CRM Posted August 5 Posted August 5 5 minutes ago, Ronbrink said: I suspect the “numbers” will increase somewhat as the compressor will work harder to reach and maintain temp in ambient conditions. However, likely less than what is typically seen with conventional units. I think the highest watts draw the engineer in the Youtube video was able to see at max power was around 1100. Still far less than any of the single speed compressor units of comparable size. In our small insulated spaces I'm guessing we would be consuming around 500-700 most of the time once setpoint is met. 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Treasure Coast Vault Posted August 5 Author Posted August 5 I don't think the numbers will change one bit. It cools the Ollie so effortlessly there's not much load in cooling an insulated cooler! ;*)) 2
jd1923 Posted August 6 Posted August 6 I read a review today, after reading several I forgot where. The reviewer stated one con was that the internal fan speed was constant, not variable speed. This comment upset me if true. I woulda thunk variable speed compressor and external fan should have a variable speed interior fan, allowing the interior fan to match the cooling needs as the inverter compressor does. This may be why it is not as quiet as could be and he denoted it as an area of improvement. Anybody here know more? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted August 6 Posted August 6 11 hours ago, jd1923 said: I read a review today, after reading several I forgot where. The reviewer stated one con was that the internal fan speed was constant, not variable speed. This comment upset me if true. I woulda thunk variable speed compressor and external fan should have a variable speed interior fan, allowing the interior fan to match the cooling needs as the inverter compressor does. This may be why it is not as quiet as could be and he denoted it as an area of improvement. Anybody here know more? Owners manual says it has low, med, hi, and auto. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Treasure Coast Vault Posted August 7 Author Posted August 7 Do any of the RV AC Systems have a variable speed fan for pushing the climatized Air? I had a few mini splits in homes and I never saw one that had a variable fan for the climatized air. All were 3 speeds L, M, H and Auto. None shut off after the cycle completed. This is what makes the Cielo Breeze Max T Stat so good it shuts the fan off after the cycle completes if you want that to happen. 1 2
Ronbrink Posted August 8 Posted August 8 23 hours ago, Treasure Coast Vault said: This is what makes the Cielo Breeze Max T Stat so good it shuts the fan off after the cycle completes if you want that to happen. Having the fan turn off as the compressor cycles off definitely prevents the dreaded humidity spike that many experience! Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Treasure Coast Vault Posted August 8 Author Posted August 8 I had the Ollie out in 95 Degree Central Florida Sunshine today and the Pioneer dropped the temperature to 78 and cycled fine. It was drawing around 685 watts. It is also very quiet. I was running off my inverter and the batteries. 1
jd1923 Posted August 9 Posted August 9 1 hour ago, Treasure Coast Vault said: I had the Ollie out in 95 Degree Central Florida Sunshine today and the Pioneer dropped the temperature to 78 and cycled fine. It was drawing around 685 watts. It is also very quiet. I was running off my inverter and the batteries. My Dometic Penguin 2 will see your bet of 685 watts and easily raise you another 1100 watts! And it must also be at least 10 dB LOUDER too! Maybe I should take advantage of the Turbro sale. It's a tough call. Just spent over $3K on D52 axles and Alcan springs that I hear shipped today. That's going to be a bunch of hours installation and a A/C unit would have to sit in the box for awhile! 🤣 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Treasure Coast Vault Posted August 9 Author Posted August 9 One thing at a time Grasshopper. While u install the axles more videos and products could hit the market. Heck it will be cooling down very soon now you could prolly coast into March and get it then. 1
