a new question..  my elite 1  hull number 822.  has the xantrex x 2000          no powee    no `110 while boondocking last week.   checked breaker. turned red arm breaker underneath seat on and off  still no power. inverter not switching on.    any thing else I can check.   im not too mechanical
skip and cyd nielsen  hull #822 Elite     tow vehicle 2017 jeep trailhawk v6
If you can’t turn the inverter on using the remote panel, try using the controls directly on the inverter.  Lots of information available here -
https://support.olivertraveltrailers.com/portal/en/kb/articles/xantrex-inverters
2020 Elite II Hull #628 "Pearl" - Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt
TV - 2011 Toyota Tundra Crew Max Platinum 5.7 V8 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Thanks.  No power at the inverter itself
there are 3 inline fuses in the red wires opposite the inverter.  Turn off all power and checking them next
While you have the power off - also check the tightness of the cable connections.
tried it all    still no power to inverter on dc or ac
4 hours ago, topgun2 said:
@Skipster has two threads going on the same subject.
There’s more viable info on the other thread, albeit it’s in the wrong forum folder.
Check the GFCI on the end of the inverter where the microwave is plugged in. These trip at times and need to be reset by pushing in the breaker button located between the two receptacle outlets if you are not familiar with these. There should be a round access port near the floor labeled GFCI.
Edited by Ronbrink
Took off breaker panel to have access to remote plug. Unplugged and put back in a few times
when I turn inverter breaker off and then back on I hear a beep and another noise but inverter still not switching on
I do not see where microwave would plug in   We do not have a microwave and access is through the seat or by taking breaker box off
That little button on the end of the inverter is not popped out and does nothing when I push on it
Took cover off and nothing seems loose. Couple pics with cover off
Will check for power with a meter tomorrow
My replies are and will be added to the other thread, and there are more relevant pics there...
I was hoping this would have been corrected...
