrated. Nice install! This copper 1/8x1x6” busbar on your B- terminal is likely a superior conductor than what your LifePo4 battery manufacturer has designed internal to the battery terminal, for sure! That’s all that counts at the final ground to the battery. Edited July 10, 2024 by jd1923 Added last sentence. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Guest Posted July 13, 2024 Posted July 13, 2024 I have to ask why so many of you are using 4/0 cable? My Oliver came with 2/0. Victron specifies 1/0 for the feed to the 3000va Multiplus 2 inverter for lengths less than 5 meters and 2/0 for 5 to 10 meters. Just concerned that I’m misunderstanding the wire ampacity tables.
Boilermaker Chemist Posted July 13, 2024 Author Posted July 13, 2024 4/0 is what was factory installed on our 2023 model. Since main fuse is 300 amp, conductors have to be rated for that amount of current. 2 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
jd1923 Posted July 13, 2024 Posted July 13, 2024 2 hours ago, katanapilot said: I have to ask why so many of you are using 4/0 cable? My Oliver came with 2/0. Victron specifies 1/0 for the feed to the 3000va Multiplus 2 inverter for lengths less than 5 meters and 2/0 for 5 to 10 meters. Just concerned that I’m misunderstanding the wire ampacity tables. You're not misunderstanding. Without doing the math myself, Victron's numbers appear correct. Over-engineering is common in DIY efforts and going to heavier gauge cable doesn't hurt, just costs more money. OTT installed 4/0 in our hull too. The length of the run, from the batteries to our 2KW inverter under the rear dinette seat is about 1m or 4 ft at most. The Oliver is over-engineered in many ways, and we appreciate that. The cost difference of 2-3m of 4/0 over 1/0 cable, at wholesale to a manufacture, is not much and they are being over-safe for a few bucks. When I go to install a DC-to-DC charger, two cables the length of TV and TT, likely over 25m, I will buy the gauge required and nothing more due to the retail cost of copper today! 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted July 14, 2024 Posted July 14, 2024 15 hours ago, jd1923 said: When I go to install a DC-to-DC charger, two cables the length of TV and TT, likely over 25m, I will buy the gauge required and nothing more due to the retail cost of copper today! I used 4AWG cable for my DC-DC install, bought 50’ red+, 50’ black-. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Guest Posted July 14, 2024 Posted July 14, 2024 18 hours ago, jd1923 said: You're not misunderstanding. Without doing the math myself, Victron's numbers appear correct. Over-engineering is common in DIY efforts and going to heavier gauge cable doesn't hurt, just costs more money. OTT installed 4/0 in our hull too. The length of the run, from the batteries to our 2KW inverter under the rear dinette seat is about 1m or 4 ft at most. The Oliver is over-engineered in many ways, and we appreciate that. The cost difference of 2-3m of 4/0 over 1/0 cable, at wholesale to a manufacture, is not much and they are being over-safe for a few bucks. When I go to install a DC-to-DC charger, two cables the length of TV and TT, likely over 25m, I will buy the gauge required and nothing more due to the retail cost of copper today! "No kill like overkill" 😉 4/0 cable and connectors are just harder to install and bend radius is higher. Victron is perfectly happy with 1/0 cable up to 5 meters long and a 400 amp fuse. I'll use 2/0 for 4 foot run and feel perfectly comfortable with that. And I am typically the king of overkill.
Boilermaker Chemist Posted July 14, 2024 Author Posted July 14, 2024 8 hours ago, katanapilot said: Victron is perfectly happy with 1/0 cable up to 5 meters long and a 400 amp fuse. I'll use 2/0 for 4 foot run and feel perfectly comfortable with that. And I am typically the king of overkill. The way I read it, TWO 1/0 cables would be required, which is equivalent to a single 4/0 cable. Admittedly, I am not an electrician, so if I am missing something, please feel free to correct me. Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Guest Posted July 15, 2024 Posted July 15, 2024 11 hours ago, Boilermaker Chemist said: The way I read it, TWO 1/0 cables would be required, which is equivalent to a single 4/0 cable. Admittedly, I am not an electrician, so if I am missing something, please feel free to correct me. You are absolutely correct. What I don't know is if Victron requires the two cable connection - to spread the load over the two input studs - or if a single 4/0 connection would be sufficient. I will reach out to them to ask. I looked again and my OEM cables are indeed 4/0. That being said, I currently (pun intended) believe the 2/0 battery interconnects are sufficient given the very short length of these cables and the 300 amp fuse I have installed. I am going to consider piggybacking an additional 2/0 cable between the 3 batteries. Thanks for being persistent and forcing me to RTFM a couple of times.
Geronimo John Posted July 15, 2024 Posted July 15, 2024 Another caution: Different hulls have different dimensions, trays, and batteries, Hence one pic may not work for all as our stack heights vary. On my 2018 with 100 AH batteries I could not use such a thick cutting board. Check yours before purchase is a good plan. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Boilermaker Chemist Posted July 15, 2024 Author Posted July 15, 2024 6 hours ago, katanapilot said: Thanks for being persistent and forcing me to RTFM a couple of times. Haha, reminds me of what my brother-in-law said he learned in the marines about assume - it makes an ASS out of U and ME. I hate to admit that the older I get, the more I am reminded of that quote! 2 1 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
jd1923 Posted July 15, 2024 Posted July 15, 2024 6 hours ago, katanapilot said: You are absolutely correct. What I don't know is if Victron requires the two cable connection - to spread the load over the two input studs - or if a single 4/0 connection would be sufficient. Doubling up cables can increase the overall amperage in the connection. They have tables for that online. The dual terminals in the Victron multiplus can be used in this way, but as evidenced above, one 4/1 is already overkill. I'm going to use the second post to connect 12VDC +/- to the Oliver 12VDC fuse panel. The OEM wiring has both connected directly to the batteries. This will clean up the battery bay, using the built-in Victron bus vs. adding another. The true reason for the dual terminal is that Victron products are designed to be installed in multiples. Use of the second terminal can daisy-chain multiple inverters side-by-side. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted July 19, 2024 Posted July 19, 2024 On 7/8/2024 at 5:16 AM, Boilermaker Chemist said: I plan to purchase a Blue Seas 350 amp switch and connect it on the negative side. That would be my thought, since when working on an automobile the standard is to remove the ground. The picture @katanapilot showed has it on B+. Victron Energy always shows it on the positive side and the shunt on the negative. I'm going to do it this way. Does anybody have a link for the Blue Seas 350-amp switch like the one in the picture, meaning surface mount. Every one that I find online that is surface mount is 300 amps. Thinking with a 3KVA Victron inverter/charger I need the 350. Thanks Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Boilermaker Chemist Posted July 20, 2024 Author Posted July 20, 2024 I ended up buying the Blue Sea Systems 6006-BSS 300 Amp switch since the main fuse in mine is 300 amps: 1 1 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
