Everything seems to work fine except one place and that's the temp control.  After I set the temp the furnace keeps running and doesn't turn off when it reaches the temp I set. Never had this issue before.  My guess is the temp sensor has gone bad but, I can't seem to find where it's located. I can turn the furnace off manually.  Does anyone have any suggestions on where to look and how to check to see if it works correctly?
Hiroshi
2023 Oliver Elite #1299
2024 Lexus GX550 Overtrail
Hull #? Signature? Please update asap...
Edited by jd1923
Sorry but I don't have one of those "fancy" things.  But, I assume that you've submitted a Service ticket?
Do you have the CP Plus wall control unit for your Truma furnace?  Could you attach a photo of the display on the unit when the furnace is still running but the set temperature has been reached?
And, an update to your footer showing hull number, model year and installed options would be very useful to those of us trying to help.
Yes, mine is a Truma CP plus. I've tried different temps and it doesn't matter.  It justr keeps running past the set temp.  i.e.62 and still heating at 72 degrees. Need to turn if off manually.  I turned in a service ticket and can't get anywhere with them. They just don't seem to understand what I am saying. Finally gave up along with my AC problem. It you guys that saved my hide on the AC.  Forgot, it's a 2021 model Elite 1
Edited by Buddhabelly
Hiroshi
The photo of the cat is cute, but a photo of the CP Plus wall unit  display when the furnace is still running, when the temp in the cabin is beyond the set temp, would be more useful.  It might enable progress toward diagnosis of your issue.
My error.  This is a pic of my Truma and a pic of the temp settng running and a differnt temp gauge so the difference after running for awhile.  Was 70 degrees inside and furnace still running.  I can turn it off manually but, doesn't turn itself off when it reaches it's temperature. Any suggestions would help...
Hiroshi
Reading your post peaked my curiosity about the Truma, particularly from the mention of a Temperature Sensor. . .  which is typically part of the thermostat.  So I looked-up the Combi and sure enough, there is a Temperature Sensor that is separate from the control panel.
Accordingly, there is a temperature off-set adjustment in the control panel to account for temperature variances depending on where the sensor is mounted verses the room temperature.  Perhaps that was inadvertently reset, which could account for your temperature miss-match.  I’d check that first.  Review your manual for instructions on how to change the off-set.
I don’t know where the sensor could be mounted, but it shouldn’t be too difficult to find by following the wire from the unit. It’s probably a simple thermistor, basically a resistor that changes resistance with temperature change.  These are easy to test with a multimeter in the Ohms setting. If the resistance value changes with a little heat applied from your fingers, then it’s probably okay.
Let us know what you find and good luck.  Cheers!  Geoff
Thanks for trying to help me out guys,  Just can't figure it out so I'm having an electrican come over and see what's going on  I'll let you know what he finds. Hope he dosen't make be feel stupid.
Hiroshi
  • 1 month later...
Forgot, Electrican found the issues with my temp issue. The sensor and Elite 1 is behind the front speaker in the corner.  Unpluged the sensor, blew out with canned air and reinstalled it and it works fine. Thinks it might have been a bad connection from the get go. Who know,  it works now and that's all that matters.  Thanks guys for trying to help. Appreciate it.
Hiroshi
