Geronimo John Posted May 15 Posted May 15 (edited) MaxBurner and I were looking for a way to gain some storage in our OE2’s. Both of us were not making effective use of the space at the front end of our wardrobe. We looked at Chiwald’s expansive closet shelving post, but needed to simplify and modify for our primary use of hanging cloths. So, the idea morphed to two shelves as pictured below. For scaling the two toilet paper rolls are “Max Size” rolls. The time-consuming part is making the two templates for the shelf shapes. The shapes of the shelf curves are not the same. After more than a few hours in the closet, we had the templates needed. We used synthetic wood 1” X 2” to support the shelves along the front surface. We chose this material as it easily can be bent and secured with a lot of short screws and MaxBond carpenters glue to the hull curve. It is also the right color (white). The shelves were cut from white laminated wall shelving from Home Depot. The front edge is 1/16” thick aluminum flat stock. For “G” loading purposes, we installed stiff legs on the left side as shown. All fasteners are Stainless Steel. When completed, the shelves are amazingly strong. In GJ’s “Ollie”, I mounted a 13’ telescoping ladder with an EPDM Rubber Tie Down Strap to secure the ladder top. To keep the ladder feet flush to the wall, I cut out a piece of lumber and attached it to the floor. The ladder leg sits into a hole in this “foot plate. The folded towel on top prevents noise and damage to the wardrobe wall. For Art’s “Casablanca” they have their “Pleasure Plank” (AKA Snuggle Shelf) mounted in a similar manner. GJ & MaxBurner Edited May 15 by Geronimo John Duplicate picture 1 8 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Jason Foster Posted May 15 Posted May 15 That looks nice. I’ve been contemplating the weirdness of the wardrobe as well but it hasn’t gone much farther than that. By itself, that space is nothing kore than a throw all. Shelves in the back allows for more vertical space usage and less piling. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
jd1923 Posted May 16 Posted May 16 That is a nice shelf, John. And yes it's a "simplified approach" which are the best designs! I had not thought of that space before, but yeah it is a void. I'm thinking now of maybe a couple of wire baskets back there for towels, if that would work on the curve. Hmmm...? (and the list gets longer, when I thought I had done enough in 2 years.) 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted May 16 Posted May 16 (edited) @Geronimo John Nice job and certainly much better use of the radius corner space in the wardrobe for sure. We opted to use a removable/stackable shelve drawer system which has worked really well for our closet storage. I will try and take a few pics post up. Edited May 16 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Ronbrink Posted May 16 Posted May 16 We hang a couple of laundry bags (his/hers) in the rear closet void; no interference with hanging clothes. They have backpack type straps for hauling into the house. 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator.
MAX Burner Posted May 16 Posted May 16 @Geronimo John's description of the wardrobe shelves is correct. Additionally, the additional "always needed" real estate for organizational efforts hit the mark. Both June and Diane are thrilled with the space for other stuff instead of a "throw all" space as @Jason Foster accurately notes above. This became a "Happy Wife -- Happy Life" Project immediately upon completion.... The white milk crate is our "wine cellar" still on the floor, and the wardroom door is backed with a hanging organizer for ready service items (Windex, misc. cleaners, more shoes, suntan lotion, etc.). The upper shelf houses our airfryer/convection oven strapped down with black tubular nylon and footman loops rather than having it banging around in the truck bed or bouncing around on the floor of the wardrobe. For scaling, those are a couple pairs of my size 13D shoes and D's Uggs on the lower shelf: 5 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Jason Foster Posted May 16 Posted May 16 3 hours ago, MAX Burner said: @Geronimo John's description of the wardrobe shelves is correct. Additionally, the additional "always needed" real estate for organizational efforts hit the mark. Both June and Diane are thrilled with the space for other stuff instead of a "throw all" space as @Jason Foster accurately notes above. This became a "Happy Wife -- Happy Life" Project immediately upon completion.... The white milk crate is our "wine cellar" still on the floor, and the wardroom door is backed with a hanging organizer for ready service items (Windex, misc. cleaners, more shoes, suntan lotion, etc.). The upper shelf houses our airfryer/convection oven strapped down with black tubular nylon and footman loops rather than having it banging around in the truck bed or bouncing around on the floor of the wardrobe. For scaling, those are a couple pairs of my size 13D shoes and D's Uggs on the lower shelf: Good to know I’m not the only one with clodhoppers around these here parts. 3 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
