chris44 Posted 5 hours ago Posted 5 hours ago Since we started using our 2024 Oliver Legacy Elite II, the gray and black tanks won't drain fully unless we lift the front as high as it will go. If the camper is fully level, the gray only drains to about 40%. Anyone else have this issue?
Moderators topgun2 Posted 4 hours ago Moderators Posted 4 hours ago How/where are you getting your percentage readings? The tank sensors can be inaccurate and/or in need of adjustment. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
chris44 Posted 4 hours ago Author Posted 4 hours ago 45 minutes ago, topgun2 said: How/where are you getting your percentage readings? The tank sensors can be inaccurate and/or in need of adjustment. Bill It is from the internal display. But the readings seem relatively accurate, since it shows as 40% when level, and as we raise the front of the trailer, a lot of gray water drains out and it reaches zero on the display after it finishes.
Moderators topgun2 Posted 3 hours ago Moderators Posted 3 hours ago OK - I think I've got it. The reason that you have to raise the front of the Ollie to drain the tanks is common to all Olivers that I know of. This is because of the basic design of the tanks - they are fairly wide and long - but - not very tall since they have to fit between the inner and outer shells of the Oliver. The good news is that this design helps lower the trailer's center of gravity and more evenly distributes the weight of the tank's contents from side to side and front to back. In addition, the location provides protection to the tanks from sources outside the outer shell of the Oliver and given that in colder temperatures the area between the shells is somewhat warmer as compared to outside. Unfortunately, the downside to this location and design is that in order to completely empty the tanks, the front of the trailer must be elevated such that the liquid contents flow more completely (and faster) towards the outlet which is basically at the rear of the camper. Your 40% seems a bit on the high side but that could be a sensor issue (again, it really doesn't take all that much of a mis-placed sensor and/or the degree of level of the trailer to have a fairly dramatic effect on the reading). I think that most of us develop an idea/sense of when and how long we can "go" before these tanks need to be emptied and or what our readings really mean. But, in virtually all cases if we want to really empty these tanks, the nose of the Oliver must come up. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Steph and Dud B Posted 2 hours ago Posted 2 hours ago Totally agree with Bill. Your readings seem high, but we always have to raise the nose when dumping. If we don't, we often have 6-12% left in the tanks (according to our monitors). Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
