Guest TxMN2020 Posted December 2, 2024 Posted December 2, 2024 Do The 2025 OTT’s include a smart shunt with The lithium battery upgrades?
Derek B Posted December 2, 2024 Posted December 2, 2024 Prior to doing some upgrades on my electrical I had the opportunity to look at a 2025 on dealer lot near us and snapped a few pics. It does have a smart shunt. 1 3 Derek and Deana | 2019 LE II, Hull #484 | 2023 F150 EcoBoost | SE Louisiana
rich.dev Posted December 2, 2024 Posted December 2, 2024 2 hours ago, Derek B said: It does have a smart shunt. Actually I’m pretty sure that is the BMV712 shunt not the smart shunt. 1 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Derek B Posted December 2, 2024 Posted December 2, 2024 48 minutes ago, rich.dev said: Actually I’m pretty sure that is the BMV712 shunt not the smart shunt. You are correct, still requires the display but does also have Bluetooth feature for the victron app. The smart shunt is Bluetooth only with no display. 3 Derek and Deana | 2019 LE II, Hull #484 | 2023 F150 EcoBoost | SE Louisiana
Moderator+ ScubaRx Posted December 2, 2024 Moderator+ Posted December 2, 2024 I've never seen a setup using two shunts. I wouldn't know how that would even work. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
jd1923 Posted December 2, 2024 Posted December 2, 2024 14 minutes ago, ScubaRx said: I've never seen a setup using two shunts. I wouldn't know how that would even work. Additional shunts can be installed to monitor subsystems, different battery banks, multiple solar arrays, etc. not much need in an Oliver, but… Our hull has a shunt wired to the display for the original solar charger. You can only read SOC and amps */- when in our hull looking at the display under the pantry. This would be the same for the BMV712 shunt mentioned above, wherever you mount the display, though this Victron product might have a Bluetooth sender or one can be added. I left the original shunt as-is and installed this Victron SmartShunt so I could read battery status outside the Oliver, in the TV while driving, even from my living room window at home! I spent $90 to add this and it’s been worth it. Download the app for no additional charge: https://a.co/d/4hKmfCW 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
dewdev Posted December 2, 2024 Posted December 2, 2024 @jd1923 For us dummies, can you show a picture of the "shunt wired to the display for the original solar charger"? Where is this shunt located? 1 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
mountainoliver Posted December 3, 2024 Posted December 3, 2024 (edited) 4 hours ago, ScubaRx said: I've never seen a setup using two shunts. I wouldn't know how that would even work. The assembly in the right side of the photo sort of looks like a fuse. The main cable looks like it is attached to the upper end of the shunt then from the lower end of the shunt crosses over to the lower end of the fuse/junction block, through the fuse/junction block and out into the world. Maybe? Edited December 3, 2024 by mountainoliver Corrected description 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
rich.dev Posted December 3, 2024 Posted December 3, 2024 23 minutes ago, mountainoliver said: The assembly in the right side of the photo sort of looks like a fuse That’s the negative bus bar 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
jd1923 Posted December 3, 2024 Posted December 3, 2024 (edited) 5 hours ago, dewdev said: @jd1923 For us dummies, can you show a picture of the "shunt wired to the display for the original solar charger"? Where is this shunt located? Thank you, our forum friend, no dummies here! I've respected many of your special posts as well. PM me if you want info specific to your hull. My first pic is the original Blue Sky Solar install, where you can see the OEM shunt (top-right). Our hull is dated 2016 and yours 2018. Nothing wrong with the original install but I can only read status, when sync'd, and while watching the installed screen inside the Oliver. The Victron SmartShunt has built-in Bluetooth and an app for reading on your phone. The second picture shows the Victron SmartShunt installed (at battery ground), the simplest installation possible. I have revised my installation since, after installing the Victron Multiplus II Inverter/charger, where I have it at the inverter, but still closest to the B- battery ground terminal. If I was to but a new Oliver Elite II (not happening for us, I'm a "always buy used" guy), I would have OTT install the solar array with wiring to rear dinette seat basement area (please NOT under the streetside bed) and I would install a Victron MP2 and pick from so many choices of LiFePO4 batteries on my own (Black Friday deals now 15% OFF). Battleborn batteries and Lithionics, good for the wealthy 3-6 years ago are now WAY bettered by LiTime (lowest cost), Epoch Essentials and others where 600AH cost <$2K or less! More info here (page up to first post)! Edited December 3, 2024 by jd1923 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators SeaDawg Posted December 5, 2024 Moderators Posted December 5, 2024 Our 2008 controllers are under the rear dinette seat. Very tight, but workable. I agree. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
