15 hours ago, Tideline77 said:
When the mini is deployed away from the camper to get clear sky , Is it a reasonable idea to power our mini with two Milwaukee Forge tool batteries ?
we have the batteries in our tool box with a few Milwaukee M18 tools , inflator, impact wrench for tire emergencies, rolling out and rolling up a power cord seems like a burden "………….after doing it for 45 years
Thank you, Robert! 😎
I've been preaching this for over a year now! No takers to date!
All these complex setups, and I too spent a day adding a Victron 12/24 DC-DC charge controller and Ethernet for input to our Pepwave router. Cool setup, but what a waste since we haven't used it yet! Yep, cords are a pain!  🤣
You have Milwaukee M18 tools, and we have several DeWalt 20V tools that we bring with us (flashlight, vacuum, impact and leaf blower). I purchased two 10 Ah batteries just for the Starlink Mini, each will run the dish for 8 hours. You want two so one is always charged. I have an extra DeWalt charger permanently mounted in the Oliver attic. Looks like you'd be in business for only $23! BTW, 1 1/2" PVC pipe fits the Starlink Mini included mount nicely too!
https://www.amazon.com/Starlink-Battery-Adapter-Compatible-Milwaukee/dp/B0FDWP191V/?th=1
Edited by jd1923
I like the idea but it has a couple challenges for me.
1- Most of those do not have a low power shutoff. So if you forget to unplug it you may kill your battery. A direct connection to the TT batteries avoid this.
2- This leads to the challenge of having to go outside to turn it off. Not so fun when warm inside and ready for bed and you remember it is still on.
3- Even with low power shutoff if you have to wake up early in the morning to get some work done you have to jump outside and switch the battery out.
I am leaning more toward something like this. About the same cost but still has cables and some manual labor to get wired in. A little lower cost and a little less setup with no need to switch inverter on and off.
https://a.co/d/03RI49lb
Edited by Zodd
Grammer
Todd & Kat
Yes, the DeWalt XR 20V 10Ah batteries we use do go dead every night, sometime after we fall asleep. Early on we had an older 6 Ah battery go dead once and fail, but it was date coded over 5 years old when that occurred. Our new 10 Ah batteries, date codes 2025, turn off a few hours before we change them out the next morning and they recharge in an hour or two. We've done this without issue for more than 20 overnights.
Regarding your point #3, if you cannot climb out of you trailer day or night, then you're back to a wired solution, at that point you could bury the cables and stay in bed for weeks! 🤣 Chris takes our dog out every morning and/or I'll go outside, soak in the sun with a morning cup of coffee! First one out usually swaps the batteries. We much prefer this over laying out and winding up the 50' cord every few days.
And if you're going to a wired solution, why not just use the supplied Starlink power cord with 30V AC adapter, but you do need an inverter for that. If going for the DC wired solution, get a quality DC-DC 12/24 charger, like the Victron @Snackchaser used and I installed (I might use it some day)! For about $20 more it's not the Amazon/China cr@p!
https://www.amazon.com/dp/B01D082AX8/?th=1
hehe, well now @jd1923 you are just trying to make me sound really lazy 😉
The absence of a cord is really convenient, but when I need to wake up at 5 AM for a work call, I try to be quiet so I don’t disturb my wife. This becomes challenging when I have to open and close the door. So far, I've been using the AC adapter and turning the inverter on and off as needed. I'm considering options that don't require the inverter to be operational, so I can keep it running continuously.
Still trying to weigh cost/effort/reward. So far using AC adapter has been fine and I have never been short on power.
Todd & Kat
Yeah, you’d want to be plugged in, if this is a regular occurrence!
On occasion when I have to locate the SLM away from the Oliver I simply place it on the TV, via the magnetic mount, and park as close as possible to the Oliver for clear skies. A 100Ah portable power station is used, rather than the TV’s battery, so the SLM is continuously operational. I get great reception inside the Oliver with this setup configuration; no cables, no power concerns, no reception issues, no worries! Generally however, I just use a dedicated sectional pole with suction cup mounts to strategically position the SLM anywhere around the trailer where the best exposure at a break in the tree canopy is found.
Edited by Ronbrink
We just got our mini and activated it from our home base, then switched the subscription to pause
so I am not too swift on the operation but I thought I saw the option on the phone APP to turn off the mini via IPhone
so I thought it could be turned off by APP without us  streaking in our camp site
also on ETSY and EBay are some pretty cool offerings that accommodate two batteries and have a small shroud cover that covers the batteries and holds the mini
giving the batteries a small amount of weather protection
look pretty neat to me
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
So, is this true?
