Now I'm back to @Rivernerd's suggestion. Get a multimeter, or someone who knows how to use one, and follow the electricity's path until you find the problem. Test your home outlet, test the power at the end of the shoreline cable, test the power at the back of the shoreline connector in the trailer, test the power at the EMS input, test the power where it enters the circuit breaker box, test the power coming into the GFCI outlet, test at the AC, and keep going down the line. But this means working around live power and knowing how to use the meter correctly. You might be approaching professional assistance territory.
11 minutes ago, Steph and Dud B said:
Now I'm back to @Rivernerd's suggestion. Get a multimeter, or…
Wish I could be there to help! Never witnessed a defect condition that would swap the hot and neutral readings. A faulty neutral makes some sense, but how does that happen when sitting at a campsite?
Certainly replace the main 30A breaker. I would bypass it as a quick test, but I would not suggest this to anybody but a trained electrician.
Too bad you do not have an inverter, as you could unplug from shore power and run on battery.
I’m reading here daily to see if I can help, yet it’s difficult to troubleshoot virtually. Godspeed and wishes!
I did post this on RV Electric, Mike Sokol's Facebook site. One answer was "It appears to be the transfer switch, if there is one."  UPDATE, saw you don't have the front plug or transfer switch, so that is out of the equation.
The general tone was the original poster should join their Facebook group so that dialog is back and forth, as they felt there was conflicting comments from the OP.
Keep us all posted.
Edited by John Dorrer
Updated Comment
This is the area of testing where I like to use a non-contact voltage tester.
Those work great to verify a hot leg is live, but it seems like he has that already out to the outlets according to his circuit tester. Someone is going to have to use a multimeter and check voltage from the hot leg to the neutral at each connection point between the EMS to wherever the problem is. My guess is a bad neutral connection somewhere or a bad EMS itself.
  • Like 8
I found out what was wrong with electrical in trailer. I open up the inline surge protector case and found a burnt wire, replaced wired, and 120 volt appliances and outlets worked, I still don’t understand even with a burnt wire the ems still showed no errors and 120 volts
2019 Oliver Legacy Elite II - Delivery Date Aug 29, 2019
Ford F150 XL Supercab - 3.5 EcoBoost
1 hour ago, Collier and Joan said:
I still don’t understand even with a burnt wire the ems still showed no errors and 120 volts.
Many were saying a bad neutral and that’s what you found. The hot output has a current sensor around it. However, the EMS is monitoring input shore power, the hot out, but not the neutral on the output side. Good find!
Probably another example of the need to check your 120 volt connections at the various lugs throughout your trailer. This isn't the first burnt wire found and reported on this forum.  So far, I'm not aware of any fires that have been caused by these failures - but it's certainly a possibility.
I will be going through our trailer and checking all of these connections when I install the new Victron components.
2020 Elite II Hull #628 "Pearl" - Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt
TV - 2011 Toyota Tundra Crew Max Platinum 5.7 V8 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
My unit is only 2 yrs, i will be checking mine.  I have already had a connection come loose , H2O pump inop.. I,m glad things are working ok..
spacer.png2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
