Mroth Posted Sunday at 08:27 PM Posted Sunday at 08:27 PM Hello all, do you simply pry these white caps off? I am getting some resistance, so I wanted to make sure before I go to town on them. thanks Marc 2024 LE2 hull #1502
tallmandan Posted Sunday at 10:11 PM Posted Sunday at 10:11 PM Hello Marc, Yes. There is a phillips screw head under that plastic cap. A gentle but firm pry should pop them off. I think I used a plastic putty knife but a small standard screwdriver should work, being carefull not to damage the fiberglass. You will also have to carefully break (slice) the bead of silicone caulk around the edge of the access panel to remove it. A new sharp plastic razor blade should work without damaging the fiberglass. Suggest adding your Hull number to your posts so folks know what year your trailer/equipment is. Hope that helps 2 2020 Elite II #627, 2021 Silverado 1500 3.0L Duramax, Colorado
Mroth Posted Sunday at 11:14 PM Author Posted Sunday at 11:14 PM Thanks, I wasn’t able to figure out how to add my hull # to my signature, but it’s 2024 hull 1502. I got it off and cleaned up. is this a vent stack or anti siphon setup? 2024 LE2 hull #1502
Mroth Posted Sunday at 11:41 PM Author Posted Sunday at 11:41 PM I figured it out It’s the backflow/ siphon break for the black tank flush 3 2024 LE2 hull #1502
Galway Girl Posted Sunday at 11:49 PM Posted Sunday at 11:49 PM (edited) 53 minutes ago, Mroth said: is this a vent stack or anti siphon setup? To make changes in your signature: Click on your name in the upper right corner of the page. It will pop open this window: Look under SETTINGS and click on account settings. In the settings tab that opens up...near bottom you'll see signature with the pencil icon. Click on that signature line and it will pop open...you can add what you want including maps of your travels, hull # etc. Craig That brass port is the anti-siphon air gap from your black tank flush. The inlet to your external black flush hose bib on the side of the trailer (down low just below the dinette window) runs up to that antiphon then back down to the side of your black tank which is where it connects to the wash head. Once done flushing, that air breaker enables water to drain back out of the inlet port line out the street connection to your flush port. The air gap is an anti suction device that keeps black tank water from coming back out the exterior flush lines. It also makes that line self draining to prevent freeze ups in the flush line. (After you take your hose off after flushing...you'll see about a quart of water drain back out the connection.) Hope that helps. Edited yesterday at 12:10 AM by Galway Girl 2 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Mroth Posted 17 hours ago Author Posted 17 hours ago Thank you, I think I was able to add the signature. 2024 LE2 hull #1502
Moderators topgun2 Posted 16 hours ago Moderators Posted 16 hours ago 1 hour ago, Mroth said: I think I was able to add the signature. Yes - your year and hull # now appear - thanks for doing this. Of course, you can add other information , tow vehicle, battery configuration, inverter size, fridge, furnace, and hot water configurations, etc. if you want. Take a look at the signatures of others to get ideas. All these details are not necessary, but, they do help the members of the Forum to help you in the event that arises again. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted 13 hours ago Posted 13 hours ago (edited) 17 hours ago, Mroth said: It's interesting how OTT installed your black tank waste valve, laying on an angle in the center of the area under the front dinette seat! Mine was installed straight up vertically in the corner. There are pluses and minuses of both. Further up and on an angle, the pull on the 144” cable would be smoother but it takes away from the storage space. I had to replace our cable since it got kinked from the hard angle (see pic below), and even with a brand new cable it's still not easy to pull. We have a lot of storage though, where a large basket fits nicely down there! Every Oliver is truly unique. Edited 12 hours ago by jd1923 added picture Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators mossemi Posted 12 hours ago Moderators Posted 12 hours ago (edited) 53 minutes ago, jd1923 said: It's interesting how OTT installed your black tank waste valve, laying on an angle in the center of the area under the front dinette seat! That is interesting, I wonder if there is an electric valve option that we cannot see in that view? That is the first PVC drain pipe I have seen Oliver use. Mossey Edited 12 hours ago by mossemi 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
jd1923 Posted 12 hours ago Posted 12 hours ago (edited) 5 minutes ago, mossemi said: That is the first PVC drain pipe I have seen Oliver use. Yep, ours are ABS. And don’t the new Olivers have electric waste valves and something different for the pull handle for the bathroom gray? I replaced that one with electric but an electric valve would not fit on the black tank waste valve where they plumbed ours without replacing all the ABS. Edited 12 hours ago by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Mroth Posted 9 hours ago Author Posted 9 hours ago (edited) that is interesting, the valve separating the shower from the grey tank is also significantly further aft in my trailer compared to yours. My valve cables operate smoothly. My valves are manual, not electric. Not sure why they went PVC for waste lines, I never really thought about that. Not sure it really makes a functional difference Edited 9 hours ago by Mroth Clarification 2024 LE2 hull #1502
jd1923 Posted 4 hours ago Posted 4 hours ago (edited) 4 hours ago, Mroth said: Not sure it really makes a functional difference. ABS (black) pipe is for waste lines, much less expensive pipe. PVC is used for fresh water and sometimes exposed sink drains, etc. You can use PVC in place of ABS like in your Oliver plumbing, but ABS is only used for gray and black waste plumbing, not rated for fresh water. Edited 4 hours ago by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steve Morris Posted 2 hours ago Posted 2 hours ago 10 hours ago, jd1923 said: but it takes away from the storage space Our 2023 is the same, and we were surprised to see it in the middle of the compartment, especially after seeing older models with the vacuum formed tray in there. But I suspect it is to ease the cable angle as much as to prevent using the bay for storage. Our TP and paper towels get stored in there. 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