jd1923 Posted August 9 Posted August 9 6 hours ago, Treasure Coast Vault said: Heck it will be cooling down very soon now you could prolly coast into March and get it then. That's what I said last year! 🤣 But you are correct. Just hope the Greenland, $1275 now with sale price and promo code, is priced as good or better next year. Or maybe an improved version 2 of these inverter A/C models gets released! We don't travel much in summer temps, but had more heat than expected in northern MN, SD, WY and CO this June where we had to put up with our Dometic A/C. Our next trip is SW Colorado late-Sept through mid-Oct. Starting at Delores CO at 7K ft elevation, to points north, 9500 ft at Sunshine Campground near Telluride, so I'm hoping to run our Atwood furnace for a couple hours before dawn vs. needing the Dometic A/C at all in the afternoons! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted August 10 Moderators Posted August 10 8 hours ago, jd1923 said: We don't travel much in summer temps, but had more heat than expected in northern MN, SD, WY and CO this June where we had to put up with our Dometic A/C. Our next trip is SW Colorado late-Sept through mid-Oct. Starting at Delores CO at 7K ft elevation, to points north, 9500 ft at Sunshine Campground near Telluride, so I'm hoping to run our Atwood furnace for a couple hours before dawn vs. needing the Dometic A/C at all in the afternoons! We’re camping in Durango now, only at 6,400’ but it was 52 degrees this morning. Late sept through mid Oct will be cold, and expect Some snow. Some campgrounds between here and Telluride close at the end of September or sometime in October! Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Treasure Coast Vault Posted August 17 Author Posted August 17 Pioneer has a Remote Thermostat now with an app like the Cielo Breeze Max. No idea if it works as well. https://www.pioneerminisplit.com/products/pioneer-wireless-smart-ac-controller
Treasure Coast Vault Posted August 25 Author Posted August 25 Here is a screenshot of the Pioneer sound level in DB in the Ollie. My friends phone showed 38 DB. He has the Penguin 2 on his custom rig (pictured) and he was amazed how quiet and how low the wattage is on the units. 2
CRM Posted August 30 Posted August 30 Right now there's 10% the Pioneer for their labor day sale. Code- LABORDAY25 1465.00 before tax. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
TimD Posted September 22 Posted September 22 I ordered the Pioneer. Will post updates as things progress. Tim 2 2021 LE2, hull 701
Treasure Coast Vault Posted September 24 Author Posted September 24 Thanks. Looking forward to the updates.
jd1923 Posted October 7 Posted October 7 On 8/30/2025 at 12:53 PM, CRM said: Right now there's 10% the Pioneer for their labor day sale. Code- LABORDAY25 1465.00 before tax. Just got another Turbro email re the Greenland Inverter A/C! List - $1499, then was 15% off $1,275. Then 20% for $1,200. Now use code FALL400, net cost $1,100! Maybe end-of-season pricing or will it be $999 for Black Friday! I’m getting close… 🤣 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted October 8 Posted October 8 18 hours ago, jd1923 said: Just got another Turbro email re the Greenland Inverter A/C! List - $1499, then was 15% off $1,275. Then 20% for $1,200. Now use code FALL400, net cost $1,100! Maybe end-of-season pricing or will it be $999 for Black Friday! I’m getting close… 🤣 Nice! Might have to jump on this even though I won't get my Ollie back until after Thanksgiving. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Geronimo John Posted November 28 Posted November 28 On 6/5/2025 at 3:01 PM, SeaDawg said: We used 3 people, safety ropes,,and two ladders. Used carpet, upside down, to slide the new unit forward, after getting it to the top. A farm back-hoe bucket worked best for our Houghton install. Also, the Dometic if still running will generally fetches $500 to $600 on Craigs List. So don't do what one fellow did that HATED his DOMETIC P2: Tossed it over the side. Which likely is not legal due to the refergerant rules. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted December 4 Posted December 4 (edited) On 11/28/2025 at 2:30 PM, Geronimo John said: A farm back-hoe bucket worked best for our Houghton install. I had a great Kubota with front-end loader 20+ years ago when we lived in N VA. But not anymore! We just installed our new Greenland Inverter A/C. It did not seem as heavy as advertised and much less weight than the Dometic P2 we removed! My son Adam and I carried the new unit onto a stand I positioned near the scaffolding at the rear of the Oliver. Another lift got it up head-height and onto the scaffolding. Then we climbed up and one more lift from the scaffold flooring to the roof of the Oliver. Easy Peasy! I had raised the scaffold platform another 6” from where it’s pictured and raised the upper bar to be level with the roofline to provide a temporary holding position. I also placed a towel on the roof since we just had it ceramic coated. We slid it on the towel. Then I went inside as Adam stayed outside for a final adjustment. I found it already 2" further up than needed. I lifted the A/C and pulled the towel down through the opening. The two of us pulled it back a little and wiggled it until the 4 corner bolts lined up nicely. Took 15 minutes at most with the scaffolding already in place. Edited December 5 by jd1923 Added pic 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
