Has anyone experienced this?  I just noticed that a couple of drawers were rough to open and it looks like the bearings on all my drawers are rusting - some pretty badly.  Like, really badly.  I'm not sure if there's a solution to this other than new slides.  I guess I could take them out and soak them, but I'm sure they'd quickly rust up again.  I have to guess it's just from humidity since there's no sign of water intrusion anywhere.  Possible that I have a hidden leak between the hulls that's keeping it overly humid in there.
I've got a dehumidifier, but I haven't been using it since it requires the trailer to be plugged in 24/7.
I guess I've got a new project.  I've sent a note to Oliver to ask about replacement.  Blum has a lifetime warranty on everything they make, so hopefully they'll swap out the parts for me for free.
Edited by Overland
Made me look🙄, haven’t seen anything like that thankfully.
This is the dehumidifier I keep in the trailer and it only needs electricity to dry out the beads inside.  When the beads turn green they are wet and need a drying cycle.
EAE33BE2-307F-4359-8704-A218267E0310.thumb.jpeg.44f93e565f822193c5bbf568eec23051.jpeg6EF939DF-5B39-458F-AC0D-56D61C8EA96A.thumb.jpeg.383ceeb648a5d613a2743a08795eaf07.jpeg
I don’t think I have any rust, but will check tomorrow!  Thanks for letting us know, something to check and know about.  Mike
That's a bummer.
I just checked mine. They're fine. But a different design, and probably a different brand. Not surprising,  since my trailer is ten years older than yours.
Thanks, I’ll have to get one like that.
I'm in the southeast, and it's pretty humid here.
But I'm thinking that it must be exasperated by a hidden leak somewhere.  I had a problem with the bath window last year and it had to be replaced, plus I discovered some water trapped inside a few of the window frames when I cleaned the caulk a bit ago.  And maybe too I've had the standard clogged window drain leak at some point, though I haven't seen evidence of it.  Your guess is really as good as mine.  I suppose it could have just been a bad batch of slides.  I'm pretty sure they're galvanized.
I had to clean a rust stain this spring from outside the battery compartment hatch. Looking inside I had a good amount of that on the battery tray slides. Hmm. Also two of the straps were broken, for whatever reason the strap had come unsewn.
