Doug S Posted October 18, 2023 Posted October 18, 2023 Hi all, We now have our deposit down!! - and are starting to look at minor customizations. So our first area to focus on is a rear table for the twin. Clearly Overland's approach to a flexible table is elegant, functional, and good looking, so I'm looking at using that as a foundation. I'm also interested in adding one more piece of functionality to literally support our two small (12lb) dogs. I'd like to use something similar for the support that Foy is using for his twin to king conversion. Something that brings enough vertical strength that would de-risk collapsing the Lagun arm or fracturing fiberglas from a wayward human. And once there is enough support we could use the same mattress material as those used in the beds, so that it would nearly be a functional king. If Foy sees this I would love to have that dialog. I know I can reach him directly, but it seemed better to launch it in the forum. - Thanks - Doug 1 Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Doug S Posted October 18, 2023 Author Posted October 18, 2023 I just realized the obvious - the table by itself isn't long enough, so there would need to be "more". Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
MAX Burner Posted October 18, 2023 Posted October 18, 2023 FYI: We made a table for the Lagun mount from some available red oak we had in the woodshop. The mount is centered on the nightstand. The underside of the table is "grooved" and can be fitted on the bed rails so our 55lb husky, Magnus, can curl up between us at night. It is serving us well so far - Magnus seems to like it too. The table and mount is stored/bungie-corded on the left side closet bulkhead. transitioning to the "dog-bed" mode above. View from below with table grooves on bed rails above. Table mode - can swing over either bed or centered in aisle for a secondary workstation.... 1 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Wandering Sagebrush Posted October 18, 2023 Posted October 18, 2023 Art, very nice! 😊 Our previous owner did something similar with two pieces of ply to fill the gap. Their wirehaired griffon slept under it, and they had a king size bed. We haven’t used that feature yet, but another benefit is with the cushions stacked next to the galley counter, and one of the ply segments on top, it makes a great extension to the counter top. Our Lagun table attaches mid way down the street side bunk (we have basement access), and stores out of the way in the closet. 1 1 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Wandering Sagebrush Posted October 18, 2023 Posted October 18, 2023 12 hours ago, Doug S said: I just realized the obvious - the table by itself isn't long enough, so there would need to be "more". Doug, we have two segments that create a king size bed. They’re in storage now, but I could drag them out and take photos if you need. Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Doug S Posted October 19, 2023 Author Posted October 19, 2023 14 hours ago, Wandering Sagebrush said: Doug, we have two segments that create a king size bed. They’re in storage now, but I could drag them out and take photos if you need. Thanks for the offer! I think I've got some more thinking to do though. I guess my first question is "do you use it"? So you use the Lagun table from midway. Does that bring any advantage that you were looking for? Doesn't it get in the way of your (or someone else's) legs? 1 Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Wandering Sagebrush Posted October 19, 2023 Posted October 19, 2023 We mostly use the Lagun for additional counter space or games, and it doesn’t get used a lot. I may buy a second mount, and use it in my All Terrain (ATC) pop up truck camper shell model. Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Ronbrink Posted October 19, 2023 Posted October 19, 2023 1 hour ago, Wandering Sagebrush said: and it doesn’t get used a lot. I find the Lagun most useful as a bed table, especially in the morning to accommodate an iPad and coffee while sitting up against the rear wall, as well as the evening in similar manner. I can also use it at the other end when watching TV. Of course the table serves other purposes, as you mention, and thus its’ versatility and usefulness justifies leaving it up full time. Currently in the process of mounting a second for the wife’s bed. 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators mossemi Posted October 19, 2023 Moderators Posted October 19, 2023 On 10/17/2023 at 8:13 PM, Doug S said: If Foy sees this I would love to have that dialog. I know I can reach him directly, but it seemed better to launch it in the forum. - Thanks - Doug It is often easier to reach Foy through the Oliver Facebook group. Mossey Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Doug S Posted October 19, 2023 Author Posted October 19, 2023 4 hours ago, Wandering Sagebrush said: We mostly use the Lagun for additional counter space or games, and it doesn’t get used a lot. I may buy a second mount, and use it in my All Terrain (ATC) pop up truck camper shell model. Thanks - seems like a lower priority for me right now. Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Doug S Posted October 19, 2023 Author Posted October 19, 2023 4 hours ago, Wandering Sagebrush said: We mostly use the Lagun for additional counter space or games, and it doesn’t get used a lot. I may buy a second mount, and use it in my All Terrain (ATC) pop up truck camper shell model. 7 minutes ago, mossemi said: It is often easier to reach Foy through the Oliver Facebook group. Mossey Thanks for the advice Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Doug S Posted October 19, 2023 Author Posted October 19, 2023 4 hours ago, Wandering Sagebrush said: We mostly use the Lagun for additional counter space or games, and it doesn’t get used a lot. I may buy a second mount, and use it in my All Terrain (ATC) pop up truck camper shell model. Thanks - I think I'll just put it in the "let's see after we use it a while" category. Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Doug S Posted October 19, 2023 Author Posted October 19, 2023 2 hours ago, Ronbrink said: I find the Lagun most useful as a bed table, especially in the morning to accommodate an iPad and coffee while sitting up against the rear wall, as well as the evening in similar manner. I can also use it at the other end when watching TV. Of course the table serves other purposes, as you mention, and thus its’ versatility and usefulness justifies leaving it up full time. Currently in the process of mounting a second for the wife’s bed. That's really interesting. Are you shifting the mounting locations? I notice that you had it at the nightstand middle at one time? Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Ronbrink Posted October 19, 2023 Posted October 19, 2023 1 hour ago, Doug S said: Are you shifting the mounting locations? Kinda, removed the original Lagun plate that Oliver installed on the nightstand, and used it with a dynamic system I designed and built. I field tested an initial prototype with much success a few months ago. However, further iterations needed to address some inherent design flaws have taken the months since. I am now ready to perform a stress test on the system, followed by more field tests for functionally and safe usage. The only other information willing to share at this time is that the nightstand drawer is no longer obstructed. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators mossemi Posted October 20, 2023 Moderators Posted October 20, 2023 4 hours ago, Ronbrink said: Kinda, removed the original Lagun plate that Oliver installed on the nightstand I may have some hole plugs that will fit the screw/bolt mounting holes from the original Lagun base plate if you haven’t already done that. Let me know the size you need and I’ll see what I have left. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Doug S Posted October 20, 2023 Author Posted October 20, 2023 10 hours ago, Ronbrink said: Kinda, removed the original Lagun plate that Oliver installed on the nightstand, and used it with a dynamic system I designed and built. I field tested an initial prototype with much success a few months ago. However, further iterations needed to address some inherent design flaws have taken the months since. I am now ready to perform a stress test on the system, followed by more field tests for functionally and safe usage. The only other information willing to share at this time is that the nightstand drawer is no longer obstructed. Sounds like a serious plan with a lot of mobile site testing needed. 1 Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Ronbrink Posted October 20, 2023 Posted October 20, 2023 5 hours ago, Doug S said: Sounds like a serious plan with a lot of mobile site testing needed. Well, I tend to over-think and over-engineer everything, drives my wife nuts! Not that “serious”, but if I told someone my motto was “I strive for perfection to achieve satisfaction”, maybe they would understand! As for testing, I can only do so much in the driveway; need to travel and camp to see how all performs, or is that just an excuse to pack up and get away? This would be a ‘one trip wonder’ to see if I’m ‘there yet’. More to come, hopefully sooner than later. 1 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted October 20, 2023 Posted October 20, 2023 10 hours ago, mossemi said: I may have some hole plugs that will fit the screw/bolt mounting holes Thanks, I really appreciate the offer. Actually I bought hole plugs, just haven’t installed them yet; I tend to save the easier things for last! Again thanks! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators SeaDawg Posted October 21, 2023 Moderators Posted October 21, 2023 Wife of engineer, "apprentice" of many decades, totally gets it. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Doug S Posted October 21, 2023 Author Posted October 21, 2023 17 hours ago, Ronbrink said: Well, I tend to over-think and over-engineer everything, drives my wife nuts! Not that “serious”, but if I told someone my motto was “I strive for perfection to achieve satisfaction”, maybe they would understand! As for testing, I can only do so much in the driveway; need to travel and camp to see how all performs, or is that just an excuse to pack up and get away? This would be a ‘one trip wonder’ to see if I’m ‘there yet’. More to come, hopefully sooner than later. I’ll save a place to note the outcome. 1 Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Ronbrink Posted November 9, 2023 Posted November 9, 2023 On 10/21/2023 at 12:12 AM, Doug S said: I’ll save a place to note the outcome. After much thought and further iterations, hopefully with this final prototype, as installed, I will “achieve satisfaction”! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
MAX Burner Posted November 9, 2023 Posted November 9, 2023 Nicely done, well thought out. Thanks for posting! 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted November 9, 2023 Posted November 9, 2023 On 10/20/2023 at 1:26 AM, Ronbrink said: Well, I tend to over-think and over-engineer everything, drives my wife nuts! Not that “serious”, but if I told someone my motto was “I strive for perfection to achieve satisfaction”, maybe they would understand! Yes, another kindred spirit to recognize for having a unique, but time consuming talent! I hereby bequeath you with this ceremonially appropriate T-shirt. GJ "The rabbit hole expert" 4 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted November 9, 2023 Posted November 9, 2023 4 hours ago, Ronbrink said: After much thought and further iterations, hopefully with this final prototype, as installed, I will “achieve satisfaction”! I took notice of your steel reinforcement of the fiberglass bed edge. My experience with loading them with between bed platforms and existing cushions was that they are really strong. Just wondering what lead you to that mod? Thanks GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 10, 2023 Posted November 10, 2023 19 hours ago, Geronimo John said: I took notice of your steel reinforcement of the fiberglass bed edge. My experience with loading them with between bed platforms and existing cushions was that they are really strong. Just wondering what lead you to that mod? Actually, aluminum bar was used; lighter weight and can be worked much like wood. Although the fiberglass bed edge worked, as evidenced by the first set of pics (above) with the original ‘black’ tabletop, it proved to be too weak (think flex and stress) when the table was fully extended over the bed. However, with said weaknesses and inconsistencies found when trying to fit the street side bed, yet another of many iterations in this project was implemented. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
