We do not have a microwave and we are thinking of getting one. Can you use one in the inverter? Especially for just a minute or two to warm up left overs?
Oliver Elite II hull # 151
Sure you can.  We have a small one from Walmart that we bought for around 60 bucks.  Amazon has a bunch of smaller ones as well.  I think our is 700 watts.  The less power draw the better.
John and Kim
Yes.
Does it fit in the cabinet?  The depth is less than what I had in my casita.
Assuming that you are talking about the inverters that normally come with the Oliver - either the 2,000 watt or the 3,000 watt -  then the answer is certainly yes for most microwave units.  Just make sure that the microwave you have in mind is at or below about 1,500 watts and you will have no worries using the inverter.
Of course you still have to be mindful to not overload the inverter by trying to run the microwave while at the same time running a toaster, hair dryer, blender, etc.
We keep it on the floor of the closet or in the truck.  Do t use it very often.
John and Kim
Ok Everyone has convinced me this would work. Can someone tell me the make and model and size of a microwave that will fit in the space provided? I would like the kind that doubles as a convection oven.   DJM
It looks to me like in order to put a microwave in the space provided I would have to remove the door and the sheet metal frame that holds the door. I suppose I might be able to find a minature microwave that fit in there but it seems like it would be better to remove that facing. Has anyone ever done this?
@DJM, if you would put your model and year in the signature or post, it would help you to get better advice.
When you say "space provided," I think you may mean you have a storage compartment with wooden sides (which Oliver no longer offers, btw.) The storage box is much smaller than the microwave cavity, because the box squares up and cleans up the curved cavity.
Would a small toaster oven meet your needs? Several people here carry one on their storage compartments. I assume they still have to pull it out to use it, at least partway, as the compartment doesn't allow for proper space for venting the heat. That would likely be true for a convection microwave,  also.
The smallest microwave I've seen, recently, was a .7 cf at Walmart. If they'd had it in red then, I might just have bought one for the garage.  Weighing in at 20 lbs, even if it doesn't fit in your cabinet, it wouldn't be difficult to move from the closet or pantry to  a tabletop for use.
Walmart also has a Galanz combination .9 cf microwave/air fryer, but it didn't have consistent reviews.  (In all fairness, most combo products I've had do an ok job on both, at best. The exception I've found is a Ninja air fryer/toaster / roaster/ oven, but it's way too big to drag around the country.)
You may get some other ideas from this thread, if you have a cabinet.
