I'm posting for an anonymous 2017 Ollie owner.
This is why we should NEVER leave our trailer with city water on to the trailer.  I need to remember this too, or just use fresh water tank with pump off when leaving.
He heard water flowing under the bunk when hooked up to city water and found that the 1/2 inch plastic swivel adapter going to the water heater, under the passenger side bunk, had broken off.  Easy fix, but only if you had the Pex tools and parts with you. The trailer would have flooded with that much water pressure going into hull.
Here are some pics.  He also found out why, in his 2017 ollie, he had low hot water pressure (a kink).
Time to put a straight and right-angle brass swivel adaptors in my plumbing bag.  Spend a few more bucks to save the rig from being an indoor pool.
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
When leaving the trailer, e.g. a day trip, there are several things we check. One is to be sure the water pump is OFF. Likewise if on City Water I will shut-off our hose connection at the hook-up.
LP off at the tanks is also a good idea for safety.
If you leave pets in the trailer these things are more important and of course they need cool fresh air!
Almost as bad as water leaking into the hull would be leaving an electrical appliance on that could cause a fire. You could trip the breaker at the post. If un-plugged the batteries could run down. As we’re locking up to leave, I’m checking the shunt reading on the app to see that amps in or out is what’s expected. 😎
Edited by jd1923
Helpful post, with great photos.  Thanks for the "heads up."
It was my understanding that Olivers have scupper holes in the bottom hull that would allow water leaking into the bottom of the trailer to drain, preventing it from becoming a swimming pool.  Am I mistaken?
Also, did the unfortunate Oliver owner use a pressure regulator on the city water input connector?
I now plan to carry a 1/2" brass fitting and 1/2" Pex B rings, with crimper, on our next long trip.
Edited by Rivernerd
52 minutes ago, Rivernerd said:
Am I mistaken?
Nope -
Those silver looking things on the bottom of the trailer are the scupper holes.  They actually even draw water vapor out from between the hulls while you are traveling down the road.
I know what I’m doing soon. 😏
Chris
Good thoughts for sure.  I take them a step further.
For the newer owners, when you hook up to the City water on-boarding port, your closed plumbing system comes up to the same standing pressure as the city system.  This includes your pump, hot water heater, and all your piping to the bathroom, kitchen and outside .  That pressure generally is much higher than the OTT pumped system, and can cause leaks.
When not using this port, most leaks are slow drippers.
But if your system is connected to this port, you can get a really serious leak.  Especially if you some air in your plumbing, the high pressure City water and air in your system can cause severe water hammer.  And that's when fittings get blown out.  With a nod to JD's post above, when you have such a system breach, it will flow a lot of water into your hull.  If you are not there, your trailer suspension and MEP systems are at extreme risk.  Hence you really should be there when using this port.
Unless my pump fails, my "Step Further" is that I don't use this port (except for winterizing at the end of season).  Just not worth the risk.
You might also want to consider throwing in a 2 to 3 foot section of pex - just in case.
@Wayfinder  Chris, are those panhead screws used to mount the return air vent grill for the heater?
I would be on my 3rd box of band-aids if that was my Ollie!
  • Care 1
