Collier and Joan Posted March 9, 2020 Share Posted March 9, 2020 I was on the roof today and notice these 2 cracks, is this normal 2019 Oliver Legacy Elite II - Delivery Date Aug 29, 2019 Ford F150 XL Supercab - 3.5 EcoBoost Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted March 10, 2020 Moderators Share Posted March 10, 2020 Yes, it can be very normal. In 40 plus years of fiberglass hull ownership (boats and trailers), we've seen a lot of gelcoat cracks . Gelcoat doesn't have the same strength of the underlying mat and roving plus resin. Gel's both more brittle, and more beautiful. Stresses like a rock dings, dropped tool, excessive flexing from standing in the wrong spot, or overtighted fastener can cause a spider crack in gelcoat. On a rare occasion, a tiny void pocket beneath , in the fiberglass, can cause a crack above with flex or extreme thermal expansion. The good news is, it's almost always just cosmetic, and doesn't really affect anything. And pretty easy to repair, especially where yours are, on the roof, out of sight. Unless it's really deep, or you live in an extreme climate zone, (or, it's below the waterline as happens on our boats) it probably will never cause any underlying issue. It's disappointing, I know, but pretty easily repaired. I'd probably get a gelcoat repair kit, and do it myself, if it's on the roof, out of view. Unless you're still under warranty. Then, call Oliver Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Overland Posted March 10, 2020 Share Posted March 10, 2020 Sounds like a job for Cap’n Tolley 1 Link to comment Share on other sites More sharing options...
bhncb Posted March 10, 2020 Share Posted March 10, 2020 Those look more like tool scratches than cracks. Contact the service department for a repair solution. Be sure to also point out the cracked flange on the vent cap where the screw was over tightened. The cap needs to be replaced as well. Link to comment Share on other sites More sharing options...
John E Davies Posted March 11, 2020 Share Posted March 11, 2020 (edited) On 3/9/2020 at 8:29 PM, bhncb said: Those look more like tool scratches than cracks. Definitely, try some automotive rubbing compound to see if the "cracks" go away. Been under any low overhangs lately? And also be aware of the condition of the sealant when you are up there inspecting stuff. This is a water leak - if not now, it will be: You can get an entire new cap assembly shipped from Amazon Prime for about $5.... just swap it out and seal it with a high quality marine sealant, and you should be good for a long time. John Davies Spokane WA Edited March 11, 2020 by John E Davies SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
