Frank C Posted August 14, 2022 Posted August 14, 2022 Not a Truma problem but the issue did manifest itself as very low HOT water flow at all faucets. Problem of low hot water flow was the same whether on city water or using pump & fresh tank. COLD water flow was good at all faucets. And I’ve done the decalcification/cleaning process annually. Did some troubleshooting and was initially thinking it was a Truma problem because flow to the hot side of all the faucets was good if I bypassed the Truma at the bypass valve on the Truma cold water inlet. Fearing a very expensive Truma repair, I dug a little further. Opening the Truma drain lever and removing the Truma screen filter, and turning the bypass valve back to normal operating position, and I saw very little flow emptying out of the Truma drain. There really isn’t much inside the Truma on the inlet at that point to even get clogged up, it’s just a direct port into the screen filter, so low flow draining out pointed back to a problem at the plumbing going into the Truma. I removed the bypass valve and found the rubber seal inside had degraded and swollen (see photo), restricting the flow in the normal position. Found a CAMCO replacement on Amazon that’ll be here tomorrow. Hopefully the seal on this CAMCO one holds up better than the original one (different valve manufacturer). I really think a lot of these plumbing components aren’t tested with the chemicals using for RV maintenance like the anti-freeze winterizing solution, or vinegar/water or bleach/water sanitizing solutions, leading to issues with degradation of the seals. A pretty easy replacement of the valve but I’m also going to use this opportunity to redo the cold inlet and hot outlet plumbing connections on the back of the Truma to change to stainless braided flexible supply lines. Not a fan of the rigid plastic connections used by Oliver initially in those locations. Some owners have had the plastic hot water PEX fitting break at the brass TEE on the Truma outlet. With all the bouncing down the road, and thermal expansion and contraction when using the Truma, I want flexible connections there like some of those other owners have upgraded to. Camco bypass valve link to Amazon: https://a.co/d/eGqkhrA 7 5
Galway Girl Posted August 14, 2022 Posted August 14, 2022 You might also consider securing the backof the water heater to the frame with a strap or L brackets. My water heater had an issue which included a fire, and one of the requested steps upon repair from Truma was to firmly attach the back of the water heater down to the frame it's sitting on. (The back of the Truma is sitting on a frame member for the trailer.) After about 3 months, I heard back that the water heater I had was found to have an improperly torqued internal gas connection from the Truma factory. They told Oliver Service that upon tear down they found the torque issue was linked to a manufacturing line situation where their Torque tool wasn't properly calibrated. Not sure what batch of units that impacted but they eventually fully refunded my replacement unit. 3 4 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Frank C Posted August 15, 2022 Author Posted August 15, 2022 16 hours ago, Galway Girl said: You might also consider securing the backof the water heater to the frame with a strap or L brackets. My water heater had an issue which included a fire, and one of the requested steps upon repair from Truma was to firmly attach the back of the water heater down to the frame it's sitting on. (The back of the Truma is sitting on a frame member for the trailer.) After about 3 months, I heard back that the water heater I had was found to have an improperly torqued internal gas connection from the Truma factory. They told Oliver Service that upon tear down they found the torque issue was linked to a manufacturing line situation where their Torque tool wasn't properly calibrated. Not sure what batch of units that impacted but they eventually fully refunded my replacement unit. Thanks for the info from Truma on the mounting issue. I’ll take a look at that as well during the bypass valve repair. 1
Swamp Posted September 22, 2022 Posted September 22, 2022 Question, was it increasing more difficult to open/close as the problem developed? Swamp Pat (Swamp) from Joliet IL, 2021 Oliver LE II Hull "848" (19K miles to date) , 2020 Ram 1500 5.7 Hemi 3:92 rear end P75 Trans "Nowhere to be and all day to get there while looking for a place to happen. Making stops along the way"
Frank C Posted September 22, 2022 Author Posted September 22, 2022 31 minutes ago, Swamp said: Question, was it increasing more difficult to open/close as the problem developed? Swamp No, the bad bypass valve still felt normal when opening and closing it. The faulty seal inside the bypass valve wasn’t noticeable until I removed the valve. The new CAMCO bypass valve is installed and works well so far. One nice little detail of this CAMCO valve is that the positions are labeled (open or bypass). And I changed all water lines into and out of the Truma to braided flexible supply lines and brass fittings to eliminate the issue of breakage of the rigid plastic connections that some owners have had. Camco 37463 3-Way By-Pass Valve Replacement - Brass https://a.co/d/8qur0uz 1 8
Swamp Posted September 23, 2022 Posted September 23, 2022 16 hours ago, Frank C said: No, the bad bypass valve still felt normal when opening and closing it. The faulty seal inside the bypass valve wasn’t noticeable until I removed the valve. I went to winterize my trailer yesterday and my valve was very hard to move. I think a up grade is in future. Thanks for you help in identifying this issue. I hate to be lazy but could you share the info on the lines as well. I like the modification. Swamp 3 Pat (Swamp) from Joliet IL, 2021 Oliver LE II Hull "848" (19K miles to date) , 2020 Ram 1500 5.7 Hemi 3:92 rear end P75 Trans "Nowhere to be and all day to get there while looking for a place to happen. Making stops along the way"
Frank C Posted September 23, 2022 Author Posted September 23, 2022 The braided supply lines with 1/2” female pipe thread ends are available in various lengths at any hardware store like Lowe’s, etc., along with the Sharkbite fittings to go on the existing water lines on the trailer. 3
Moderators topgun2 Posted September 24, 2022 Moderators Posted September 24, 2022 5 hours ago, Frank C said: along with the Sharkbite fittings to go on the existing water lines on the trailer. I do carry an assortment of Sharkbite fittings with me at all times in the event I should need to do a plumbing repair while on the road. However, there have been several posts concerning the possible failure of these fittings (unless performed exactly correct) in the various abusive (read that as vibration and flexing) environments that are common with travel trailers. Bill 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted September 24, 2022 Posted September 24, 2022 On 9/22/2022 at 7:22 PM, Frank C said: No, the bad bypass valve still felt normal when opening and closing it. The faulty seal inside the bypass valve wasn’t noticeable until I removed the valve. The new CAMCO bypass valve is installed and works well so far. One nice little detail of this CAMCO valve is that the positions are labeled (open or bypass). And I changed all water lines into and out of the Truma to braided flexible supply lines and brass fittings to eliminate the issue of breakage of the rigid plastic connections that some owners have had. Camco 37463 3-Way By-Pass Valve Replacement - Brass https://a.co/d/8qur0uz Ordered to keep as a spare if needed. Thanks Frank C! 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rich.dev Posted June 22, 2023 Posted June 22, 2023 On 9/22/2022 at 7:22 PM, Frank C said: And I changed all water lines into and out of the Truma to braided flexible supply lines and brass fittings to eliminate the issue of breakage of the rigid plastic connections that some owners have had. Frank, I love what you've done here, really nice job! Sorry if I missed it but what did you use to connect the braided lines to the existing plastic lines/connectors in these 3 spots? Other than the Camco by-pass valve, do you maybe have a list of all the parts you used? Thanks! **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Frank C Posted June 22, 2023 Author Posted June 22, 2023 32 minutes ago, rich.dev said: Frank, I love what you've done here, really nice job! Sorry if I missed it but what did you use to connect the braided lines to the existing plastic lines/connectors in these 3 spots? Other than the Camco by-pass valve, do you maybe have a list of all the parts you used? Thanks! I used sharkbite connectors to go from the braided supply lines to the original plastic plumbing lines. I got all the parts at Lowe’s. 1 3
Galileo Posted July 25 Posted July 25 Hi all, For a change, I WAS able to use search and find a thread that addressed my issue. Anyway, when de-winterizing this past January, I found the bypass valve in the back of the Truma to be EXTREMELY hard to turn. Being buried under poorly-routed ducts in a tight spot where you can’t see didn’t help much. With what leverage I could muster using just my fingers got the valve -mostly- open and I was in business - sorta. We’ve been noticing that the ECO mode didn’t seem to work, and the normal/comfort mode only delivered lukewarm water. Finally getting around to what causes this, I learned that if that valve isn’t all the way open - it can cause the hot water to be diluted - causing our lukewarm water. Taking a pliers to the valve and much cursing of the brain surgeon who put that valve where he did, I got it to move a bit. But it’s clear that valve is toast and needs replacing. I’m not thrilled with replacing that valve with another one that is made so “well”. Anyone have leads for an upgraded one? 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted July 26 Posted July 26 I must also admit to being a bit puzzled by the plumbing. Turning ONE valve isolates the water heater? I guess I’m thinking of typical household water heaters. If you shut off the inlet (or outlet) you get nothing out of the hot water taps. With this plumbing - the water heater is out of the circuit - and your hot water taps give cold water? I think I read that there’s a check valve on the “other side” of the water heater that keeps pressure in the hot water line from backing up into the water heater(?) 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Snackchaser Posted July 26 Posted July 26 When installing a hot water recirculation system, I found that the isolation valve had pinched the heater duct and worn a hole through it. There is a check valve at the water heater and you can see it in the photo above -- it's the brass spool piece and mine was stuck open. I removed both of them because in the unlikely event that the hot water heater ever needed to be isolated, I'd just shut off the water instead. The hot water recirc system is a great modification that has served us very well.
Galileo Posted July 26 Posted July 26 14 hours ago, Snackchaser said: There is a check valve at the water heater and you can see it in the photo above -- it's the brass spool piece and mine was stuck open. Theres a lot of brass pieces there. I’m assuming you mean the check valve is the first piece attached to the upper port of the water heater? Guessing the next piece after that is just a coupling to join to the tee? I’m not caring for the “quality” or robustness of that bypass valve. I’m thinking that if it is a weak spot in the system, and the check valve apparently is also a failure point - that it might be an option to replace the check valve with a plain old valve, and rework the bypass with a Tee and two valves? Not sure I’m ready to install a whole recirculating system at this point. I’m leaning toward 120v AC point if use heater(s). 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Snackchaser Posted July 26 Posted July 26 24 minutes ago, Galileo said: Theres a lot of brass pieces there. I’m assuming you mean the check valve is the first piece attached to the upper port of the water heater? The check valve is the second brass piece from the water heater, with two hex ends. If you magnify the photos, you can just see the directional arrow on the top side between the hex ends.
Galileo Posted July 26 Posted July 26 12 minutes ago, Snackchaser said: The check valve is the second brass piece from the water heater, with two hex ends. If you magnify the photos, you can just see the directional arrow on the top side between the hex ends. Cool! I see it. whats the piece closer to the WH? Just a coupler? 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted July 27 Posted July 27 Since the existing bypass valve has had issues for at least a few owners already, I’d be very leery about replacing it with another of the same valve. Amazon has at least three 1/2” three-way ball valves - all with more substantial handles and likely better guts. Not sure if THIS is the right configuration - but if not - there’s two others: https://a.co/d/0gG3fFr3 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
