4 hours ago, Gliddenwoods said:
lower the equalizer
If you cannot screw them as mounted.
And if you do remove any suspension bolts, be on level ground first. If not the equalizer may not want to go back in the direction it came from. 😎
Edited by jd1923
On 10/19/2025 at 8:01 AM, Ronbrink said:
The majority were SAE 1/4-28, but a few were Metric M6x1mm.
I am pretty sure I tried both of these and ended up going metric but as described earlier neither would simply screw in despite repeated efforts.  Perhaps the original zerk was the wrong size.  I was amazed it simply came off in my hand and had not fallen on the highway earlier. There did not appear to be much for threads in the hole at all but of course it was very difficult to see even with my lights and mirrors.  I would suggest Gliddenwoods have his tap ready if he is proceeding with the disassembly route and he may find little or no threads in those holes.  Of course, he has like 6 to replace whereas I only had one problem child so his more extensive approach is understandable although I feel bad he has to go that route.
As strange as this may sound, when replacing all of my stock zerks with SS 45° fittings I found that two different thread sizes were used in my Dexter suspension setup (random wet bolts). The majority were SAE 1/4-28, but a few were Metric M6x1mm.
In response to a question by @Gliddenwoods, I answered with the above statement based on mental recall; but in finding a comment made on FB from several years ago I can honestly say “it ain’t what it used to be”! I stand corrected in the following:
Edited by Ronbrink
2020 OLEll, Twin, 579:
Update and new plan.
I have determined that two of the open holes of the three missing Dexter equalizer zerk have little/no remaining threads. Replacement zerks just slip in and fall out. New larger tapped threads would be required.
So...the new plan is to replace the existing Dexter equalizers with new equalizers. I have no faith in the equalizer product on my Oliver.
I have been in touch with Dexter and I am filing a warranty claim. Not sure how the claim will go, but new equalizers will be installed either way.
Assume that you realize that this is a relatively expensive option versus simply tapping new threads and replacing the "cheap" zerks?
"Dexter offers a limited five-year warranty on its E-Z Flex equalizers and suspension systems. The warranty is valid for the original purchaser and covers defects in material and workmanship from the date of the trailer's original purchase."
"Five-year limited warranty coverage"
"The five-year warranty on equalizers and suspension components applies to all Dexter trailer axles, suspensions, and brake control systems manufactured on or after September 1, 2016."
I had a zerk that needed replacement last year.  Luckily for me, an extremely helpful hardware store guy (way up in the mountains in Colorado last year) determined that I have (at least) TWO DIFFERENT zerk thread sizes: one was metric and one was not. He sold me some 'spares' of each of those, AND tools for the metric.
Edited by Boudicca908
my Oliver has camped here
Not surprised.  I think my one zerk issue suffered the same.  Thanks for doing the deep dive into this and reporting back.
It's just hard to imagine how this happened. The grease fittings on the equalizers I removed were in there solid. The one fitting I removed (so that I could measure threads for you) had threads 5/16" in length. I had to turn it 4-5 revolutions to remove it.
I replaced the originals (one is pictured on page 1 of this thread) because the center bushings were very worn after 7 years of use (with weak springs and lose wet-bolts). No reason for grease fittings to wear and inside the suspension hanger they are quite protected from damage. Who knows why? But it is what it is.
I purchased two of these:
https://www.etrailer.com/Trailer-Suspension-Parts/Dexter/013-144-03.html
Topgun, (and others)
You (and others) have referred tl "cheap" zerks. Without regard to cost what brand(s) of zerks would you purchase if you wanted to obtain the very best zerks available?
(Others, please weigh in.)
Thanks
As with anything else, I'm sure that there are some zerks that are better made (materials, craftsmanship, etc.) than others.  However, given the relatively simple design and purpose of these things, I've never given the cost of a zerk or where or how its made much thought.  Heck, you can buy as many of these little things as you most likely could ever use for much less than $50.
Having said this - I would strongly suggest that for any new zerks and/or even old zerks, the usage of protective caps over the zerks helps keep them cleaner and less likely to get "plugged" by keep most dirt out of that little spring loaded ball that is in the end of the zerk.
Project/saga Update,
Dexter Axle Company has agreed to provide me with two new replacement 13-144 equalizers at no cost to me. Shipment delivery expected next.
Now for installation. Zerk correct tightness will be confirmed.
End of story...I hope.
