Truma vent to screen or not to screen?
I have just completed installing SS screening to the frig vent (pic) and installed the screen for the furnace vent to keep wasps, mud dobbers and other home seeking critters out. Also installed the AC Cover to keep birds from nesting.
My question for Truma owners that have done this install is did you use the same size mesh for the Truma as you did for the frig? (See mesh size pic I used for frig). If not what size screen did you use? I want to be sure I do not restrict air flow to the Truma system.
I may just call Truma and ask if this is even recommended? I solicit thoughts of others that may have already called Truma and asked this question or completed this mod. I will try and contact Truma today and see if this will impact airflow and VOID the factory warranty before moving forward.
Thank you,
-David
Edited by Patriot
North Carolina 🇺🇸
I don’t know the answer, but I do know that Truma makes a plug for that vent to use when not in use. One comes with the electric antifreeze kit and so you may be able to get one separately if you call them.
The plug has a tether and a slot to store it when not in use, and also there’s a visible tab that sticks out of the vent when installed, to remind you to remove it before turning on the hot water.
Edited by Overland
Yes, thanks! We did get the electric antifreeze kit. I will check with Truma on the vent plug.
I sent an email to Jason Essary asking if adding a screen will void the Truma warranty. I will post up his reply.
Edited by Patriot
North Carolina 🇺🇸
I read this in the 2020 manual, so it appears screening is a no go on the Truma unless I hear otherwise from service.
Edited by Patriot
North Carolina 🇺🇸
In your shoes I would choose a much bigger mesh size and epoxy it behind the slots. I don’t see how a 10 mm mesh could possibly obstruct airflow. It would certainly keep out larger insects, like those pesky Murder Hornets.
Add a strong magnet on the inside at each corner and along the edges and make a solid “storage cover” from Sunbrella or a vinyl fabric, with matching magnets (observe polarity!) to slip onto the outside when the heater is dormant. I don’t think you should travel with it installed, so a bright color would be good so you will remember to remove it. I have some like these, I actually use them to hold an old cotton sheet over a gun safe, they are super strong for their size, you have to watch your fingers when getting them close together.... https://www.amazon.com/DIYMAG-Refrigerator-Magnets-Premium-Brushed/dp/B07B3SDRCP/ref=sr_1_9?dchild=1&keywords=Neodymium%2BDisc%2BMagnets&qid=1593276158&sr=8-9&th=1 .... depending on the thickness of the Truma access door you might need bigger ones. It could involve some trial and error.
Let us know how it works out so I can make some for the fridge grills for dusty roads. I get dust infiltration all the way into the cabin, along the lower sill of the fridge door. ;(
Edited by John E Davies
I decided not to add screen to my Truma vent. It was not gonna be as easy and clean as the fridge, so it was not done.
If the kit is installed, the yellow flue plug and metal storage bracket should be on the access door like this.
