I’m looking for a sanity check from other Oliver owners.
I’m attending evening classes in Clemson (Tue–Thu, 6–10 pm) and have a long-term spot at an RV park during the week. My home base is ~90 minutes away on winding, wildlife-heavy roads, so I head home Friday mornings and return Tuesday afternoons. That means the trailer will often sit unattended for ~4 days at a time during February.
My concern is avoiding repeated winterize/de-winterize cycles (likely 15–16 times) while still protecting plumbing during what’s shaping up to be a colder-than-usual stretch.
Here’s the approach I’m leaning toward:
Plan
  • Leave the Oliver “wet” (water system active, not winterized)
  • Use the propane furnace as the primary freeze protection
    • Thermostat set around 45–48°F
    • Furnace on continuously when unattended
  • Use the Houghton heat pump only when occupied (not relying on it for freeze protection)
  • When leaving for multiple days:
    • Disconnect the exterior water hose
    • Blow out the hose and city-water inlet (trailer plumbing remains live)
  • Cabinet doors open under sinks
  • Fresh propane tanks topped off
  • Batteries in good condition (furnace blower dependency)
What I’m avoiding
  • Space heaters while unattended
  • Relying on heat tape (only partial coverage)
  • Heat pump alone below freezing
  • Full winterization every week (wear on fittings and check valves)
Added insurance
  • Remote temperature sensors inside the cabin and near plumbing/underbelly
  • Propane level monitoring
The thinking is that the Oliver’s furnace-heated plumbing spaces + a modest thermostat setting should keep everything above freezing, while disconnecting the exterior hose removes the most failure-prone component.
I’d appreciate feedback from anyone who has done something similar, especially during prolonged cold snaps. Anything I’m overlooking specific to the Oliver layout?
Thanks in advance — trying to balance realism, safety, and not crawling under the trailer 16 times this winter.
1 hour ago, Hoosier said:
I’d appreciate feedback…
I believe you have a solid thoughtful plan. It’s about what I do all winter long since we travel on-n-off and get spells of overnight lows to 20F or below.
Instead of doors open, some of us have added vents to pull air through the basement when the furnace is running.
Given you can check temps remotely, you’re also covered for the unforeseeable! 😎
Edited by jd1923
You have a very good start.  The odds of another deep freeze this weekend is likely 100%.  From the forecast, it is already heading your way.  I would suggest:
·        Pulling the bed mattress and vertically stacking them in the hallway.  Then pull the fiberglass covers to expose the basement to the cabin interior.
·        Ditto for the dinette seating and covers.
·        In the bathroom if you have installed one of these you are golden.  Open it.
·        If not, then consider removing the towel bar cubby from under the sink.
·        Open the basement hatch in the rear center storage if you have one.  Open the wardrobe and bathroom doors.
·        Insulate the battery box and basement outside hatches.
If you have shore power, acquire a small 120V desk fan to circulate air around the opened up cabin.
The items above can easily be done very quickly.  Of course the hatch takes a lot longer to do. But it opens up quite a bit of storage as a prime benefit.
Edited by Geronimo John
I like the hatch mod. Is that sized to go where the towel bar goes? Do I have to remove any fiberglass to fit, if so I'd probably wait until spring.
The hatch that is mentioned to open is located at the rear of the trailer (if you have one- (it was a option)) that goes into the cellar (basement) storage area. The water feed piping from the campground water connection runs in this cellar (basement) storage area.
The towel bar rack is in the bathroom. There are 4 screws (covered by the white plast covers). Take out the screws and remove the bar rack. The bar rack is likely held in place by some caulking.
Edited by dewdev
I also store my Oliver remotely outdoors through the winter but do not winterize.  All above advice is solid.  I use remote temperature sensors and have found that the coldest spot in the basement is in the lower rear of the trailer (storage area) where the water lines run.  If that location stays above freezing, I am confident that nothing will freeze.  The one additional thing I did was change out my thermostat to one with remote monitoring and control.  I chose a Micro-air Easy Touch RV thermostat.  It has both remote wifi monitoring and blutooth.
 https://www.micro-air.com/products_easytouch_rv_thermostat_touchscreen.cfm
When temperatures are forecast to stay well above freezing, I can either turn the furnace off (remotely) or set it low (42-45 degrees).  When the forecast is for below freezing temps, I turn it up to around 50.  My remote sensor will send an alert to my phone if the rear basement approaches freezing temps and I can then turn the thermostat up even more from home.  When daytime temps rise above freezing again, I turn the thermostat down to save propane.
Steve and Lornie
Oregon
YES.  Here is Art's (MaxBurner) approach to adding space under the sink.  I don't know if he was the first to do so, but I captured his post and used it.  it DOES require mod and does provides significant additional storage space.  When I did mine, lowered the floor to well below the bottom of the hatch, and extended it as far left and right to gain even more space.
