My wife and I just returned from a trip out west and we encountered quite a few bugs on the trip back.   We have only owned the trailer since April and wanted to see how others have handled the issue of removing bugs from the Oliver.   We did not get the professional finish as we are planning to have that done next year.   In the mean time, any thoughts?
As a first step, i wash off with alot of sudsy soap water and sponge bath, letting it soak the bugs, then go bug and tar remover for the relatively few that persist.
A professional ceramic coating will allow those bugs to wash right off with a PH neutral car wash soap.
We had our Oliver ceramic coated by CGI and they did an outstanding job. 🌟🌟🌟🌟🌟
Highly recommend! https://www.cgidetailing.com/
Edited by Patriot
Pending your ceramic coating 🙂....a great / inexpensive option is Turtle Wax 50595 Power Foam Bug & Tar Remover.  Interesting video here from Dallas Paint Correction.  I am sure there are better products, but maybe not for the price and the foaming dwell time.  As mentioned in the video, good for bugs horrible for tar.  Citrol also works but is a harsh chemical.  Just a thought!
That Power Foam Turtle Wax bug remover gets high ratings.
Once you get your ceramic coating done you will find that the bugs are a bunch easier to remove.  CGI (that Patriot mentions above) has a product that will also aid in bug removal while enhancing and adding to the life of your coating - I believe that "Ceramic Shield" is the name.
When I first saw the title of your post I thought you were fighting the dreaded No-see-ums that get past the screens.
I would second, or third, the recommendation to get CGI to do a ceramic coating for you.  They really are experts and outstanding young men with an awesome work ethic.
The two products that I got from them for after care are 1.) Ceraglo - soap to wash and 2.) Shine & Shield - to use after washing... it helps to keep the ceramic coating fresh.
CGI will be at the rally and would be happy to inspect your trailer and give you a quote on ceramic coating.
Scotty
  • 4 weeks later...
I use 3D Bug Remover - spray on, let sit for a few minutes, hose off.  Use mesh sponge with a second application if any remaining.  Recommended by CGI.  Works amazing.  I clean and re-coat front cap after every trip with Meguiar's Hybrid ceramic wax. As others mentioned, makes removal easier.
Mike
  • 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler
  • 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
