We have Elite II Pro package with 3 Lithionics batteries. Currently boondocking near Capital Reef Utah. I checked batteries mid-morning with good sun and saw 2-3 amp draw on each battery. I came back after a good day of sun to same draw and batteries down 15% in a day with no usage. Inverter off. Norcold refrigerator on propane.
Here’s what I’ve done
Restarted inverter
Reset inverter breaker (red switch streetside bed)
Power cycled batteries
Reset all AC breakers while watching amp load - nothing changed
pulled each DC fuse one at a time - no change
 checked all wire connections in dinette by pantry. No loose wires
Batteries are taking charge from generator but show same loss as soon as generator turned off.
Any ideas where to check next?
Thanks in advance Oliver crew!
Edited by DaveAndBecky_NorthernMI
2022 Oliver Elite II Hull#1047 "Saunter"
Solar Pro 390 aH Lithionics
2022 Ram 1500 5.7L Hemi
ALAKAZCOILINIAKSMIMONENVNMNCOHSCTNTXUTWV
You should be getting +A from your solar. So 2-3 amps/battery, is say -8A total with everything off? You should be getting approx. +12A from your solar, given the fridge on LP. That means during the day your about net -20A. That's a large draw!
The one time this happened to us, I had the hot water heater on AC (electric). Are you certain no change with all the breakers OFF? You wrote you restarted the inverter. Did you leave the inverter OFF for a period of time to measure draw with it off? Do that to be sure it is not anything 120VAC provided by the inverter.
Hard to imagine anything DC taking that much power. Do you have any special DC accessories?
Also, pull your 30A jack fuses, one at a time. A jack could perhaps be shorted in a way where it's drawing power to ground through the motor. Do you have a fridge cooling fan or other fans? Battery heaters ON?
I cannot think of anything else DC that could draw so much amperage. Hope the best for you two! Bummer to have this worry when you're in such a beautiful place.
JD
we have Truma on demand hot water. Turned off. No change.
Inverter I only turned off for a short time. Can try shutting off for longer period tomorrow.
No custom fridge cooling fans. I do think Norcold fan has gotten louder. I turned off fridge and still see draw.  No special DC accessories.
i will try jack fuses in AM.
Check to make sure that your brake "breakaway switch" wasn't  accidentally pulled out.  If so, the electric brakes have been on the whole time.
Four brakes would draw  3-4 amps each.  If you were reading 2-3 amps draw on your Lithionics battery App, then that's only one of the 3 batteries.  So it's actually 9-12 amps.  Add in the solar input and it's about right for what the brakes would draw.
Good luck, Geoff
Edited by Snackchaser
