Mountainman198 Posted January 20, 2022 Posted January 20, 2022 Saw my first 2022 Tundra in person today. Cement, Limited crew. Owner tows a 27’ Airstream and says it handles well both on flat and in Mtns (lives near Big Bear). Have to admit that it is not as butt ugly in person as it was in print. Grill not as billboard-ish in person. 3 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
Patriot Posted July 3, 2022 Author Posted July 3, 2022 Just saw this, heads up to 2022 Tundra owners - updated post. https://pressroom.toyota.com/toyota-is-conducting-a-safety-recall-involving-certain-2022-model-year-tundra-vehicles/#.YsINIbrV30Y.link 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderator+ ScubaRx Posted July 3, 2022 Moderator+ Posted July 3, 2022 Apparently there's nothing worse than "have certain nuts that can loosen over time." 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Patriot Posted July 3, 2022 Author Posted July 3, 2022 36 minutes ago, ScubaRx said: Apparently there's nothing worse than "have certain nuts that can loosen over time." Ageed, there are enough loose nuts in this world 😅 1 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted July 3, 2022 Author Posted July 3, 2022 Just saw this. Here is the fix and also production dates of trucks impacted. 2 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rideandfly Posted July 4, 2022 Posted July 4, 2022 4 hours ago, Patriot said: Just saw this. Here is the fix and also production dates of trucks impacted. David, Will have the Toyota dealer to check out our Tundra next week. Thanks, 2 Bill 2015 LE2 #75 2024 F350 6.8L
rideandfly Posted July 23, 2022 Posted July 23, 2022 Took the Tundra for the recall and the dealer needed less than an hour to perform recall work. 🙂 Been experimenting using cruise control while towing Ollie with over 10,000 miles on the Tundra’s odometer after this trip. Tundra’s on board MPG is accurate and was used for two test using cruise control. Both test were over 300 miles each on interstates. 2WD 3.5L 10 speed Tundra with street tires on Ollie & Tundra. TV tire pressures 40 PSI and Ollie’s tire pressures 50 PSI. LE2 Ollie’s weight between 4900 to 4950 pounds with empty grey and black water tanks. Rig weight is around 10,900 pounds. Check Rig & TV/Ollie weights periodically with CAT scales. Set cruise at 63MPH yielding 61MPH GPS speed. Tow haul mode used with 7th gear. Engine speed was 2150 RPM. During the test while climbing a 5% grade reduced speed to 55MPH and dropped down to 6th gear. One way test from Crossville TN (TN plateau area) to Denver NC yielded 15.8 MPG. Round trip from Crossville TN to Howenwald TN and back to Crossville yielded 15.5 MPG. Should see better MPG in the flat lands, will see. 1 4 Bill 2015 LE2 #75 2024 F350 6.8L
