BBL Posted August 4, 2023 Author Posted August 4, 2023 45 minutes ago, SeaDawg said: It would be super nice if lithium controllers gave you the choice to charge only to a certain per centage in storage Lithionics batteries have ON/OFF switches so you can turn the battery itself OFF for storage. I think that is a nice feature and it's good when you want to do work around the battery. BL 2
MAX Burner Posted August 4, 2023 Posted August 4, 2023 1 hour ago, Brian and Brandelyne said: Lithionics batteries have ON/OFF switches so you can turn the battery itself OFF for storage. I think that is a nice feature and it's good when you want to do work around the battery. Concur, 100%. I'm thinking, as a "Battle Born Guy", that one would achieve the same effect by having a master battery cut-off switch inside the battery compartment, labeled accordingly, specifically for first responders in the case of a fire and the need for securing electrical power to the rig. 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators SeaDawg Posted August 5, 2023 Moderators Posted August 5, 2023 2 hours ago, Brian and Brandelyne said: Lithionics batteries have ON/OFF switches so you can turn the battery itself OFF for storage. I think that is a nice feature and it's good when you want to do work around the battery. BL That's true, and degradation/depletion is extremely minimal, with lithium ion in storage. I'm thinking of people like me (still on agm) who leave the fan on low, and both vents open somewhat, to circulate air. My FanTasic fan uses .5 amps on low, thermostatic regulated, so not constant, and we've narrowed our ghost draw to less than .4 amps, so solar keeps our agms up, just fine. But, agm batteries like being 100 per cent,,and lithium don't. Since we don't have lithium batteries on the boat, either, I've not checked to see if we can adjust charging level for storage. Wete it me, I'd like to be able to leave the minimal draw of a fan, on low, and ghost draw active, and not deplete my lithium batteries. Just my (probably off the wall) thoughts. 4 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
NCeagle Posted August 5, 2023 Posted August 5, 2023 8 hours ago, SeaDawg said: That's true, and degradation/depletion is extremely minimal, with lithium ion in storage. I'm thinking of people like me (still on agm) who leave the fan on low, and both vents open somewhat, to circulate air. My FanTasic fan uses .5 amps on low, thermostatic regulated, so not constant, and we've narrowed our ghost draw to less than .4 amps, so solar keeps our agms up, just fine. But, agm batteries like being 100 per cent,,and lithium don't. Since we don't have lithium batteries on the boat, either, I've not checked to see if we can adjust charging level for storage. Wete it me, I'd like to be able to leave the minimal draw of a fan, on low, and ghost draw active, and not deplete my lithium batteries. Just my (probably off the wall) thoughts. My "ghost" draw is around 1.7 amps (refrigerator, radio, CO detector, Natures Head fan, ...), so about 40 amp hours per day (10% of my Lithium capacity). I also don't want to turn everything off for storage and I don't want to keep my Lithiums at 100% or even 90% while sitting in my storage garage, so in this scenario I set my Xantrex to "float" my Lithiums at 13.2v which is about 50% SoC. What eventually happens is the battery settles to "standby" with net zero current at 13.2v and the Xantrex uses only the power necessary to keep the batteries at 13.2v - thus passing enough power through the battery to satisfy whatever battery draw is present. 3 2020 Elite II, Hull 688 --- 2021 Silverado 2500HD, 6.6L Duramax Diesel
Moderators mossemi Posted August 5, 2023 Moderators Posted August 5, 2023 I’m feeling kind of primitive with my battery maintenance schedule. My Ollie is plugged into a 20 amp circuit while in storage and I turn the battery charging breaker off when the batteries reaches 100%. Then I wait for Victron's VRM service to send me an email letting me know that the batteries have reached 35% SOC and I trudge 25ˋ up the hill in the snow and turn the breaker back on until the batteries again reach 100%.😂 And then I repeat the sequence. I have thought about incorporating a relay to automatically shutting off the breaker and maybe that’s a future project. We all have to figure out what works for our non camping lifestyle! Mossey 2 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators topgun2 Posted August 5, 2023 Moderators Posted August 5, 2023 12 minutes ago, mossemi said: I trudge 25ˋ up the hill in the snow Really?😁 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rich.dev Posted August 6, 2023 Posted August 6, 2023 @Brian and Brandelyne Brian, did you leave the charge controller “low temperature cut-off” at the default of 41°F (5°C) or did you change it? 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
BBL Posted August 6, 2023 Author Posted August 6, 2023 1 hour ago, rich.dev said: Brian, did you leave the charge controller “low temperature cut-off” at the default of 41°F (5°C) or did you change it? Rich - on my charger that setting is "Disabled" but if I go to turn it on, the 41 degrees shows up. This is how Oliver set it up and they got the settings from Lithionics. I am assuming it is that way because the batteries have a built in battery heater. The battery spec says the heater will shut off when temperature reaches 40 degrees. I am ok with these settings, they make sense to me. Regards, BL 1
