Gliddenwoods Posted June 7 Posted June 7 I am attempting to draw bleach water into my boondock port to clean the tank. I have done this several times over the past few years. However today the port is not drawing water. I am sure (I think) I have all things set up correctly. The pump sounds normal. The port was working (and entire water system) upon return in April. The Oliver was stored in a heated building since our return. So what may I be missing? Any thoughts on checking the system. Is there a need/way to prime the pump? Thanks. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Galway Girl Posted June 7 Posted June 7 (edited) Is there any water in the tank? If completely empty you could try first to check and clear inline filter located by the pump. This may be enough to break air pocket. Next try holding your external tank above the back bumper to give a bit of gravity help to the pump. alternatively If you have access to pressurized street water try pressurizing and running a bit then turn off water at street and try pump again just in normal position. Video on priming: https://youtube.com/shorts/AEcmmXFO8ww?si=bGwmFSqB-FYKYFGw Edited June 7 by Galway Girl 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
Gliddenwoods Posted June 7 Author Posted June 7 Update. The draw from the boondock port is there, but very very weak. I put the Oliver back in normal use water use and added water to the fresh water tank. Then when I check the pump and water pressure to the two sinks the pump ran normal and very well. Went back to boondock setup and tried to draw water in back port. Again the draw from the back boondock port was very very weak. Is something blocking the line from the back boondock port to the pump...maybe? 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Moderators topgun2 Posted June 7 Moderators Posted June 7 Sounds to me like you have an "air leak" in that line from the boondocking post to the pump - i.e. you need to have what is basically a perfect seal in any connection between that boondocking port and the water pump. The first place I would check is right where you connect your hose into the boondocking port - this is where I have had "issues" in the past. Next check all hoses in and around the water pump to include that little water "filter" right at the pump - be positive that none of these are leaking and are tight. Finally, check any elbows or other connections in the run of pipes from the boondocking port to the pump. Good luck! Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted June 7 Posted June 7 (edited) As Bill @topgun2 mentioned, “right where you connect your hose into the boondocking port” the rear hose bib itself. If it wobbles, it needs tightening. There is a hex opening inside, maybe a 1/2” (13mm) hex? Not certain of size. When we bought our Oliver used 3 of 4 were loose, and since I have the correct Allen key in our tool bag for when needed again. Edited June 7 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galway Girl Posted June 7 Posted June 7 1 hour ago, jd1923 said: 1/2” (13mm) hex That’s correct. 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
Moderators mossemi Posted June 8 Moderators Posted June 8 4 hours ago, jd1923 said: 1/2” (13mm) hex Since I don’t own a 1/2" Allen wrench, I carry a 5/16" bolt and 2 nuts back to back to create a 1/2" Allen wrench. Tightening the Oliver hose bibs is the only time I remember ever needing a 1/2” Allen wrench, so I used what I had available. Mossey 4 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Gliddenwoods Posted June 8 Author Posted June 8 Yup, thats what was the problem...air leak. Thanks all. 3 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Geronimo John Posted June 8 Posted June 8 On 6/7/2025 at 8:05 AM, topgun2 said: Sounds to me like you have an "air leak" Mine has been a tired hose bibb gasket on my water transfer hose and/or the hose was not tight on the Ollie boondock connection. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