It would be great to power down the Mini via the Starlink app! I would do that each night from bed and would then have ample battery left for the next morning! 😎
Edit
AI search shows the APP sleep mode can be set via APP
sleep mode is not a complete shutdown but is a low power mode designed to conserve battery use
so its sleep mode you want to set on your APP
For sure Need to review the APP to confirm this because my mind and memory are not 100% anymore. Plus I only played with it for 3-4 evenings
i can get mine out tomorrow and double check
Edited by Tideline77
Robert E
The Entrepreneur made twin M 18 battery housings listed on eBay and ESTY would be the cats meow . They must be three D printed plastic
if these makers could take that idea one step further and use a short pole to get the mini out of the brush or grass and maybe get a little better sky reception
Hope I didn’t derail this thread two much 🙄🙄🙄
Robert E
Can any provide a link to purchase the "“three pin” 5.5 mm female socket" described in this post?  I'm referring to the one where the 3rd pin is switchable.
Please email to rarebear.nm@gmail.com
Thanks
Thanks
Edited to correct link.  Here is an updated Amazon  link: https://a.co/d/04TQyt2M
Edited by Snackchaser
2 hours ago, Rarebear.nm said:
I do not see where either of two choices have a built-in switch as described in the post.
Yea sorry, those Amazon links were questionable, so I updated that reply with a better link.  3-pin dc power connectors are typically switched, to disconnect a battery when an outside power supply is plugged in.  Those Amazon knock-offs have a sketchy description, so without actually testing one there is no telling what they are.
I buy parts from DigiKey.  Look up Digikey part PJ-005B and view the datasheet.  There is a schematic showing the Pin-2 to Pin-3 switch.  They are under $3 at DigiKey plus shipping, Amazon sells them 5 for $18 with free shipping:  https://a.co/d/04TQyt2M
  • 3 months later...
Our Ollie does not have factory solar or inverter. I use portable suitcase solar panels or a 2000W Honda Gen-Set when away from shore power.
Copied @Snackchaser idea converting the Furrion Cable TV inlet to a Starlink Mini power outlet using a 5.5 x 2.1 mm DC Power Jack Socket. Thanks Snackchaser for the idea! Used a 7/16" drill bit to drill the new Furrion power outlet for the power jack socket to fit. Had enough threads on the 5.5 x 2.1 mm DC Power Jack Socket to install water/dust cover, lock washer and nut.
Old Furrion inlet on the left:
https://www.amazon.com/dp/B0GKB4YSM5?ref=ppx_yo2ov_dt_b_fed_asin_title
https://www.amazon.com/dp/B0DLKN8J7M?ref=ppx_yo2ov_dt_b_fed_asin_title
Purchased a 12/24V to 48V DC to DC step up Starlink Mini converter and switching with a manual switch to be installed.
Bill 2015 LE2 2024 F-350 6.8L
  • 4 months later...
The Mini 2 is about to be released!  Right now by invitation, but usually to the public soon after.  The price includes a year service plan, but what will it be the year after?
Built-in Battery. Built-in Wi-Fi.
Mini 2 is the next-generation portable Starlink Kit, with a quick-swap battery and built-in Wi-Fi. Press a button and you are online in about 60 seconds. Take it camping, on a boat, on the road, or anywhere you can see the sky.
Mini 2 preorders are open by invitation only to select U.S. customers, ahead of the public release. Make sure you are logged in to the Starlink account that received this email to access the preorder page.
One Price. A Year of Connectivity.
Mini 2 is $999 plus tax, which includes:
  • Mini 2 Kit. Everything you need to get online, including a USB-C power cable and one quick-swap battery.
  • A full year of Roam Unlimited ($2,100 service value). Unlimited data for road trips, streaming, video calls, and more, including in-motion use at speeds up to 100 mph.
  • International travel, up to 30 days at a time. Take Mini 2 abroad and stay connected, included with your Roam Unlimited plan.
Secure yours today with a refundable $100 deposit. The remaining $899 plus tax is charged when your Mini 2 ships. Shipments are estimated to begin in mid-December, and this price and year of included service are exclusive to this preorder invitation.
It would only be worth it for those who pay for Roam Unlimited 12 months a year (then monthly plans are likely the same as the original Mini). This service bundle could be of interest to new full-timers who travel regularly where cell service is limited.
We pay the $10/mo Standby Plan 6 months a year and then only what we need when we travel. When you have a viable cell router and antenna you need Starlink much less often. The 5G cell SIM card adds $30/mo to our cell plan which is much less per Gb than Starlink. Regardless, we would not travel without Starlink for when we need it.
For those still holding out, now's the time to get the original Mini before this becomes the only available option! The Mini keeps getting cheaper too, now only $149 ($12.41/mo for 12 months).
Are they advertising any better performance in their new product? It boots faster and has a built-in quick swap battery (after you buy an extra), and having an extra is truly a must unless you want to be offline every time it needs charging.
We have 2 external batteries and plug-in options and when you swap a battery, of course the Mini reboots. If the Mini 2 has hot-swappable batteries, that would be cool!
