Hey Gang,Ā
It's past time to retire the Penguin AC for something quieter and more suited to our eventual upgrade to a 600ah Lithium system.Ā
I know we have owners with the Truma, Houghton, and dometic freshjet 3 series.Ā  Ā (Thanks to Roadlotus for her write up on the FJ3)
I am leaning toward the new Dometic Freshjet 4 or 5 series.Ā  Ā Reasons include:Ā  A) Quieter than the penguin (what isn't)Ā  Ā B) would be easy to fit into the existing structureĀ  C) Service almost anywhere D) Has iphone app control as well as the Air Distribution Box controlĀ  Ā and E)Ā  Should be energy efficient enough to allow a few hours operation on a 600 ah system.Ā
I was considering the Furrion Chillcube but the possibility of condensate overrunning the pan down the side of the trailer is a deal killer.Ā
Just wanted to ask what I might not be considering on the above list OR if there is an outlier that is not on my Radar.Ā
TIY,
Scotty
Gregg & Donna Scott andĀ Missy the Westie Ā - Ā  Ā The Flying Sea Turtle - 2016 Hull # 145Ā  Ā 2024 Nissan Titan XD -Ā  Ā Western NC
Ā
Ā
Scotty (or Greg), you may know I’m the only one here with the Chill Cube installed on an Oliver. So you may say I’m biased!
I just ran a test which I’ll post soon on my Chill Cube thread. Ran it for one full week on batteries, set at 80F (it’s parked at home). Daily high temps low 90s! Without A/C with the AZ sun the cabin would be high 90s or more.
Not a drop of condensate down the hull. The Chill Cube has a condensate trough that the condenser fan runs through, picking up the water like a water wheel. But can’t promise there wouldn’t be any in humid climates. There would be much less.
Ran it for 7 days using on average 96 Ah per day ONLY! We have 320W rooftop solar which adds power in addition to the 96. Your Oliver and ours are both 2016 models. Maybe you have the same solar.
Without solar say it adds to 240 Ah per 24 hours. That’s about 10A per hour average. On full blast, it pulls 60A but not for long. Our Dometic P2 took 150A minimum and would take forever to cool down.
I'm starting another test this week with set temp at 74F. 80F is a good summer storage temp and at 74F it will be very comfortable inside. I'll bet I can run it 3-4 days at 74F in 90F+ heat. I cold never imagine this when we had LA batteries and the awful Dometic.
BTW, I’m talking DC amps that can be read with Bluetooth connection to a shunt. We do everything on 900 Ah batteries, usually un-plugged (600 Ah is a good number).
I now know for a fact the Chill cube takes 30-50% of the power compared to ANY RV A/C in the market today that is not an inverter or variable speed compressor!
If there is a little drip, level front and curbside jacks up 1/2ā€ and the excess will run down the back corner. It’s basically distilled water, so will not stain the fiberglass like rain water catching all the chems they put in our skies.
The Chill Cube will run on batteries twice as long as the Freshjet and it’s also quieter than any other model out there, no compressor bang like the Truma, Houghton, Tosot or any US market Dometic product.
And if you’re dead set on the condensate issue, the Freshjet is your only choice.
You couldn’t pay me to own anything else now that we’ve experience the Chill Cube (a non-paid advertisement)!Ā šŸ˜Ž
Edited by jd1923
In humid climates there will be more than just a little drip, but being slightly off level as you suggest will divert any runoff to a rear corner. Even though condensate is like distilled water, be assured there will be some staining from contaminants it picks up as it leaves the condenser and drains outward. Maintaining adequate wax on the gelcoat will help reduce said staining and further cleanup of any resulting streaks.Ā
Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2ā€ receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Having the condensate collect in pans in the DPll and drain via the inner hull tube Oliver installs is not without issue. Many have experienced, self included, condensate water dripping inside the cabin either from drain line blockage, improper leveling on setup or excessive humidity conditions. I have no regrets abandoning the tube drain with my chosen a/c replacement and no further worry of internal leakage. Just say’n!
Another Chill Cube customer here however I've not installed it yet.Ā  I waited until the heat pump version came out to make my purchase.Ā  I didn't see the no drain system as a problem.Ā  I have a small window unit at my vacation home that uses the same method of throwing condensate on the condensing coil for additional evaporative cooling.Ā  It sounds like a waterfall when it starts but has never dripped.Ā  Now, I realize I'm making a big leap of faith the Cube will work the same but I'm not too worried if a little condensate flows off the trailer.
