it started making a bad noise like a fan was grinding then quit.    rather than repair it we would like to replace it with a unit that is quieter.   we can't use it because its too loud.  I turned it on last week and now it just shuts down and no fan comes on.   I've looked at different threads on ac replacement but need advice.
skip and cyd nielsen  hull #822 Elite     tow vehicle 2017 jeep trailhawk v6
we are in Livingston, Montana and close to Bozeman
18 minutes ago, jd1923 said:
I believe @Ronbrink is working his installation any day now!
The shipment was delayed, I decided to have SDG install the SoftStartRV; should ship this coming week.
2020 OLEll, Twin, 579:
No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade.
Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer;  pending transfer of Mechman 320A high output alternator from former TV.
hey thanks so much for the website etc.    now to find a rv repair service in bozeman that could order install the unit on our ollie #822.
It is my opinion that when Houghton gets around to offering a remote thermistor and low speed fan cut off relay as standard OEM option, they clearly will have the best unit on the market.  It is exceptionally well built, super quiet and energy efficient.  I believe the best unit out there.
There are two mods that can be done that totally resolve the humidity issue caused by their Set 2 design.  However, they require HVAC and Electrical skills that are well beyond most owners.  One OOPs and you have voided the warranty and are most likely hosed......
So, until then, for general use, I suggest doing a good technical spec side by side study of the options. Then carefully read and question lots of reviews.  Most importantly delay buying a unit that is new to the market.    Being a first adopter has unforeseen risks.
J
J
All they'd have to do is produce an optional control board- one that has DIP switches where you could select between utilizing the built in thermistor and an external thermostat and one to select between an always on fan or only on when compressor running. I'd buy one of their units tomorrow, and I bet they'd get a lot of sales of those upgraded control boards, too...
2010 Elite II, Hull #45.  2014 Toyota Sequoia Platinum 4WD 5.7 with tow package.
