John E Davies Posted June 27, 2020 Posted June 27, 2020 (edited) This is the standard pin, it has a very slight and rough 45 degree bevel on the small end: I used a file and a belt sander to make a nice tapered bullet contour. I polished it with 360 grit sandpaper after reshaping it. Optional: the holes in the ball mount did not have much of a taper: I used a 1” drill bit plus tapered polishing stones to open it up and smooth the inside edges where the pin will slide past. You only need to do the left side, the one you normally insert the pin from Now it slides in with much less fussing and swearing. John Davies Spokane WA Edited June 27, 2020 by John E Davies 1 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Yukon Posted November 7, 2020 Posted November 7, 2020 Thanks John, figured as much. The wife found some post that said the pin was installed under the new triangle plate . From the pictures I could not see how that could be. Wishful thinking I guess. I do like your idea on the pin I will give that a try.
Jim_Oker Posted November 7, 2020 Posted November 7, 2020 Nice, and thanks for sharing. Looks easy enough to do. Have you by any chance shared this notion directly with the Anderson folks as a constructive suggestion for presumably a cheap and simple way of improving their product? Jim and Yanna, Woodinville WA 2004 Ford E250 camper conversion Oliver Elite II hull #709
BackofBeyond Posted November 7, 2020 Posted November 7, 2020 I'd bet a beer - Anderson would claim the little swaging out JD did was outside their engineering specs... I'd certainly do the same, except I sold my Anderson. RB 2 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2027 EII on the board. "Die young - As late as possible"
Jim_Oker Posted November 10, 2020 Posted November 10, 2020 Yes, that occurred to me too as I was typing that, but still, I like to give people a chance to better serve their markets by really thinking about constructive customer input. 1 Jim and Yanna, Woodinville WA 2004 Ford E250 camper conversion Oliver Elite II hull #709
Jim_Oker Posted November 10, 2020 Posted November 10, 2020 It's certainly an easy enough thing to do at home (especially with a mounted belt sander etc. like I have in my shop area) but it seems like they could probably add a pretty cheap step and get more love. Maybe it doesn't pencil out for them, maybe it does. Jim and Yanna, Woodinville WA 2004 Ford E250 camper conversion Oliver Elite II hull #709
Trainman Posted November 27, 2020 Posted November 27, 2020 I don't see rounding off the end of the pin a problem, but modification to the actual hitch itself in an accident and lawyers today if they can find where modification have been done could cause you big problems in court. It's the same as towing a trailer with a vehicle not rated for the trailer being pulled, know your tow limits and what your tow vehicle will handle under the manufactures ratings. Yes, my 1500 RAM 4X4 needs a WDH, but a 2500 RAM does not for the Elite II, don't cut corners just because you don't want it. trainman 2 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
John E Davies Posted November 27, 2020 Author Posted November 27, 2020 1 hour ago, Trainman said: I don't see rounding off the end of the pin a problem, but modification to the actual hitch itself in an accident and lawyers today if they can find where modification have been done could cause you big problems in court. Thanks for bringing this up. You are certainly entitled to your opinion. This mod does nothing to weaken the attach point of the whale tail. The shackles, chain or the welds on the fin would fail long before the solid steel bar it attaches to would break. If anyone is worried about liability, then skip the hole part. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
John E Davies Posted July 31, 2021 Author Posted July 31, 2021 This mod is now OBSOLETE, instead of grinding, just buy one of these hitch pins with the great big handle. Thanks to all the Ollie members who suggested this. John Davies Spokane WA 1 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Ralph Mawyer Posted July 31, 2021 Posted July 31, 2021 Just watch tight turns as you will bend the handle… 2 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
John E Davies Posted August 1, 2021 Author Posted August 1, 2021 If clearance is an issue, you could easily saw off a few inches of the tip and drill a new hole. Mine clears fine, but I have a 3" longer "extended" Andersen stinger. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