We're still rocking lead acid batteries and don't have an inverter.Ā  My goal wasn't energy conservation as we're usually plugged in or occasionally on a small generator at lunch stops.Ā  My goal was quiet and humidity control in the trailer.Ā  My hope is when the Cube ramps down to a constant run state, it will achieve both.Ā  Fingers crossed
Big Texas – 2018 Elite II, Twin Bed, Hull #306
2024 RAM 2500 6.7L Cummins, Weigh Safe hitch
My friend Ron, of course you know! Our son Adam played a USTA Tennis Tournament in the very nice Houston suburb of Clear Lake 15 years ago. I remember sitting outdoors, large-brimmed hat on for the sun, I was drippin' wet just watching! šŸ˜ŽĀ The 16-year-old boys had drenched shirts before the first set was won.
Traveling the west vs. the gulf states is night and day. Wish we had a forum member in the east with a Chill Cube for comparison.
The Chill Cube condenser fan wets the condenser by design. To my knowledge, no other A/C unit has this feature (perhaps Furrion has a patent). The water-cooled condenser increases the overall cooling efficiency.
In very dry climates (the spring is our windy dry season), the little bit of condensate it pulls out of the dry air quickly returns to the air (evaporates). I have yet to see any condensate drip on our hull.Ā When greater cooling is needed and it's humid, the fan should create a visible mist blowing from the condenser coils. More mist means less drip. But when the volume of condensate gets large it would overflow the condensate trough and run down the hull.
I have to say ..... I think jd1923 may have converted me to the Church of the Furrion Chill Cube.Ā
I was very fixated on condensate running down the outside of the trailer and NOT on the amount of power needed to run the damn thing.Ā
I've been doing some research on power draw on this A/C vs. the dometic and other compressor types and am pretty much amazed.Ā  All in all about half the power needed to run the Chill Cube.Ā  Ā And quiet.Ā  Ā
We are scheduled for a lithium upgrade toward the end of the year and will have the A/C replaced at the same time.Ā  Ā Right now... I am going with the Chill Cube.Ā
Thanks JD for the help on this.Ā  Ā Appreciate it.Ā  Ā
ScottyĀ
Ā
Ā
Thanks JD for the help on this.Ā  Ā Appreciate it.Ā  Ā ScottyĀ
You're welcome! And you will not be sorry. If you're waiting to later in the year, we won't get real feedback from you until the following summer. Looking forward to seeing results from somebody who lives east where humidity is certainly a climate factor in A/C performance,
I've tried running a couple studies and each time I failed to capture full data every 24 hours, but I have some preliminary findings.
With highs in the low 90s for a full week, lows high 60s, I set temp on the Chill Cube at 80F (cabin temp on Ruuvi showed 79F consistently) which is a good set temp for parking the Oliver outdoors in the summer. I got good data for three 24-hr periods which averaged at 108 Ah used per 24 hours, A/C running 24x7. I know I I took snapshots every day for a week but don't get me started on iCloud because sometimes pics just disappear off my phone!
Beyond the 3 days of verified data, I know for a fact that I ran the Chill Cube for ONE (1) FULL WEEK on our 900 Ahs! After a week SOC was down to a low 18%. This translates to 105 Ah per day. Keep in mind, when low 90s outside, and if there was no A/C running, the Oliver Cabin would get up to 99F min or low 100s!
Then I tried another test, A/C set temp at 74F which is a comfortable temp for camping. I was able to run our A/C for four (4) full days, 4x 24x7, again highs low 90s. Daily Ah used wasĀ 135, 209, 270, 136. I have no idea why yhe numbers varied in this way as the weather was rather consistent. Average over 4 days is 188 Ah per day. I cannot believe how efficient this runs.
One additional factor: these numbers are net of the fact we have 320W rooftop solar which produces 10-20A per hour half the day. Next test I should account for this or just turn off the SC so everything is pulling from the 900 Ah Epoch batteries.Ā
Did you know the Dometic P2 once it gets past the Soft Start procedures draws 150A or higher? In this short test, the Furrion Chill Cube on average took as much power cooling for 24 hours as the Dometic P2 would use in one hour and fifteen minutes.
