ccevans6 Posted October 7 Posted October 7 My wife and I just returned from a trip out west and we encountered quite a few bugs on the trip back. We have only owned the trailer since April and wanted to see how others have handled the issue of removing bugs from the Oliver. We did not get the professional finish as we are planning to have that done next year. In the mean time, any thoughts?
Steph and Dud B Posted October 7 Posted October 7 Bug and Tar Remover, then wash and re-wax. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
FloraFauna Posted October 8 Posted October 8 As a first step, i wash off with alot of sudsy soap water and sponge bath, letting it soak the bugs, then go bug and tar remover for the relatively few that persist. 3 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Patriot Posted October 8 Posted October 8 (edited) 19 hours ago, ccevans6 said: My wife and I just returned from a trip out west and we encountered quite a few bugs on the trip back. We have only owned the trailer since April and wanted to see how others have handled the issue of removing bugs from the Oliver. We did not get the professional finish as we are planning to have that done next year. In the mean time, any thoughts? A professional ceramic coating will allow those bugs to wash right off with a PH neutral car wash soap. We had our Oliver ceramic coated by CGI and they did an outstanding job. 🌟🌟🌟🌟🌟 Highly recommend! https://www.cgidetailing.com/ Edited October 8 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Jim and Frances Posted October 8 Posted October 8 Pending your ceramic coating 🙂....a great / inexpensive option is Turtle Wax 50595 Power Foam Bug & Tar Remover. Interesting video here from Dallas Paint Correction. I am sure there are better products, but maybe not for the price and the foaming dwell time. As mentioned in the video, good for bugs horrible for tar. Citrol also works but is a harsh chemical. Just a thought! 2 SE Texas | 2021 Elite II Twin Bed # 927 "Lucy" | 2019 F250 FX4 6.7
Moderators topgun2 Posted October 8 Moderators Posted October 8 That Power Foam Turtle Wax bug remover gets high ratings. Once you get your ceramic coating done you will find that the bugs are a bunch easier to remove. CGI (that Patriot mentions above) has a product that will also aid in bug removal while enhancing and adding to the life of your coating - I believe that "Ceramic Shield" is the name. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
ScottyGS Posted October 9 Posted October 9 When I first saw the title of your post I thought you were fighting the dreaded No-see-ums that get past the screens. I would second, or third, the recommendation to get CGI to do a ceramic coating for you. They really are experts and outstanding young men with an awesome work ethic. The two products that I got from them for after care are 1.) Ceraglo - soap to wash and 2.) Shine & Shield - to use after washing... it helps to keep the ceramic coating fresh. CGI will be at the rally and would be happy to inspect your trailer and give you a quote on ceramic coating. Scotty 3 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
Gavin Luthringer Posted 10 hours ago Posted 10 hours ago If you have an electric pressure washer it will make it a little easier. Here is a bug remover you can use if regular Ph neutral soap and water aren't working: https://link.amazon/B0fsiodKg Here is a youtube short on CGI using it: The more oxidized a trailer is, the harder it will be for the bugs to be taken off. Hope it helps! 2
