Gliddenwoods Posted yesterday at 01:50 PM Posted yesterday at 01:50 PM Morning, I know a lot (too much) has already been written on replacing the very very loud AC systems but I have just one simple(?) question. This relates to my very limited "extra" ceiling height room above my Oliver in my storage building. What are the two "best" low (no higher than existing Oliver installed) profile quiet AC to replace the current beast on my 2022 Oliver? Why? Thanks (FYI: From Wisconsin and we don't use AC here. However, just returned from the 100 degree SW and rethinking the topic.) 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Geronimo John Posted 3 hours ago Posted 3 hours ago Owners/Moderators: I had heard a rumor that OTT is using/considering the Houghton 3400 on new builds. Can this be confirmed? If so: Does it have the fan on contineously issue resolved so that it can be set to turn off the fan with the compressor? Does it have remote thermistor? Does it condensate drain by tube option for those with no height concerns? Please advise. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted 3 hours ago Posted 3 hours ago (edited) 40 minutes ago, Geronimo John said: I had heard a rumor that OTT is using/considering the Houghton 3400 on new builds. Can this be confirmed? I read they resorted to the Dometic FreshJet, but not certain of the series model. That said however, in viewing the recently released ‘2027 Oliver Legacy Elite ll Platinum Model Walkthrough’ video, a Dometic is perched atop! AI states the Dometic FreshJet sits slightly lower on the roof than the Penguin ll. Dometic FrestJet (Series 5): Measures exactly 10.5 inches in height. Dometic Penguin ll: Measures 11.25 inches in height. When AI is asked is the FreshJet is quieter than the Penguin ll: Yes, the Dometic FreshJet is significantly quieter than the Penguin ll. I’m only presenting facts, not a personal recommendation. Edited 2 hours ago by Ronbrink Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Galway Girl Posted 2 hours ago Posted 2 hours ago (edited) I had just asked last week about what they are upgrading older units to now days at the factory, Dometic Freshjet was the reply. Price was $4600.00 for upgrade. Edited 59 minutes ago by Galway Girl 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
CRM Posted 59 minutes ago Posted 59 minutes ago 2 hours ago, Geronimo John said: Owners/Moderators: I had heard a rumor that OTT is using/considering the Houghton 3400 on new builds. Can this be confirmed? If so: The new Apex X23 model comes with a Houghton 48 volt AC / heat pump.. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