Scotty, I'm seeing much better savings than "aboutĀ half theĀ power!" But camping in hot humid times in the east, you should half the power, or perhaps 40%. Can't wait to see!Ā
I'll run a better test in a few weeks when we get daily highs in the high 90s. It just cooled off here and thankfully for the next week or two we're back to spring-like temps in the low 80s.Ā šŸ˜Ž
Edited by jd1923
With my Turbro Inverter, once it reaches set temp I'm seeing between 250-600 watts during the day in 85-95 degree weather with 80+ humidity so you're probably pretty close with your numbers- and we keep the inside temps low, too... around 70-72. Haven't monitored during the night yet but obviously the watts draw will be even lower.Ā
Don't know why anyone who boondocks would buy anything but an inverter AC/Heat pump.Ā
2010 Elite II Hull #45, the first LE2 sold.Ā  2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
I guess not pulling the trigger on replacing the NOISY Dometic (Penguin 2?) A/C that came with our LE2 back in early 2022 has opened the field for more upgrade options?Ā
I’m still hoping to DIY this project - so is the latest consensus the ā€œChill Cubeā€? Is some kind of external roof support still an issue?Ā
NOT on lithium or solar, almost always plugged in, so AH’s are not on our criteria list.Ā
We like the condensate drains through the tubes between the hulls as opposed to running off the roof - but not opposed to running it through an external tube if that is an option.Ā
One big reason that we haven’t rushed into anything as of yet is that we -rarely- use the A/C. It’s got to get to the high 80’s before we opt to break out the earplugs, crank the TV volume to 100, and run the A/C until we get to 70-something and shut it off again.Ā
I guess I’ll run the original equipment until it stops working at this rate. (That, and avoid Texas in August…)
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
(17.9mpg towing, 35mpg clean)
RealTruck hard tonneau cover
Rove R2-4K DashCams
Ā
That's what I thought. Living in Arizona we do not travel in the summer months. Then a couple experiences changed my thinking!
Over two years ago we did a SW Utah trip, from Apr 21 to May 7, 2024. You wouldn't think it would get hot, springtime at high elevation, and most of the trip was fine. The day we left, we dropped down about 3K ft to US-93 and we boondocked in Wikieup, AZ. It was 93F when we got there and fortunately by 9PM it was cool enough to be in the cabin again. Back then we still had lead acid and the Dometic P2 so all we had tp remove cabin heat was the Maxxfan.
Our next stop was to be Valley of Fire SP, NV where we had booked a dry camping spot. Quite a fitting name, given the forecast showed 99F highs for the next 2 days of our reservation. We wasted that money, instead having to book an electric site at the north end of Lake Meade.
Plugged in to run the G-awful Dometic A/C. I had to wear noise-cancelling headphones to watch TV and to fall asleep! Thank goodness it was only 2 of 16 nights on that trip.
Last year we did a 5-week trip to Minnesota, from May 29 to July 4th. We headed out east and swung north and took a northern route back. I believe it was 12 of 36 nights where we needed A/C. I had thought being so far north we wouldn't need A/C, bad assumption. We even had to book campsites in SD and WY where we would have much preferred to boondock in the woods but were forced into a campsite to plug in.
After that trip, I vowed never to hear that awful Dometic P2 again! And also, my goal was to gear up in Inverter and Ahs and replace the A/C with a unit that would sip vs. gulp Ahs.
For you, the freight-train NOISE of the P2 should be enough of a driver. You plug in so yeah power consumption does not matter (though we run ours for lunch breaks on the road too).
Easiest DIY out there given size and weight. The only A/C model I've heard of that needs a custom platform was the Truma. The Chill Cube has a 29x29" footprint, making it a full foot shorter to the rear. It's also the lightest unit out there.
Here is my DIY thread. This link will take you down page 2 to where my installation starts. I have installed 3 RV A/C models in the last 6 years, and this one by far was the easiest. You will need to add a furnace thermostat control which I also show here:
Ā
Edited by jd1923
We pretty much dont travel in July unless we get an unusual cool stretch and can mobilize quickly. We have the quieter Truma ac but still the point is to be outside.Ā  If the heat doesnt get you up here in northland the humidity and mosquitoes will. I have researched how far north i need to go to get substantial temperatures drops (vs south central wisconsin) and the outcome was not encouraging.Ā  By heading to far northern wisconsin or the southern portions of the UP, we might see about a 5 degree temp drop.Ā  If we get up to the northern side of lake superior or the Apostle Islands that might improve to a 7 to 10 degree drop depending on positioning of the jet stream.Ā  Anything more probably requires the Canadian rockies!
2023 Legacy Elite II -Ā Twin Bed -Ā Hull #1394
17 minutes ago, FloraFauna said:
Anything more probably requires the Canadian Rockies!
Yeah, and then you have altitude. Our trip was mainly in June, not July-August! I expected heat in Kansas or Iowa but was not expecting it in the Dakotas and Wyoming. Finally, Colorado camping at 9K ft was cool!Ā šŸ˜Ž
Drove down to Phoenix on Thursday to pick up Chris from Sky Harbor Airport. High temp on the truck trip computer was 112F on Phoenix highways. The high in Prescott was 85F (low 58F). Our home is at 5400 FT. That's a 27-degree difference with 4300 ft change in elevation.
