rideadeuce Posted May 20, 2024 Posted May 20, 2024 I don't know enough to really answer your question but what the deciding factor for me was that Victron stated somewhere that the non-isolated version will work for most (99%) of applications. Maybe @MAX Burner will have some input after having had some experience using it. 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
jd1923 Posted May 21, 2024 Posted May 21, 2024 13 hours ago, Galway Girl said: A simple way to connect the new DC charging lead, using a standard (larger) lug, would be to merely double up on the battery lead on the far right in this picture. There are enough threads on the bolt, and you have a direct connection without going through the bus and any resistance it may cause. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
MAX Burner Posted May 23, 2024 Author Posted May 23, 2024 (edited) On 5/20/2024 at 6:36 PM, rideadeuce said: Maybe @MAX Burner will have some input after having had some experience using it. The Victron 12/12vDC charger totally meets our camping style and needs... When departing after boon docking for a few days during overcast weather - we know that our SOC will be at 100% within a few hours, so we'll start with a "full deck of BB cards" at the next destination. As y'all know, the "non-isolated" version will require installation of a dedicated negative cable from the TV battery/alternator to the rear bumper connection then continue with a thru-hull penetration to the Smart Shunt bus bar. FYI, (knocking on wood) we're 3,000+ miles into an 18-day trip and the Victron suite has performed flawlessly. Glad to hear at LGSP that OTT is considering Victron as an optional upgrade - good stuff along with Renogy, Blue Sea Systems, and others. Cheers! Edited May 23, 2024 by MAX Burner 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted May 23, 2024 Posted May 23, 2024 5 hours ago, MAX Burner said: As y'all know, the "non-isolated" version will require installation of a dedicated negative cable I am thinking that it is a wise idea to install a negative regardless of which Victron 12-12 30 you purchase. Why: One way or another the rated power of the DC - DC charger will be flowing from the TV battery to the Ollie batteries. With my clamp on amp meter, tests with a pair of 4 AWG wires for the pathway, I see 100% flowing via the Positive, and about 70% flowing via the Negative cable. So, the rest, 30%, is flowing via the frame/Andeson Chains, and Bulldog to the frame. Without the Negative cable "home run", all of it would be going thru the frame via the Bulldog, greased balls and Anderson chains ending up at the Battery Cable for the TV. The Battery Cable may or may not be sized for the additional load. But for sure, the series of resistance connections on that path would be a concern. With a clamp on amp meter and our 712 Smart, we can learn a lot. Kind of fun exercise as well. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rideadeuce Posted June 8, 2024 Posted June 8, 2024 Curious to what others with the Orion XS 50 amp 12/12 installed are using for their charge settings and engine shutoff settings. I have mine wired with the TV battery negative to my negative bus which goes to chassis ground and house Epoch battery negative. The positive IN is obviously from TV using 4 awg wire. Orion OUT goes to hot bus bar in rear. My voltage number IN/OUT are fine but the Amps are staying low between 7-11 maybe 14 for a bit on the highway yesterday. Just trying to problem solve. Used 4 AWG for all connections. 2 60 amp manual breakers Thinking about running hot ORION OUT to main pos bus in trailer instead of the rear one and taking neg directly to main chassis ground from TV battery and Orion instead of using neg busbar. Any thoughts @MAX Burner what kind of numbers are you seeing on your trip? Best, Mike - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Ronbrink Posted June 8, 2024 Posted June 8, 2024 (edited) 3 hours ago, rideadeuce said: Thinking about running hot ORION OUT to main pos bus in trailer instead of the rear one and taking neg directly to main chassis ground from TV battery and Orion instead of using neg busbar. Running a dedicated 4 AWG ground wire directly from the TV’s battery to the rear bumper Anderson port, then continue the run of same size cable directly to the DC-DC would likely solve your problem. Edited June 8, 2024 by Ronbrink 1 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
