ejhall Posted June 7, 2022 Posted June 7, 2022 Hubby and I are experienced campers currently without a camper. Though we are still (probably) a year away from purchasing a new or new to us camper we are currently researching our options. So far Oliver TTs really tick all of our boxes! We are try to figure out which configuration would be best for us and our two dogs. I noticed that the LEII has the twin bed option with the nightstand between, but the LE doesn’t. Can the dining table in the LE be configured as twin beds? Thanks! The Halls
Moderators SeaDawg Posted June 7, 2022 Moderators Posted June 7, 2022 Welcome to the forum! The le is being redesigned this year. The original, like mine, had a twin floor plan available, with one bed across the back, the other slim bed down the side, utilizing the small dinette. Stay tuned for the redesign. We'll see. Attached is a very old floorplan, for the elite. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators topgun2 Posted June 8, 2022 Moderators Posted June 8, 2022 Depending on the size of the humans and the pups you might find the smaller Ollie to be a bit cramped. It would be best to actually take a look at each model or even better take the factory tour. Welcome! Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted June 8, 2022 Posted June 8, 2022 Welcome to the forum! As Bill said really try and take the factory tour. You will see Ollies being assembled from start to finish and it is truly amazing. All the best with your choice! David 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
johnwen Posted June 8, 2022 Posted June 8, 2022 Hi EJ, FWIW, I agree with Bill. You essentially have a family of 4 and from a couple that lived in a Casita Deluxe for 2 years, which is roughly the size of an Elite, we so much appreciate the the extra room an Elite 2 provides. The floor plan is something I can't help with but for the 2 of us we are very happy with the twin beds. BTA we are full timers and want the space. We wish you the best with your decision, Wendy & John 3 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
CnC Posted June 8, 2022 Posted June 8, 2022 As previous Airstream owners, we too felt the E2 ticked all our boxes - and eliminated so many problems with other designs. The idea of the cabinets molded into the unit meant never having to reinforce screw holes. When you analyze the many things - so many things - that Oliver has built into their design, it makes one smile. And, as production continues, they seem to listen to those of us commenting on their product. Good choice! Charlie 4 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
dewdev Posted June 9, 2022 Posted June 9, 2022 If you contact Oliver, they can set you up to see both the Elite 1 and Elite II somewhere close to where you live. This is recommended if you can not make it to the factory. 3 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