In Arizona you can drive a couple hours and change your weather which doesn't work in the Midwest!
Thanks for the info @jd1923!
Our trip so far this year (Jan-June) has been pretty schizophrenic weather-wise. From NOLA to Reno we’ve had surprisingly cool weather - toying with needing tire chains, and once having to depart a camp site early to avoid having to get stranded by a major storm. I think we’ve run the A/C only 4 times - and just long enough to bring the temp down from high 80’s to mid 70’s.
We’ve yet to make that ā€œseeking 70’sā€ circle tour of the US work for us. Last year in Florida - we were freezing our butts off or running from mosquitoes.
I guess I’ll look into this ā€œChill Cubeā€ā€¦.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Ā
That’s a pretty compelling video and testing.Ā
Ā
and…. You can get it through Walmart?!
I think the concerns about the condenser coils collecting dirt are a bit of a concern.Ā
Otherwise - it sounds great.Ā
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Ā
Why does this come up as an issue? Was something mentioned in the Morton's YouTube? @Geronimo JohnĀ made a comment about this 6 months ago.
I've had 5 different RV A/C models. To clean the condenser coils you always remove the cover and hose it clean. This one should be the same or easier because it's taller.
I think that was Morton’s YouTube (the electrical engineer with the super in-depth testing of ducted and ductless models?)Ā
But yes, he mentioned because the condensate gets flung onto the evaporator coils to assist in the cooling that it might be more susceptible to collecting, dirt, dust, etc. That makes sense as a wet surface is a lot more likely to hold onto airborne stuff - pollen, etc. The added moisture would also allow stuff to grow.Ā
The height might make it easier, but the water there would work against that.Ā
I suppose as with most things, YMMV as to how often you need to clean the condenser coils, what method to use, and if you’d need something like a commercial coil cleaner.Ā
I had a home window unit that did something similar with a ring around the condenser coil fan that sat in a pool of condensate water. It was in humid Texas, so the water didn’t evaporate that well, but did make sure that dust and pollen collected into a mud that required pretty aggressive cleaning.Ā
Once a season I’d pull the whole unit out of the sleeve, put aluminum foil over the electronics, and take a pressure washer to the thing.Ā
I don’t know how well that brushless DC motor that turns the condenser fan is sealed, or if any of those ā€œmanyā€ sensors will appreciate being sprayed with a stream of water.Ā
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Ā
Yeah, thanks for the reminder. Or the condensate being blown through the condenser could help keep it clean. There are always two sides of an argument! 🤣
I stopped worrying about that when we left the East. I remember coming out of the shower during summer months in IL, VA and/or FL. I would towel-off, a never-ending process with water being replaced with sweat. Here I barely towel-off, start getting dressed and by the time you're done dressing you're dry!Ā šŸ˜ŽĀ I put tools, or scrub brushes or anything away wet. We don't worry about coasters under drinks on wood tables. Moisture vanishes and not much grows out here.
On this point, when making choices for mods to our Olivers, personal camping style and climate where we camp truly matters. What works for one might not work as well for another.
I was lulled by an OTT owner that condensate over the side of our hull was no issue.Ā  I went with the Houghton (no internal drain or evaporative solution such as a water wheel). My hull is now stained by the condensate.Ā
SO, I fully agree that an internal drain or a water wheel what works in humid conditions is a must.
CORRECTION:
The quote above was not from RonBlink.Ā  Not sure why it was attrituted incorretly.Ā  Here is a copy of it:
Sorry Ron!
Ā
Ā
Edited by Geronimo John
Quote was not attributed by system correctly.
TV:Ā  2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear LockerĀ Ā Ā  Ā  OLLIE:Ā  2018 OE2 Hull 342, Twin Bed.Ā Ā  Ā OLLIE DIY’s:Ā Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf.Ā  Ā TV DIY’s:Ā  2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ā Ā
I suppose if one stayed in one geographical and/or climatic region - you could worry about this or not.Ā
We find ourselves in pretty much every area.
(the ā€œtrying to towel offā€ illustration is something we’ve encountered far too often!)