rideadeuce Posted June 8, 2024 Posted June 8, 2024 2 hours ago, Ronbrink said: Running a dedicated 4 AWG ground wire directly from the TV’s battery to the rear bumper Anderson port, then continue the run of same size cable directly to the DC-DC would likely solve your problem. That makes sense. I will give it a try! 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
rideadeuce Posted June 8, 2024 Posted June 8, 2024 (edited) Voila! Immediately went up to 31 amps at idle then settled down at around 14 amp. Voltage output went up from 13.5 to 13.9 as set. @Ronbrink Thanks again. About to head out on the road to do a test run to see how well I can monitor it remotely. Edited June 8, 2024 by rideadeuce 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
rideadeuce Posted June 8, 2024 Posted June 8, 2024 (edited) So went out for lunch and the Orion seemed to be maxing out at around 15 amps. Still double than what I was getting yesterday. The cool thing is I figured out how to remotely monitor the Orion through the Ekrano WIFI instead of the online VRM which is hard to see what exactly each device is doing. But if I go to the Victron Connect app and go to VRM => devices. Each device shows up individually through the Ekrano display, which is nice for monitoring while traveling down the road. The bluetooth direct connect does not work for me in TV, just out of range while driving. I wonder if the Epoch battery BMS which is controlling the charging may be limited charging? 2016 Tundra's 150 amp alternator may be getting tired? Mike Edited June 8, 2024 by rideadeuce 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
jd1923 Posted June 8, 2024 Posted June 8, 2024 2 hours ago, rideadeuce said: I wonder if the Epoc BMS which is controlling charging may be limited charging? 2016 Tundra's 150 amp alternator may be getting tired? Mike The BMS can limit, but note your MPPT solar charger is offering 33A, that's 48A total if I'm reading this right. 150A on the truck alternator is good number given it is in good condition, many are rated lower. Try running your test again, with your batteries needing charge (<80% SOC) and your MPPT solar charger turned off. This will show what the Tundra alternator and DC-to-DC is capable. 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideadeuce Posted June 8, 2024 Posted June 8, 2024 It was a good idea but unfortunately after testing with MPPT off no difference in results. Battery SOC 50%. I also tried turning off the Epoch BMS and changing some other settings to no avail. I know you had shown some interest in the EPOCH batteries. This link has some helpful insight to their Pros and Cons. I still think they are great but there are some things you need to know about them. I am still using the Victron comms. Link: https://panbo.com/update-epochs-460ah-battery-what-weve-learned/ 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
jd1923 Posted June 9, 2024 Posted June 9, 2024 2 hours ago, rideadeuce said: I know you had shown some interest in the EPOCH batteries. This link has some helpful insight to their Pros and Cons... Thanks for the article link. It went back to the Victron SmartShunt, gotta love it! Change your charge settings to 13.9 and 13.4 as stated. This makes total sense yet blows many LiFePO4 manufacturer's recommendations (grain of salt). Many people leave maintenance chargers on 24x7, not a good idea IMHO. I connect a charger only when needed, and I keep shore power off unless we need to run AC. I'll trust our old-school Blue Sky SC, never see voltage over 14V with it on alone. Don't trust RV shore power/120V chargers or inverter/chargers either when connected fulltime and more so for storage. Just don't do it. Recently I'm more interested in Epoch without the Victron Comms. Was thinking of two of these 300AH batteries to start and perhaps a 3rd or 4th later with some installation wizardry (that is a word, right GJ?). There is room in the bay for a 3rd with a tray mod and maybe room in the basement for another one to two! This could add up to 900AH, 1200AH, OMG 1500AH! ~🤣 Too bad the 2x 460AH Epochs w/o Victron Comms will not fit no matter what you do. 600AH at 80% = 480AH (conservative estimate with a 20% safety factor) is more than 2x what I