Hello, I am hoping that someone can provide a diagram of the shower plumbing.  I want to replace the pop up drain washer and a looking for the right washer to replace it with.  We have had several instances when traveling that the shower pan backs up with dirty water and yes the back flow valve is closed.  Any suggestions would be very much appreciated.
Thank you
Ron
Hello Ron, with the 2015 hull #99, very nice! 😎
There's not a plumbing diagram that would help. My understanding is if the waste valve is closed the pop-up shower floor valve really doesn't matter. If you want to replace it anyway, maybe somebody here knows the make and part number or inquire with OTT.
You know, if you close the "back flow" valve when the Oliver nose is down, there would be grey water in the plumbing that would then come out when towing. Make sure your front jack is lifted when you're closing. We use the LevelMatePRO and always have our front up 1/2" or more when camped. We close the bathroom valve before releasing the jacks to tow.
During travel, I use the kitchen sink to wash my hands to leave that valve alone. If you open the valve with the nose down with Grey Tank on the full side, water can back up to the plumbing under the shower that you may see later.
Given all this, if it's still leaking on the shower floor, your waste valve could be jammed up, not closing fully. With the tanks empty, remove the valve and give it a good cleaning and lube. Under the front dinette seat, it's the 2" line at the top of the picture. The 4" is the black water drain and you might want to service that at the same time. The main Grey waste valve is under streetside bed, jammed against the floor where the two lower screws are VERY difficult to remove.
I serviced ours last year since the pull handles were getting very hard to pull. This thread may be of interest. Best wishes, JD
https://olivertraveltrailers.com/forums/topic/10711-waste-valves-restoration-and-upgrade/
I agree with JD's thoughts and recommendations.  The rear gray water valve is a bear to take apart.  But it appears that your problem likely is the vent valve up front.
I would add that if the valve is not closing there could be two causes.  The valve is partially clogged.  That can turn into a mess for sure to also deal with.
I would approach it this way:
Step 1:  First try servicing all your cables as in the below DIY.  Such a DIY is long overdue for your  hull 99.  Mine was and it is 342.  That process may result in the valve clog getting mushed and then flow down to the dump station. If that does not fix the try Step 2.
Step 2:  At a dump station, from inside, flood the gray water lines with a LOT of water.  Use your pump hot water at both sinks.  Then try max flow with the pump and a garden hosed flowing into the bathroom sink.  Suggest having a watchful eyed helper.
Step 3:  Send a garden hose with the end cut off it from the rear of the trailer to see if you can clear it that way.  Be sure to open the gray valve outside to clear the pathway.
Step 4:  Consider getting help with a camera inspection.
Hope this helps.
DIY - Sanitary Drain Valve Cables.docx
Edited by Geronimo John
Thank you both for the advice this si very helpful, the gray and black tank valves appear to be working fine.  The back flow valve pull. In the bathroom is always somewhat difficult to push/pull.
Ron
You're welcome, Ron. Ours was too and there are a few reasons...
The pull cable is very short and it turns 90 degrees. It's in an awkward place to pull, whether standing outside the bathroom, sitting on the can or wherever, you can't get a straight pull! And a gunked up waste valve blade will make it worse.
You can remove the waste valve, clean and lube the blade, lube the cable and it could help. You can't change the 90 degree cable run and the awkward location of the pull handle.
We love the new electric one! Without the cable, push the button and I can hear it open or close in just a second! Check my thread linked above if interested.
I’mmmmm back!  So I was able to access my Oliver today and attached is the photo under the seat closest to the bathroom.  The circled area on the lower right is the cable that attaches to the pull handle in the bathroom.  I tried to follow the cable but there is no what that I can get my hand under there.  I am assuming that the circled area on the left is the black tank valve.  Any thoughts will be greatly appreciated
Ron
1 hour ago, DBL-R said:
Any thoughts will be greatly appreciated. Ron
Hey Ron, After seeing this picture, I realized you must have a 2015 Elite I, the single-axle baby Ollie! You should add a signature line so we realize that more quickly.
Calling on @SeaDawg, @DavePhelps, @bugeyedriver and others with an older EI to advise!
Most of us have the dual-axle larger EII with furnace right rear and there's so much different to which us EII owners would have no clue.
Best wishes, JD
Sorry about the confusion, it’s our first Olli!  Yes, it is a 2015 Legacy Elite I
Ron
Edited by DBL-R
DBL-R,
I also have an early model LE I (2008 - #14) with the same plumbing configuration up front and for years, I dealt with the potential back flow of grey water into the shower pan if the handle for the valve on the back wall of the shower was not adequately closed before travel and the spring actuated foot valve was open.  Then, many years ago, a good friend, Larry Gamble, of Little House Customs, fixed the issue by installing a HEPvO valve and magically solved the back slosh issue.
The HepvO valve is a one way valve which closes like a duck bill and prevents the grey water from backing up into the shower during nose down or deceleration while braking.  Now that handle on the shower wall is always in the out position, allowing water to drain from the pan into the tank and the HEPvO precludes it from making the return trip.  I've removed the foot actuated drain plug and replaced it with a small sink screen to catch any small items and prevent them from gumming up the HEPvO valve.
Larry said the clearance to install the HEPvO was very tight, but with his skill he managed to get it done anyway.  He's retired now making music instead of bending wrenches, but there should be some skilled RV mechanic you can find to make the same modification on your trailer.
Good Luck,
Pete
Hello, any chance that you have photos of the installation?
Ron
20 minutes ago, bugeyedriver said:
DBL-R,
Good Luck,
Pete
The configuration beneath my front dinette seat differs from yours a lot.  While you have a furnace in that area, I have one of my favorite things about The Wonder Egg, a 45 ft 30Amp extension cord on an electric windup spool!  My furnace is in the galley area, resulting in a loss of some kitchen drawers from your configuration.
Here are two pictures which will show the white HEPvO valve which Larry inserted into the PVC line from the shower to the grey tank. Good luck and let us know if you manage to have a HEPvO valve installed in your trailer.
Thank you Peter, I took all of the drawers out and removed the sink faucet and sure enough the clog was due to calcium deposits.  I cleaned it all up and everything is working great again.  Little by little, we are resolving all the little bugs that come with a new camper. I am hopeful that if I fully drain the gray tank, close the valve and seal the shower pop-up, we may mitigate future shower backups, fingers crossed.
Ron
Bosker -
Wow - that surely is tight in there.  No way your Dad could have gotten that thing in there.  Thank goodness he had Larry around to help him.😇
  • Haha 2