One can only assume (hope?) that the folks who designed, built, and teased this critter have taken varying climates where one might use A/C into account.Ā
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Ā
Seems like areas that I just cleaned and waxed yesterday have water spots on them by morning. If I could only direct rain or tree debris…
The video didn’t mention if the ChillCube had a designated ā€œoutletā€ for condensate that doesn’t get blown through the condenser coils. Does it just ā€œoverflowā€ when it reaches the top of a pan or channel, or is there a designated drain or even a handy barb or nipple one could slip a hose onto to direct the overflow someplace least harmful?Ā
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Ā
The OP changed his mind on this criterion. Scotty can chime in again, but I believe it's because the benefits of less noise and greater Ah efficiency of the Chill Cube over the Dometic FreshJet. For me, I would not buy a Dometic RV A/C product again on principal, so I didn't!Ā šŸ˜Ž
We have no plans for summer travel to the Gulf Coast, the Mississippi Valley or anywhere else hot & humid anytime soon. However, we can assume when the cooling demands are high and high humidity is present, the Chill Cube like any A/C will produce an abundance of condensate.
13 hours ago, Galileo said:
The video didn’t mention if the ChillCube had a designated ā€œoutletā€ for condensate that doesn’t get blown through the condenser coils. Does it just ā€œoverflow?ā€
Yes, there is no drain for it, so if enough is produced to overfill the condensate wheel reservoir it should overflow. If there was a drain, or if one was added you would lose the efficiency in wetting/cooling the condenser by the water wheel.Ā Ā
Why couldn't theĀ condensate reservoir be tapped, condensate plumbed away?Ā No condensate drip may be worth losing some efficiency, but many Forum members have expressed their unwillingness to modify new equipment. Comments like this were added to GJ’s Houghton mod posts, "I shouldn't have to!" or ā€œI can't for warranty reasons.ā€
@Geronimo JohnĀ this would NOT be you, as you have modified your Houghton A/C years ago in ways that were not easy to design nor execute!
Condensate drain plumbing in the Oliver was designed to mate with the Dometic P2 and we've heard but not confirmed the FreshJet drain would mate as well.
The picture shows the A/C opening of our Oliver. We could assume all OTT Dometic P2 installations to be similar. On the far right we see the 12 AWG yellow Romex to power the A/C. The other wiring with red butt connectors is the low voltage thermostat wiring and right in the middle is the condensate plumbing.
There was also tubing connected there running from the rear of the p2 to this elbow fitting. If we had a condensate drip issue, I would pull the Chill Cube off the roof, drill and screw a tap somewhere in the condensate trough and run a flexible water line to the front left corner attached to this drain. In my thinking when something is needed, it's not can I do this, but how will I get it done!Ā šŸ˜Ž
It shouldn't be too difficult and running the Chill Cube vs. a FreshJet would certainly be worth the effort. Why can't condensate plumbing be added to the Atmos/Tosot that several here have installed, or the Turbro/Pioneer inverter A/C, or the Houghton?
https://www.amazon.com/Joyway-Brass-Fitting-Degree-Elbow/dp/B07CMRYL16/
Yeah, that's the way of our world. Last November, I worked a full exterior cosmetic restoration of our 10-year-old hull ending with ceramic coating. We don't travel near as much as Galileo, but since then we've gone on 10 short trips, 54 overnights (43 boondocking on dirt). See picture where the pavement ends and then another 24 miles to our campsite at Walnut Creek. I pressure-wash when we return from trips like this but don't ever truly wash her. I'm not using products or buffing wheels, not me. I do use a leaf-blower after pressure-washing! 🤣
We're just going to get her dirty and bring 'er back for detailing every year or so. This reference makes sense to me, what's a little condensate drip for campers like us?
Edited by jd1923
I’m thinking that a hole could be drilled through the condensate pan with a ā€œstandpipeā€ that would allow water to collect in the trough/pan to wet the condenser fan and tubing - but drain before it could overflow and drip/run onto the roof. Whether it could be plumbed into existing tubing would be the question.Ā
As for ā€œmodifyingā€ things that might void the warranty - aside from my vehicles (IOW - expensive stuff) I usually don’t sweat it. If I’m going to buy a piece of equipment from Amazon or Walmart and install it myself, IF there is even still a warranty at that point - I’ll navigate the CS to get whatever breaks under warranty resolved.Ā
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Ā
Based on my experience with the Furrion Stereo - I had to stop and take a breath before I started considering a much more expensive item from Furrion.Ā
Hopefully, they make A/Cs better than they make stereos….
As for Dometic - obviously the Penguin 2 A/C does not win them any customers. IMHO - the toilet is crap as well. The hob is fine - though the ā€œbumpersā€ that cushion the glass cover only lasted two uses.Ā
Norcold? Great fridge - if the freezer hinges were tough enough to withstand normal use.Ā
Then again - Truma hasn’t impressed me much either.Ā
Im usually pretty easy to please. Maybe that old ā€œthey don’t make things like they used toā€ is the reason - or - I’ve just become more crotchety in my old age.Ā
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Ā
