5 minutes ago, Ronbrink said:
I suspect the “numbers” will increase somewhat as the compressor will work harder to reach and maintain temp in ambient conditions. However, likely less than what is typically seen with conventional units.
I think the highest watts draw the engineer in the Youtube video was able to see at max power was around 1100. Still far less than any of the single speed compressor units of comparable size. In our small insulated spaces I'm guessing we would be consuming around 500-700 most of the time once setpoint is met.
I read a review today, after reading several I forgot where. The reviewer stated one con was that the internal fan speed was constant, not variable speed.
This comment upset me if true. I woulda thunk variable speed compressor and external fan should have a variable speed interior fan, allowing the interior fan to match the cooling needs as the inverter compressor does. This may be why it is not as quiet as could be and he denoted it as an area of improvement. Anybody here know more?
Owners manual says it has low, med, hi, and auto.
Screenshot 2025-08-06 at 08-54-23 Manual_112124 - PYZ012AZUDCIPD-UM-min.pdf.png
Do any of the RV AC Systems have a variable speed fan for pushing the climatized Air? I had a few mini splits in homes and I never saw one that had a variable fan for the climatized air. All were 3 speeds L, M, H and Auto. None shut off after the cycle completed.
This is what makes the Cielo Breeze Max T Stat so good it shuts the fan off after the cycle completes if you want that to happen.
Having the fan turn off as the compressor cycles off definitely prevents the dreaded humidity spike that many experience!
2020 OLEll, Twin, 579:
I had the Ollie out in 95 Degree Central Florida Sunshine today and the Pioneer dropped the temperature to 78 and cycled fine. It was drawing around 685 watts. It is also very quiet. I was running off my inverter and the batteries.
My Dometic Penguin 2 will see your bet of 685 watts and easily raise you another 1100 watts! And it must also be at least 10 dB LOUDER too!
Maybe I should take advantage of the Turbro sale. It's a tough call. Just spent over $3K on D52 axles and Alcan springs that I hear shipped today. That's going to be a bunch of hours installation and a A/C unit would have to sit in the box for awhile!  🤣
6 hours ago, Treasure Coast Vault said:
Heck it will be cooling down very soon now you could prolly coast into March and get it then.
That's what I said last year! 🤣
But you are correct. Just hope the Greenland, $1275 now with sale price and promo code, is priced as good or better next year. Or maybe an improved version 2 of these inverter A/C models gets released!
We don't travel much in summer temps, but had more heat than expected in northern MN, SD, WY and CO this June where we had to put up with our Dometic A/C. Our next trip is SW Colorado late-Sept through mid-Oct. Starting at Delores CO at 7K ft elevation, to points north, 9500 ft at Sunshine Campground near Telluride, so I'm hoping to run our Atwood furnace for a couple hours before dawn vs. needing the Dometic A/C at all in the afternoons!
We’re camping in Durango now, only at 6,400’ but it was 52 degrees this morning. Late sept through mid Oct will be cold, and expect Some snow.  Some campgrounds between here and Telluride close at the end of September or sometime in October!  Mike
Right now there's 10% the Pioneer for their labor day sale.  Code- LABORDAY25
1465.00 before tax.
  • 4 weeks later...
1465.00 before tax.
Just got another Turbro email re the Greenland Inverter A/C!
List - $1499, then was 15% off $1,275. Then 20% for $1,200. Now use code FALL400, net cost $1,100!
Maybe end-of-season pricing or will it be $999 for Black Friday!
I’m getting close… 🤣
Nice! Might have to jump on this even though I won't get my Ollie back until after Thanksgiving.
On 6/5/2025 at 3:01 PM, SeaDawg said:
We used 3 people, safety ropes,,and two ladders. Used carpet, upside down, to slide the new unit forward, after getting it to the top.
A farm back-hoe bucket worked best for our Houghton install.  Also, the Dometic if still running will generally fetches $500 to $600 on Craigs List.  So don't do what one fellow did that HATED his DOMETIC P2:  Tossed it over the side.  Which likely is not legal due to the refergerant rules.
I had a great Kubota with front-end loader 20+ years ago when we lived in N VA.
But not anymore!
We just installed our new Greenland Inverter A/C. It did not seem as heavy as advertised and much less weight than the Dometic P2 we removed!
My son Adam and I carried the new unit onto a stand I positioned near the scaffolding at the rear of the Oliver. Another lift got it up head-height and onto the scaffolding. Then we climbed up and one more lift from the scaffold flooring to the roof of the Oliver. Easy Peasy!
I had raised the scaffold platform another 6” from where it’s pictured and raised the upper bar to be level with the roofline to provide a temporary holding position. I also placed a towel on the roof since we just had it ceramic coated.
We slid it on the towel. Then I went inside as Adam stayed outside for a final adjustment. I found it already 2" further up than needed. I lifted the A/C and pulled the towel down through the opening. The two of us pulled it back a little and wiggled it until the 4 corner bolts lined up nicely. Took 15 minutes at most with the scaffolding already in place.
Edited by jd1923
Added pic
  • 4 weeks later...
Don’t know if it is correct or incorrect but I was told Pioneer is owned by Gree
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
21 hours ago, Treasure Coast Vault said:
I did an overnight in the Ollie last week. Used the Pioneer on Heat. It worked perfectly and the fan cycled on and off with the unit. Great little unit.
Yep, the heat works excellent with these units. IMO even better than the AC does. Camping in North Florida at the moment and on the first night we had temps in the 20's and were able to warm up the cabin in minutes We even had to turn the heat down in the middle of the night because it got too warm.
Maybe a parent company? Not sure.
The Pioneer and Turbro Greenland are same (or similar) Inverter A/C models.
The Gree Eco-Cool, the Tosot and what was the Atmos are all the same (or similar) models, with standard on/off compressors not variable-speed inverter compressors. These are very quiet dual-fan models.