Not an easy project, but is one that is not all that hard to do if you are handy.
DIY - Art's Bathroom Under Sink Storage Mod.docx
Hoosier:  Especially if you down the road you may do the bathroom cabinet hatch, cutting the existing towell fixture caulk and removing the unit for your unique situtation would be advisable.  You could temp reinstall eacy week, and next spring permenantly reinstall or do the hatch DIY.  Don't forget to keep the the bathroom door open.  Use of mag catches has been done by many.  But for now, take a cloths hanger (Don't cut it) and just bend it into a long triangle with the hook at the top.  Slip the body under the dinette cushion with the coat hanger hook holding the door open.  When you get pack, unhook the door and push the coat hanger under the cushion.  Easy.
As Max Burner's spouse was, mine is loving having the sink storage area all to herself.  Happy wife, happy life.
I wasn't interested in having a hatch under the bathroom sink. To do so, you lose the towel bars and external storage. However, you need to get in there to straighten out the heater ducting and to add vents. Just get a flexible putty knife under the panel, pry it off and then remove the remaining caulk. I went with a rubber seal and 4 screws to hold the panel which can be removed again when needed for service.
I also do not believe in winter storage that includes having beds on their sides and/or panels to basement areas open for periods of time. Add ventilation, do it right, and then you can leave beds and panels alone. The link below shows the mods I've made.
Exactly, I also have a Ruuvi temp sensor on the rear wall of the basement. When the furnace is running set low at 45F, it can be 20F outdoors and that coldest interior area will be just above 32F. If not, set the thermostat a little higher.
Readers should be aware that you live in AZ.  And equally important you generally are in relative proximity of your Ollie should weather turn terrible.
Those who have their trailers where hard freezes HAPPENl and can't always get quick response to their Ollie easily..... may want to consider your approach as not being ideal for their location.  But for your situtaiton it is easy and effective.
Please remember the context of this thread, re leaving the trailer with plumbing ready, weekends in Clemson SC. It’s not about long storage in cold climates!
Average January low in Clemson is 36F and in Prescott AZ it’s 22F (it’s not Phoenix up here)! Average Jan highs in both towns are in the low 50s. The good weather in Clemson SC is certainly more mild than in Prescott AZ.
Based on the 36F average, 2 of 3 winter weekends in Clemson will stay above freezing. I still contend @Hoosier’s original plan is good as was written!
Edited by jd1923
22 hours ago, Geronimo John said:
"Those who have their trailers where hard freezes HAPPEN"
JD:
I admit that my living in Hawaii makes me a "Weather Woosie", but the current weather lows at Clemson SC of 15, 15, and 16 degrees are three nights while he was gone each with hard freeze conditions pending.  Below cut and pasted for reading enlightenment.
So not being winterized while away, with hard freezed inbound, with the furnnace on low.....  opening the basement up to the cabin is easy insurance with such conditions inbound.
I don't care!  Cold is cold and at 22 degrees being outside in the snow is no fun.
On the other hand - a couple of runs down the hill will get the heart pumping.
Grab a board and hit the waves for me - please.
I may do a bathroom hatch some day but for expediency, I experimented with a quick and simple (and reversible) hack designed to achieve greater heating of the area under the sink while also adding a return vent from the bathroom into the basement to improve heating in the bathroom  (My 2020 didn't have a return vent in the bathroom like the newer models).  I had also concluded, as have most, that the heat supply vent under the TP was essentially useless because of the long flex-duct run to the bathroom.  It never did supply much heat.
What I did was temporarily removed the towel bar rack, disconnected the flex duct from the heat vent under the TP holder, dropped the flex duct to the floor (where it heats the area under the sink) and replaced the towel bar rack.  That gave me a return vent in the bathroom (without cutting a new hole) that pulls heated air from the cabin into the bathroom and then into the space under the sink, while the loose flex duct also supplies additional heat to the area under the sink.  You can tell it is pulling a measurable amount of air through the bathroom into the sink cavity by looking at the dangling TP moving when the furnace is running.  I now have two cold weather seasons of experience with this setup and I will never go back.
As long as I keep the bathroom door slightly open against the closed twist lock, the bathroom stays warmer than it ever did with the flex duct attached to the vent under the TP.  Also, I have noticed that the bathroom feels a little bit warmer when a late night visit to the bathroom is called for, likely due to less radiant heat loss from my (un-shirted) body, due to the warmer surface of the fiberglass surrounding the sink cavity.  The additional heat under the sink cavity also improves the heating under the kitchen sink area as the heat from the sink cavity circulates rearward to be recirculated through the furnace.
Steve and Lornie
Oregon
It looks like your Ollie and those winding roads got a lot of snow and several days of hard freeze too.  I hope that you will be able to get back safely after the roads get cleared and the thaw allows.  Glad you reached out to optimize your rig from being damaged.
We all wish you a safe return to your Ollie.
