I’ve never liked Furrion entertainment center, it’s not user friendly and the front panel is difficult to read in low light. The tiny remote is absolutely terrible, and the larger upgrade remote isn't much better.  I usually control it with the phone app when I remember where to find it, for some reason they called it "ES Control,” and it constantly drops out.  The tech is outdated.
Iv’e wanted to upgrade it for years, but never found a unit that met my requirements and justified the expense:
  • Has to fit into the existing cutout
  • Controls that are intuitive and easy-to-read
  • Decent remote control
  • HDMI ARC ports on front and back (not the cheap HDMI pass-through ports)
  • Current Bluetooth technology
  • Two speaker zones
  • Cost under $200
I found IRV Technology’s model IRV62 for a $180, and it had everything I wanted.   https://a.co/d/0dODdwBi  The controls couldn’t be simpler or easier to read.  It does have a few less features than the Furrion, but nothing that will be missed.  Like only 2 speaker zones compared to Furrion’s 3 and the Optical audio port that caused horrible sounding audio phasing issues between TV and stereo speakers.
The IVR62 was a close fit on paper.  But unfortunately Oliver had cut an oversized opening for the Furrion and miss-drilled extra mounting holes.  Consequently, the new faceplate didn’t quite cover the extra holes, and the new mounting holes were on the very edge of the cutout.  This was resolved with white JB weld on the edge of the oversized cutout to strengthen the screw holes, and I made a thin 3-D printed bezel that covers the extra holes.  It’s not even noticeable.  The print file is available if anyone has the same problem, or I made extra bezels if anyone needs one.
The rest of the installation was easy, although it took a minute to figure out how the Furrion was mounted.  There are 4 screws behind top and bottom trim pieces.  These trims have small notches on the ends where they can be popped off with a screwdriver.
It’s highly recommended to identify and mark each of the 4 speaker cables before cutting the connections.  Use the wire color code legend on the back of the Furrion case to identify the right rear, left rear, right front, and left front.   Also the IRV’s yellow “Bat” wire and the fused red “+12” wire are both connected to the Olivers hot wire, which was purple in my case.  Other than that, the wiring is straight forward.
The new stereo is so much easier to use, it works seamlessly with Bluetooth and the TV, and it sounds better too.  I’ll be using it more often now that I don’t need a flashlight and reading glasses to operate it.
Cheers!  Geoff
IMG_0161.thumb.jpeg.21302f537af7e106fc1ea44c5fb715af.jpegIMG_0167.thumb.jpeg.001a18995bef222e5ce995c1d4fda993.jpegIMG_0165.thumb.jpeg.99358bffe633c4a0a4fc422fa153aac2.jpegIMG_0168.thumb.jpeg.db2e550f1eed825ea0a24b0e5b7c8bf5.jpegIMG_0172.thumb.jpeg.b8d9f6ad1d833e55e9e8969e76c54d92.jpeg
Edited by Snackchaser
