Wandering Sagebrush Posted January 3, 2024 Posted January 3, 2024 A bit pricey, but they don’t expire, have a long discharge time, and are small enough to fit in the door pocket of most vehicles. Santa was good to me. I’m going to buy a couple more. 3 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Patriot Posted January 3, 2024 Posted January 3, 2024 Neat find, can you send your Santa to Western NC? 😄 Here is a link to more info and prices. I like that it has pretty solid reviews, leaves no residue, is fairly compact and no expiration date. https://elementfire.com/collections/allproducts FAQs -https://elementfire.com/pages/faq Amazon -https://www.amazon.com/UTVDistribution-Element-Extinguisher-Mounting-Magnet/dp/B0C1WL9KLC/ref=sr_1_1_sspa?keywords=element+fire+extinguisher&qid=1704286282&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 Patriot🇺🇸 2 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Ronbrink Posted January 3, 2024 Posted January 3, 2024 35 minutes ago, Patriot said: Here is a link to more info and prices Thanks, used a 10% off discount code, no tax, free shipping on my purchase of two E50s from the referenced website! Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Wandering Sagebrush Posted January 3, 2024 Author Posted January 3, 2024 They are also certified for A, B, C, and K class fires. 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Wandering Sagebrush Posted January 5, 2024 Author Posted January 5, 2024 On 1/3/2024 at 5:24 AM, Ronbrink said: Thanks, used a 10% off discount code, no tax, free shipping on my purchase of two E50s from the referenced website! I just did the same. One for each truck, one for the Ollie or Camper. 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Steve Morris Posted January 6, 2024 Posted January 6, 2024 I have an Element 50 as well as two traditional fire extinguishers in the truck. On other forums, I've seen recent comments questioning the value of the Element fire extinguishers. I have zero actual use experience, but just wanted to let folks know it may or may not be as effective as expected. Here are a couple of failure to extinguish videos posted: 20:15 into this video for the Element And lastly, this notice by California State Fire Marshall )may have more to do with documentation thatn actual effectiveness.) Better than nothing, but I'm not going to replace a traditional fire extinguisher with an Element. 1 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Ronbrink Posted January 7, 2024 Posted January 7, 2024 22 hours ago, Steve Morris said: I have zero actual use experience, but just wanted to let folks know it may or may not be as effective as expected. No doubt, not effective on a fully engulfed fire. It is imperative one understands the limitations of these and proper use. Unlike conventional extinguishers, Element is meant to remove one leg of the fire triangle, oxygen, and not meant to be aimed at the ‘source’, as demonstrated in the featured videos. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Steph and Dud B Posted January 7, 2024 Posted January 7, 2024 43 minutes ago, Ronbrink said: Unlike conventional extinguishers, Element is meant to remove one leg of the fire triangle Actually, most of them do that. Carbon dioxide and foam extinguishers also remove the oxygen. Water extinguishers remove the heat. The ABC dry chem extinguishers work by interfering with the chemical reaction itself (the fourth side of the now-called "fire tetrahedron"). 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Wandering Sagebrush Posted January 7, 2024 Author Posted January 7, 2024 We now carry both traditional and Element fire extinguishers. What I like about the Element is the long burn time, and the small size that makes it handy to store (and grab) in the cab of the TV. Prior to buying, I spoke with my daughter who recently retired as a Fire Marshal from a large Oregon fire district. She keeps them in her vehicles. 5 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Steph and Dud B Posted January 7, 2024 Posted January 7, 2024 Here's a really good video, made by a firefighter, that tests and goes over proper use of multiple fire extinguisher types - including the Element: I don't think the Element is a replacement for a regular fire extinguisher, but it's another tool in your arsenal - like the First Alert spray we have under our bed rails - that might be helpful because of its proximity when you need it. 5 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Ronbrink Posted January 8, 2024 Posted January 8, 2024 22 hours ago, Steph and Dud B said: I don't think the Element is a replacement for a regular fire extinguisher, but it's another tool in your arsenal Bingo! With early detection of a fire the Element will likely suffice, but if a fire is more involved then another type of extinguisher would be required. I like the fact that the Element will not necessitate a HazMat cleanup following its’ use. I have firsthand knowledge of an incident wherein a fire extinguisher somehow accidentally discharged inside a vehicle and it had to salvaged due to the high expense of a cleanup. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
