“To sum up, for long and happy LFP battery life, in order of importance, you should be mindful of the following:
  1. Keep the battery temperature under 45 Centigrade (113 deg F), under 30C (86 deg F) if possible – This is by far the most important!!
  2. Keep charge and discharge currents under 0.5C (0.2C preferred)
  3. Keep battery temperature above 0 Centigrade when discharging if possible – This, and everything below, is nowhere near as important as the first two
  4. Do not cycle below 10% – 15% SOC unless you really need to
  5. Do not float the battery at 100% SOC if possible
  6. Do not charge to 100% SOC if you do not need it”
https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/
Does the Oliver factory lithium option have any features to help cool the batteries, other than having no vents and some insulation inside the compartment door?
Any idea how hot the inside of the box gets on a 110 degree day in direct sunshine? Have you considered the importance of keeping that side of the trailer in shade during extreme sunny weather?
If you tend to not run the air conditioning, maybe you should consider using it more often, and starting earlier in the day.
The onboard battery management system will prevent charging at a certain high temp (135 deg F for Battle Born) but keeping it well below that amount seems to be pretty important.
I am working on a powered fan vent system for the box and the two electronics compartments on that side of the trailer. The design of the LE2 box, with two nested cubes and the pantry sitting on top, traps heat like an oven. Venting might also reduce the temp inside the pantry.... I drilled my first set of holes yesterday 😳😳😳
32089343-FFAD-4937-B084-90DF17E6C501.thumb.jpeg.ce0010b46bb0e3886671e9ef5b114165.jpegIt sure would be nice to have a way to actively chill the batteries, but I can’t imagine any practical way to do that in an RV.
  • The title was changed to EXCELLENT Lithium resource, and heat management discussion
No.
I hope to never find out, but pretty darn hot I'll bet!  I'd rather be in a blizzard in the Rockies than in the desert at 110F!  I'll keep my Ollie shaded in the garage if it's that hot outside.  😃
50 minutes ago, John E Davies said:
Cool idea!  Can't wait to see how it turns out!
While driving the pre-existing vents will keep the compartment "chilled" and for camping in heat I'm thinking maybe I'll first try a small DC fan or set of fans (similar to the nature's head fan) to move air in and out of the pre-existing vents that I have temporarily plugged up for the winter.  I need some real life temperature data before I start drilling and venting inside just yet.
States Visited Map
In south Texas our afternoon temps are above 86 for at least 6 months out of 12 and high 90’s for at least 3 months.
NCeagle, FYI 110 degrees F outside air temp is not uncommon in summer in much of the West, not just in the SW desert.
I try very very  hard to avoid those southern deserts in the middle of the year. Moab UT is stunning, but no place to be from July though Sep. I don’t even know how people can live in Phoenix.....
You can’t always avoid blistering heat. All you can do is run the AC and bail out to a motel if it gets too hard for you or your pet.
  • Sad 1
Much of my wife's family and my oldest son live in phoenix - I think they just experienced a large succession (143) of days 100 plus, and 34 above 110.  Not for me....... I head to elevation when we visit.
The Oliver lithium package may need a dedicated cooler in that temp set.
Now the winter season - perfect.
Yes - I've heard it said before - "when it gets hot, get high" 🤣
  • Haha 2
Getting close, I have all the vent holes cut, and I mounted the fan in the bottom of the battery box. I have some wiring left to finish before I can test it and see how much actual airflow I get . There will be several install threads in a while....
Before anyone asks, the four posts sticking up are grab handles for pulling the fan plate free from the velcro for cleaning or servicing.
I took the liberty of moving all the comments on velcro types to a new thread. Since many of us use Velcro (and other hook and loop fasteners), I thought it might need a stand alone thread.
Velcro comments continue here:
