This problem only started near the beginning of 2022, and a year later, I still can't figure it out. I get condensation build up inside of the driver's rear light fixture; right above my head when I sleep.
You can see the rust spots inside of the light. The glass dish/cover will fill with water/condensation and then drip out.
At first I thought it was because that's right where my head was breathing towards; however, I haven't slept in my trailer in a few months, but everytime I hang out in it, I get the same condensation in the same light fixture.
I put a plastic container of Arm & Hammer Moisture Absorber, but after a couple of weeks, it's dry. I altered the placement of the moisture absorber to different locations, but all condensation still goes to the same light fixture.
I know it's not a leak because it occurs in dry weather and rainy, and because I inspected the cabinet with the wires that feeds the electricity to that light fixture. The channel the wires run through in the fiberglass is bone dry. I put multiple q-tips in there but don't show any moisture indicative of a leak coming from anywhere else, or condensation following a path to that location.
In short, I'm stumped why condensation is only attracted to that particular light fixture.
Edited by mossemi
Rotate Pics
2017 Elite 1
Hull 220
1997 Dodge 2500
Also, for some reason my pictures were rotated 90 degrees. I'm not tech savvy enough to know why. They look OK in my phone's photo gallery.
2017 Elite 1
Hull 220
1997 Dodge 2500
The picture seems to indicate this fixture is below the overhead cabinets.   IF so, when the cabinet doors are closed, that area can become quite cool when the hull is cold.
That could cause cold to chill the light and get it cooler than the inside of Ollie.  And that could cause condensation in the fixture.
If I am imagining their location properly, can you open up the cabinets to let them warm up and see if it stops.
Our cabinets got REAL wet inside during a 99% humidity time in cool weather in N.C. during the summer.  Opened the glass cabinet doors, problem went away.
That sounds like a good theory! I'll be at the trailer this Thursday and again on Saturday. I'll leave that cabinet open and see if there's any difference. I'll give a report back on Saturday.
2017 Elite 1
Hull 220
1997 Dodge 2500
It's probably easier for us to open the cabinets, as we have the old school sliders, but opening the cabinet doors does eliminate a lot of condensation, as @Geronimo John suggested.
It's definitely worth a try.
Could also be the low collection point of a tiny leak. Stuff a paper towel,  preferably a blue shop towel, under the third tail light up on the attic, if opening the cabinet doors doesn't improve the situation.
I meant to give an update sooner, but life got crazy like usual.
Leaving the cabinets open seemed to stop condensation inside the light fixture; however, it should be noted that was without anyone sleeping inside the trailer.
We also had some rain recently, and I did not observe any leaks either. To confirm there were no leaks, I left out paper towels and I also removed the rear driver's side speaker.
This allowed me to access the area between the attic and my troublesome storage area; no moisture detected. I'm therefore pretty confident there are no leaks, at least from the rear Oliver light.
I won't get a chance to camp in the trailer until the end of February, so till then I won't know of my condensation problem is completely resolved, but till then, it's looking promising!
Thanks everyone for your help! I'll update again after we go camping next month.
Edited by topgun2
corrected photo
2017 Elite 1
Hull 220
1997 Dodge 2500
12 hours ago, Stranded said:
And for some reason, my pictures are still getting turned 90 degrees to the right.... oh well.
Better?
14 hours ago, topgun2 said:
Better?
Much better, thanks! Any way you can fix the pictures in the first post as well?
2017 Elite 1
Hull 220
1997 Dodge 2500
Probably - how much money and time ya got?😁
Seriously - Hopefully later today I'll get a chance to work on it for you.  The process is actually fairly simple - just import a picture into an editor, rotate it, save it and repost it.
Stranded:
Has it been humid where your Ollie is located?
If so and your Ollie is plugged into shore power, you might consider installing a small dehumidifier inside.
Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and  Xantrex Freedom XC 3000 Pro Inverter in 2025
Maine
On 1/31/2023 at 5:56 AM, dewdev said:
Stranded:
No, it's generally not humid where I live, I'm next to the Antelope Valley.  Also, I don't plug my trailer into shore power.  However, when I start camping again in late February and March, I'll probably get a small dehumidifier for when there is electrical at a campsite. That being said, I usually camp where there is no services.
2017 Elite 1
Hull 220
1997 Dodge 2500
  • 3 years later...
As I am preparing to move out of the camper after 2 and a half months of transition. I found the entire area behind all the insulation was wet enough to be dripping down and out behind the belly band. Im very unimpressed with the fact that the entire shell sweats that bad when they market these as 4 season trailers. Mind you that was with a dehumidifier and damp rid.. also I found out they do not put dicore sealant on the roof at the time it is being built. Only when it comes back for service will that be performed. I am just hoping leaving everything open for a few months will dry it out. Otherwise I will have a nice mold factory just like all the other travel trailers out there.
Way back there in June after 40 nights you did not report any condensation issues.  Now you have issues.  What chanaged?  The weather most likely... i.e. cooler temperatures.
Likely you do not have adequate air changes in your unit AND are seeing lower temperatures especially in the cabinets and other non-heated areas.  Combined you will have condnsation.  It IS necessary to open up your MaxFan just a bit and one of your windows a bit to allow moisture to exit.   When cooking inside, using a higher setting on the max fan and a wider window opening are required as well.  Give this a try and see how it works for you.
Good luck.
PS:  I would wager that 90% of us have had condensation issues at some point, and learned how to manage air changes as much as we must monitor our SOC's.
Edited by Geronimo John
Added "and a wider window opening as well"
One followup thought about your product choice for pure dehumidificaiton:
Typically, our OE2 is stored 7 to 8 months off season (November to June) in a dark barn on top of an OK mountain.  I have used Arm and Hammer for one year and DampRid for 8 years.  DampRid from my use has provn far superior for us.   I noted your picture and for grins checked what AI thinks.