have today in 450AH LA at 50% = 225AH (2.13 more available AH). I believe you made the right choice Mike. Who has more LiFePO4 AHs than you in an Oliver (nobody)! If they run another Black Friday sale at an additional 15% off, you can source 600AH OTD under $2,000, a nice number for a LiFePO4 upgrade and I have all the 4/1 cable, lugs and tools I need. I see these in my future, look for my upgrade TBD: 12V 300Ah Heated & Bluetooth LiFePO4 Battery - Epoch Essentials (epochbatteries.com) 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideadeuce Posted June 9, 2024 Posted June 9, 2024 9 hours ago, jd1923 said: There is room in the bay for a 3rd with a tray mod and maybe room in the basement for another one to two! I looked into this as well definitely an option with the LiFePO4 batteries. 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
MAX Burner Posted June 27, 2024 Author Posted June 27, 2024 On 6/8/2024 at 5:41 AM, rideadeuce said: Any thoughts @MAX Burner what kind of numbers are you seeing on your trip? Sorry for the delayed response, I missed this post somehow... We're seeing 26 - 28.5A (max so far) from the Orion unit with SOCs in the mid-60% range. The 50A model would be nice, we would've probably got one, but they weren't available yet when I dropped the hammer on getting our 30A unit. 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Teaney Hull 292 Posted yesterday at 02:30 PM Posted yesterday at 02:30 PM On 11/3/2023 at 11:07 AM, MAX Burner said: After detailed discussions with @Geronimo John regarding a DC-DC Charger installation, we finally got around to making it happen. There's a ton of posts on this mod/upgrade, so we're not going down the rabbit hole to the end - just saying that it's a worth while mod to consider. Essentially, our concern was the 12AWG DC circuit from the 7-pin connector supplying an inadequate DC current to the OTT while towing, especially during the hours of darkness when there's no solar input to the battery bank. So, we decided to go with the Victron 12/12 30amp Bluetooth unit to be compatible with our other Victron devices (Smart Shunt, MPPT Solar charger, and the Cerbo S-GX multiplexer). We decided to upgrade from the OTT factory PWM solar module controller to the Victron MPPT unit. We also added the 7" Victron Touch to monitor all our AC and DC input/output activity which has been a game changer for us. Here's a series of pix that may satisfy the curiosity of those interested in efficiently charging the battery bank. FYI: We've got 3x BB's and ran 1/0 cables from the TV's smart alternator to an Anderson plug installed at the hitch, then 4 AWG cables from the Anderson through a Blue Sea Cable Clam to the Victron DC-DC charger installed under the aft dinette seat. The cables were snaked from the forward bulkhead under the toilet to the forward dinette seat, under the dinette table, to the aft dinette seat area: Below shows the location for the Victron Cerbo S-GX Touch Screen... This is the location where we mounted the new Victron MPPT Smart Solar Charger, upper street side compartment where the old PWM solar charge controller was mounted: We mounted the Victron remote solar controller monitor to the right of the Touch Screen... Building the Anderson plug for the OTT with 4AWG cables... Below shows the Blue Seas Cable Clam hull penetration adjacent to the 7-pin cable... Victron DC-DC Charger mounted on the street side wheel well/aft dinette seat next to the Progressive surge protector... Note the 50amp breaker between DC-DC Charger and the battery bank. We installed another 50amp breaker between the TV alternator and the Anderson connection: Pulling 4AWG cables from the hull penetration under the head sink thru the front of the toilet and to the aft dinette seat area... Thanks to @ScubaRx - Steve gave a great suggestion for snaking wires through challenging areas using a stiff plastic strap for securing pallet loads... One and done. I'm going for a cold one... Need your help on my DC to DC Orian 50 amp charger on Hull 292. There are 3 cables coming out and does not seem to have any more room for my Clam for the 2/0 cable. Should I go to the side of the rectangle? Or should I try to use on of the cable holes and add it to my clam? See pic attached. I’m open to any suggestions. Thanks Gary Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
