Mainiac Posted January 21, 2017 Posted January 21, 2017 Toilet Chemical... what do you mostly use? We have lately used Eco-Save. We like scented, just because of the scent. The dry is just right for boon docking as it last so long, and it lubricates valves. A nice thing is it can freeze, shake it, works fine. First saw it used at a campground dump station. A newbie had a sun damaged blue 'stinky' hose that broke, and lost it's content all over the ground. It was a real hot dry day. The CG owner raked and shoveled any solids and flushed away in the bathouse.. He then put about an ounce or so of Eco-Save and some water in a spray bottle and spray covered the area. I watched the area that weekend and never a hint of odor or problem. I like it because it is not chemical based. They don't even recommend it is used ntil there is waste in the tank. Doesn't seem to be mass marketed, but available at a lot of campgrounds. Their web site list where its available in your state. 1
KarenLukens Posted January 21, 2017 Posted January 21, 2017 I've used different brands but never tried the Ecosave yet but I did read about it a couple of years ago because one of our friends use it exclusivly :) - http://www.eco-save.com/products-frame.html Different people all have different ideas about how to set up and service their black tanks and some put a few gallons of water down in the beginning with the chemical to start everything working but not me. A lot of my friends simply dump the tank and then add some bleach or one of our camping friends simply uses dish soap and calls it good. Here's a link to that method and it works fine also - http://wheelingit.us/2012/03/21/rv-tank-sensors-the-geo-method/ For me, the chemicals are easy and I like having them setting in the bathroom. I must say though that not all chemicals are the same and my method is old school in that I don't add any water in the beginning. After we dump the tank and then start to use it again, for the first few flushes I just stand on the pedal for a few extra seconds until after a few flushes, I've maybe added a gallon to help combine with the urine. It doesn't smell that first day and when I get up the next morning, I use the toilet and add a couple cap fulls of the Thetford Aqua-Kem - https://www.amazon.com/dp/B0006H92RY/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=DVETVI1ZF5E8&coliid=I3GJFOCGHSSVHF I did say "Cap fulls" because even though it comes in that nice small 6 pack, you flat out don't need to use that much. Most of the time we are staying a week at a time in different places and I dump the tank when it gets half full if we are leaving anyway. Karen has the hose and nozzle inside for washing out the tank and I run the outside and hand her the hose through the bathroom window and she washes out the tank completely around once a month or so. Really, only a cap full is needed most of the time and I add it as needed from there. After a few days, I just watch the level or take a wiff, and if everything is running fine, I don't add anymore. As we all know, different times are constantly changing and every now and again we get the odd week and I will add an extra cap full but that's it. So the small little 8oz bottle sits in behind the tank with the window cleaner and other cleaning supplies and it lasts us along time. The little blue bottle just flat kicks it over most other brands. With others, some come with a measuring section - and a cap full of the Aqua-Kem is really such a small amount that you wouldn't think that it's going to be enough. I can't count how many 6 packs I have used over the years but they last and last. One bottle goes in the bathroom and the rest go into my tool box :) 2 Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II
Mainiac Posted January 22, 2017 Author Posted January 22, 2017 I now use EcoSave exclusively. The small bottle of scented usually last me all season. I put about a capful of it, long with about a cupful or so of water at the start of a trip. It "splash blends" as we go down the road. Kind of lubes the bottom of the tank and wakes up the microbes. No formaldehyde, and would never put bleach in...I do carry a bottle of the dry, just in case I run out of the other. But I am lazy, and just splash the 'about right' amount in when needed. 4
Fargoman Posted July 26, 2021 Posted July 26, 2021 I could not find an answer in searching the Forum. What toilet bowl cleaners are safe to use with the black tank additives? I purchased Happy Camper brand black tank additive for our September 16th LE 2 delivery date, but just realized that standard household toilet bowl cleaners might be incompatible with black tank additives. This is just another one of many trailer-related questions that seem to occur to me in the middle of the night. 2021 Legacy Elite 2 Twin Bed | Hull Number 894 (9/16/21 delivery) | Ram 1500 Longhorn 4x4 3.0L EcoDiesel 3.92 axle
Moderators SeaDawg Posted July 27, 2021 Moderators Posted July 27, 2021 Definitely, don't use household toilet bowl cleaners. Dishwashing liquid is quite enough to clean the bowl, and use that sparingly. Toilet bowl cleaners like Lysol are very caustic. Dishwashing liquid is all I've ever used, in the camper, as a cleaning solution. 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Fargoman Posted August 30, 2021 Posted August 30, 2021 Another toilet question: I have read that we should use RV/black tank-specific toilet paper. Is that necessary in your experience when using a black tank additive such as Happy Camper? According to Happy Camper, their product can properly 'digest' regular toilet paper. 2021 Legacy Elite 2 Twin Bed | Hull Number 894 (9/16/21 delivery) | Ram 1500 Longhorn 4x4 3.0L EcoDiesel 3.92 axle
Moderators SeaDawg Posted August 30, 2021 Moderators Posted August 30, 2021 Most people i know use Scott's single ply, septic safe paper. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators Mike and Carol Posted August 30, 2021 Moderators Posted August 30, 2021 Angel Soft is good too. Mike 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
AndrewK Posted August 31, 2021 Posted August 31, 2021 6 hours ago, Fargoman said: Another toilet question: I have read that we should use RV/black tank-specific toilet paper. Is that necessary in your experience when using a black tank additive such as Happy Camper? According to Happy Camper, their product can properly 'digest' regular toilet paper. Fargoman, We use Happy Camper and the Costco Kirkland toilet paper without problem. Andrew 1 1 Andrew 2019 Legacy Elite II 2018 BMW x5 35d
Moderators SeaDawg Posted August 31, 2021 Moderators Posted August 31, 2021 Most septic safe paper is ok. If you're not sure about your favorite brand, put a couple clean squares in a jar with some water, give it a couple gentle shakes, and see if it falls apart. If it does, you should be good to "go." So to speak. If not, find another brand. The key to avoiding the dreaded poop and paper pyramid is enough liquid in the tank, before you dump. It doesn't have to be a lot of clean flush water. The water that's already been through you works just the same... Edit to add: Scott makes an rv tissue that's a little softer, smaller rolls, still pretty inexpensive. The big Scott one ply megarolls we get at Costco don't fit well in the marine style dispenser in our Ollie, till I unroll a bit. That's ok, because I save those bits in a zip lock to carry in my pocket for campground facilities. I learned a long time ago to not count on available paper. 1 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Guest TxMN2020 Posted September 29, 2024 Posted September 29, 2024 We have used Angel Soft in septic tanks for years, am planning to use it in the Oliver. Tank additives are an unknown to me, is Happy Camper readily available and considered a top product. I am not afraid to pay for premium products if they outperform others and are good for the Oliver. Plan to use it many years so want to take best of care for long term performance.
